- Local time
- 10:22 AM
- Joined
- Jun 29, 2022
- Messages
- 483
OK team , Here it goes . I need the hive Mind .
So first overlanding trip in the Grenadier is comming up . So i decided to make a master lsit of spare parts to go with it . Below is everythign i want to carry with me . I have found part numbers for most things but not for everyting .
What i would appreciate is that if any one of you can Copy this list in a new reply and add part numbers to it .
I will not put Fuse part numbers because the legend of a man @TheDocAUS made an exaustive list here: https://www.theineosforum.com/threads/main-fuses-used-in-ineos-grenadier.12411958/
The main problem is BMW engine parts because when ordered from INEOS are very expensive vs when oredered from BMW
My list is based on the B57 engine
The Master list :
Thank you guys , please add anything you fell is needed.
The Master list :
| Ineos Part Number | OEM manufacturer Part Number | Aftermarket Part Number | ||||
| Alternator | EI-0000015983 | SEG/Bosch Part Number: | ||||
| Starter Motor | EI-0000006985 | SEG/Bosch Part Number: | ||||
| Top Radiator hose | BMW Part Number: | |||||
| Bottom Radiator hose | BMW Part Number: | |||||
| Front Wheel Speed sensor | GRA-5E00-006960 | |||||
| Rear Wheel Speed sensor | GRA-5F00-006860 | |||||
| Front wheel studs | GRA-5E00-002680 | |||||
| Rear Wheel studs | GRA-5F00-021700 | |||||
| Oil filter | BMW Part Number : 11427826799 | |||||
| Fuel Filer | ||||||
| Air filter | GRA-3B02-008230 | MAHLE Part Number: LX3985/1 | ||||
| Front Break pads | Brembo part Number: P68062 | |||||
| Rear break pads | Brembo Part Number : P68063 | |||||
| Wiper blades Front | Bosch Part Number : AR16U |
