New Year Service Overdue Bug
TALLY (updated and complied by the unpaid expendable gofer*)
Krabby 1492 days
ResponsiblyReckless 1625 days
Chook 1840 days
anti 1841 days
Itsdchz 1841 days, first US car with the pox
Dlucky 1851 days
BrandonADV 1852 days
TahoeGren 1852 days
Rocky 1856 days
Bjoern 1864 days
Znarfgh 1864 days
PB60 1865 days
Pat-Ard 1868 days
Rok Dr 1869 days
Tx246 1872 days
WanderingSniper 1872 days
Malkay 1875 days
Sonoranrover 1875 days
linksk9rig 1877 day
BluDawg 1879 days
Shopkeep 1879 days
rabia 1879 days
XxShantilisxX 1880 days
mji111 1880 days
PNW IG 1881 days
csjeeper 1884 days
donnygreygrenadier 1885
Michael H 1889 days
Guy 1890 days
Robt 1890 days
Chem409 1890 days
Blackwolf 1891 days
Duncan McDonald 1892 days
Deon 1893 days
joejet 1894 days
grnamin 1897 days
TimeosYoc 1899 days
Korg 1899 days
LPT FSJ 1900 days
GrenADV 1901 days
Green Gren 1903 days
stefan.schaefer.de 1906 days
Grumpy 1906 days
crashnburn 1908 days
HeavyFoot 1915 days
pedrogb 1915 days
Tom Ireland 1916 days
FlyersFan76 1917 days
Jax F1 Dave 1917 days
Old Salt 1919 days
Woody 1919 days
UncleBuck 1924 days
Force Pro 1924 days
Voader O 1925 days
OGrid 1927 days
singlefin 1927 days
Green 1928 days
DrahthaarGuide 1929 days
WhiteBear 1931 days, first car outside ANZ
ecohen2 1932 days
oilpresuure 1933 days
Forefun 1933 days
Happyoldgit 1933 days
Leonidas 1935 days
DaveB 1935 days
OkGo 1937 days
prezioson 1940 days
NixGrenadier 1940 days
Rupert 1941 days
Gerrymac 1944 days
Peterr's neighour 1944 days
ddv 1945 days (Aug 2023)
Tergosa 1946 days
Rudilf 1948 days
Johnb 1950 days
Fred 1950 days
pmatusov 1953 days
Antgil 1953 days
TheBMcCann 1953 days
Camilondo 1953 days
nr002 1954 days
Knoe 1955 days
rickydoc 1961 days
Peterr 1961 days
IG Pop 1967 days
Jeremy966 1967 days
Ex-defender driver 1968 days
TheDocAUS 1968 days (Feb 2024)
shekesc 1969 days
SilverNZ 1971 days
Joe B 1971 days
Denis M 1975 days
Augustin 1979 days
Telliottaus 1980 days
rwhitinger's better half 1981 days
Zimm 1982 days
OZZA 1987 days
joejet 1989 days
Mohs9 1989 days
MattG 1989 days
Jonnieblaze 1950 days
TJD 1985 days
Phred 1994 days
douggie 1995 days
Isle of Wight Paul 1996 days
Phud 1996 days
Bluesmurf 2003 days
Des Mattes 2003 days
Glen 2007 days
Badger4x4 2007 days
Adam 2007 days
snowball 2009 days
Baron van T 2009 days
Tomdoc 2016 days
gratefuldiver 2021 days
nzmark 2022 days
Silverjay 2022 days
Sully 2023 days
BEM-S4 2024 days
theox 2024 days
Chris Hilton 2024 days
Tony H 2025 days
nuclearbeef 2026 days
SaudiGR 2026 days
FlyersFan76 2032
Sylvan 2032 days
Landmannn 2044 days
Oscar786 2045 days
acky 2048 days
n545ca 2050 days
Logsplitter 2051 days
Commodore 2057 days
NeoGTi 2057 days
The Angler 2058 days
HelgeL 2059 days
Greasemonkey 2059 days
KristinaM 2062 days
SD