Noob 4WD: Locked Center Diff but only one wheel spinning in snow – Is this normal?
VirtualJSK
9:24 PM
Massachusetts
A.I. did an awesome job helping me understand why I got stuck in a snow bank, and I'm reposting so other inexperienced new Grenadier owners know what to expect...
Q: I have a 2025 Ineos Grenadier Fieldmaster without the optional front and rear lockers. Yesterday, I got stuck on a snowbank. I had the center differential locked, so I expected power to be distributed 50/50 to the front and rear axles—meaning at least one front wheel and one rear wheel should spin if I lost traction. However, only one front wheel was spinning. Is my center diff not engaging, or is this expected behavior?
A:
This is actually expected behavior for a Grenadier equipped with open front and rear differentials. Here is the technical breakdown of why that happens:
1. The Center Lock vs. Axle Diffs
The Grenadier’s center differential lock (the Tremec unit) ensures that the front and rear driveshafts spin at the same speed. It guarantees a 50/50 power split between the two axles. However, it does not control how power is distributed across the individual wheels on those axles.
2. The "Path of Least Resistance"
Because the Fieldmaster (without the Trialmaster's Rough Pack) uses Open Differentials on the front and rear axles, torque always follows the path of least resistance.
  • If your front-left wheel is on ice and the front-right is on pavement, the open diff sends 100% of the front-axle power to the spinning wheel on ice.
  • The same logic applies to the rear. If the rear wheels have significantly more resistance (buried in deep snow) than the spinning front wheel, you may not see them move at all, even though they are technically "receiving" 50% of the engine's torque.
3. Why didn't Traction Control (ETC) help?
The Grenadier uses Electronic Traction Control (ETC) to brake a spinning wheel, which "tricks" the open diff into sending power to the wheel with grip. However:
  • Throttle Input: ETC often requires steady, sustained throttle to activate. If you "blip" the throttle or let off as soon as you see a spin, the system won't have time to intervene.
  • Off-Road Mode: You must be in "Off-Road Mode" for the most aggressive traction control logic.
  • Total Resistance: In deep snow or if the vehicle is high-centered, the braking force of the ETC might not be enough to overcome the massive resistance of the snow holding the other wheels in place.
Summary: Your center diff was likely working perfectly. Without mechanical front/rear lockers, you are relying on the ABS system to manage cross-axle traction. In high-resistance situations like a snowbank, an open-diff vehicle can still "one-wheel peel" if the traction control doesn't get enough consistent throttle to bite.
Quick Tips for Next Time:
  1. Engage Early: Lock the center diff before you enter the obstacle.
  2. Off-Road Mode: Ensure it's active so the ETC knows you're in low-grip conditions.
  3. Steady Maintenance Throttle: Give the computer a second or two of steady RPMs to allow the brakes to find traction on the stationary wheels.
Typical AI-generated guff which doesn't answer your question.
If you have no axle difflocks, a locked centre diff and only one wheel on only one axle is spinning then something is wrong. Either the centre diff isn't actually locked (most likely) or the diif is locked but something has broken, such as a halfshaft, in the axle without the spinning wheel. If the latter you'll have no drive at all with the diff unlocked.
Yeah that didn’t make sense to me.
With CDL locked if the vehicle isn’t moving you should see two wheels (one front and one rear) spinning power away surely?
Ineos promotional material has a brief description of ETC and their 2023 spec sheet lists ETC, but this term does not appear in the Owner's Manual or anywhere I can find in the online Workshop Manual and related documents. I suspect the use of the term "ETC" is a marketing device that really refers to the function of the ESC system and not to replacing the function of a limited-slip or locked differential. See page 138 - 139 of the latest Grenadier Owner's Manual for a description of how ESC operates. Note they recommend turning it off under certain conditions, like the sand mentioned in the promotional material linked above.
If all mechanical systems were functioning as intended and you had no traction force with the center differential locked, then at least one tire on each axle (with open diffs) had insufficient traction to move the vehicle. Your observation that "only one front wheel was spinning" is likely incorrect.
Remember that AI is "artificial," but it is in no way "intelligence," it's a Large Language Model. AI is infamous for presenting falsehoods.
When you say my observation was incorrect, I understand... You are probably guessing that I could not tell how many wheels were spinning from inside of the car. In this case, however, two friends were with me and trying to help me get out of the snow bank, and from outside of the car they observed that only the right front wheel was spinning. I'm back to wondering whether the center differential actually locked. I did not try to actuate the center diff until after I was stuck. Maybe it never clicked in. Are you certain that there are no circumstances (other than the significant mechanical issues you mention) where only one wheel would spin when the center diff is locked?
If you were able to select a locked diff, you should have seen a telltale on the dash indicating the diff was locked. From the Owner's Manual, pg 175:
Assuming your diff was locked, ESC operates in a "limited mode." I suppose it is possible in your case ESC reduced engine power (which it can do) to an extent that the power getting to all the wheels was insufficient to move the vehicle. But I'd hope that is not how ESC works at a near-standstill. If you encounter a similar situation in the future, the thing to try would be to affirmatively turn ESC off with the switch (this also disables ABS).
If only one wheel was spinning the centre diff was unlocked. If the centre diff was locked then one wheel on each axle would have been spinning. Unless something such as a halfshaft is broken there are no other possibilities.
I guess the key here is that with the center diff locked, if one driveshaft is turning, the other has to be turning too since they are locked together. If a front tire is spinning, then the front drive shaft - and therefore the rear driveshaft - has to be turning. So that puts it back to observer error or unlocked center diff.
This is a common misunderstanding. Power = Revolutions x Torque. If the driveshafts (propshafts) have same revolutions this doesn't guarantee equal power. Say you front axle is on ice and rear axle on dry surface with good friction. Front axle power = revolutions x almost zero torque = almost zero power. Then almost all power will be available at rear axle.
I dont have a strong answer for OP. i do have an observation though about winter conditions and the Grenadier.
I bought a place recently in Vermont’s northeast kingdom, and its been a historic winter in a place thats typically a snow belt. We’ve probably had somewhere in the 4-5 feet of snow so far. I have a 3/4 mile gravel/dirt driveway that gains ~400 feet in elevation. The steepest ascent tops out at about 16 degrees according to the car.
The brake traction control is generally a better bet than any lockers when going up with any appreciable snow on the ground. The center locker isnt terribly effective prob b/c it nerfs the traction control a bit (although I do have a bad habit of forgetting to re-enable the offroad mode). Lo gear is horribly ineffective, too much torque means i risk digging through the snow and layers of sand we drop to the frozen ground below and spinning uselessly. Needless to say the front and rear lockers are ineffective for the same reason, then its just all four wheels digging to the ice and then spinning. OEM tires this winter, maybe if i source some Nokians for next winter it’ll be different but for now i have much better luck in these conditions with open diffs.
The brake traction control is generally a better bet than any lockers when going up with any appreciable snow on the ground. The center locker isnt really effective and it nerfs the traction control a bit. Lo gear is horribly ineffective, too much torque means i dig through the snow and layers of sand we drop to the frozen ground below and spinning uselessly. Needless to say the front and rear lockers are ineffective for the same reason, then it’s just all four wheels digging to the ice and then spinning. OEM tires this winter, maybe if i source some Nokians for next winter it’ll be different but for now i have much better luck in these conditions with open diffs.
I guess east cost snow is different than west coast snow. I have had mine in a lot of snow these last two winters and the diff locks have done their job. I can’t fathom how open diffs do better in a low traction situation on a truck with basically zero computer aids. You are saying that turning half the contact patch equals more traction… that just doesn’t make sense
I can feel the brake traction control working in real time, saying it doesnt exist is fallacious. It may not be as advanced as LRs or Toyotas but it absolutely exists and is effective at least situationally.
At least with the oem ATs, if I dig down to the ice under the snow im stuck, so low range isnt particularly helpful. The snow is the grip and the brake traction control can react fast enough (certainly faster than I can) to transfer power to avoid digging in the specific situations i’m talking about where there is 6+ inches of fresh powder on top of a thin layer of crunchy compact snow + sand on top of a thick layer of ice while ascending a steep curving slope
I will say also that I spent over a month this winter with a snapped transfer case bowden cable, so I of necessity had a lot of time to experiment with how the truck behaves in these specific conditions using only what is available in high range.
As we say out here on the west coast… dude you are high. I mean truly stoned out our your mind. Or maybe it’s mushrooms because you are seeing and feeling things that simply don’t exist.
There isn’t shit for “brake traction control” or any sort of computer traction intervention. It is 100% mechanical systems (center, rear and front lockers) that make a Grenadier work in low traction situations. It’s very old school in that regard which is fine by me. This is the reason why you don’t buy a Grenadier without triple lockers if you intend to use it off road or in the snow.
Don’t believe me, take a look at AO’s roller test.
View: https://youtu.be/URuanFs17oY?si=Yw8-XdQl81tkpKpy
I disagree with this. Trying to go uphill by braking already slipping wheels isn't better than locked axles and centef diff with all four wheels on same rotational speed.
Yes, with an automatic gearbox. In snow you need to press throttle to to get the car moving and then the spinning starts.With a manual gearbox you don't generate massive torque but can get the car moving smoothly wuth clever use of the clutch without spinning wheels.
This snow bank is roughly 1 meter deep (over 3') and uphill. No massive tyres (215/85R16), but tyre chains, manual gearbox with low range, center diff lock and rear locker engaged, and up we go:
Friend's Defender with autobox conversion didn't make it despite larger tyres (255/85R16) and less weight:
This is how deep the snow was:
With all respect to AO, I don't think their roller test adequately displayed the ESC's ability to intervene. Here's a video clearly showing the Grenadier braking a wheel with CDL, Offroad Mode engaged and both axles unlocked, this time on dirt instead of rollers: Grenadier vs Mud. The difference between this video and AO's video is that the wheel slip lasted long enough for the ESC to intervene and brake the slipping wheel.
Ineos provided us with a table of ESC functionality and I published it here: Ask INEOS - Does the Grenadier Have ETC
In snow you need to press throttle to to get the car moving and then the spinning starts. With a manual gearbox you don't generate massive torque but can get the car moving smoothly wuth clever use of the clutch without spinning wheels.
I much prefer a manual in snow because I find it a lot easier to regulate power and obtain feedback about traction. But . . . vehicles with automatic transmissions can be very capable in snow and low traction. For starting from a stop in extremely slippery conditions, the technique I'd often use is to select a higher gear to start. This reduces the amount of torque transmitted to the wheels and reduces initial slipping. Instead of slipping a manual clutch, I'm slipping the torque converter or clutch bands. Do this enough - like when you're stuck and trying to rock out of a hole - and you can absolutely burn up a clutch band that is nearing end-of-life (done that). So just like slipping a manual clutch, it needs to be done sparingly.
I used this technique everyday for several years driving to work in a '68 Plymouth Fury III in the early morning winters in Alaska. The Plymouth was a big 18' long 4-door sedan with almost no weight on the rear axle and a 318 with 230 HP up front. Going to work, I'd pull into a left turn lane that was aimed uphill with about a 3% grade. In Anchorage, the roads would get covered with ice and snow in October and stay that way until May. Left turns lanes were almost always polished ice due to lots of sliding stops, wild spinning starts (dumb drivers) and the heat of idling vehicles melting the ice and snow (which would immediately re-freeze). The technique to get moving without spinning was to manually select 2nd gear on the automatic transmission (or sometimes even 3rd gear in extremely slippery conditions ), let off the brake and let idle or a tiny amount of throttle get the car moving. There was almost always enough traction to move slowly - like at a slow walk. Try this in Drive (which would select 1st gear to start from a stop) and the tires would immediately break free and spin in place. Less informed drivers could hold everyone up as they madly spun their wheels, going no where through two or three light cycles before finally getting through the intersection by dumb luck.
There are no such circumstance, not unless something is broken.
The CDL is a very simple mechanical system on the Grenadier.
I guarantee you didn't actually have the center diff locked if only one wheel was spinning.
Love that response - a breath of fresh air after hearing endless blabber about 50/50 power split.
There are only two quasi-axioms about open and locked differentials:
(1) An open differential splits input torque equally between two outputs.
(2) A locked differential (spool) forces both outputs to spin at the same rate.
How does that relate to power delivery?
The ONLY case (1) and (2) correspond to equal (50/50) power split between the outputs is a drive in a straight line on dry pavement without any tire slippage, with tires having exactly the same rolling radius.
In practice, 50/50 power split is very rare.
This is a ridiculously common misunderstanding (mistake or error), promulgated and propagated by the "Honchos" of four-wheeling world like Tom Sheppard.
Say, Tom Sheppard really understands (1) and (2), but in his book "4x4 Driving" he slips into the same fallacy. I tossed the book after seeing "50/50 power split" for the fifth time.
To answer the OP question - ALL AI-generated stuff is garbage. Your center diff was not locked, or you have not had an attentive observer.
It's all pedantic. Nobody really cares.
A locked center diff sends equal (insert whatever fancy concept makes you happy) to the front and rear driveshafts.
Having rebuilt a bunch of center diffs of the same style, you are physically coupling shafts inside the transfer case.
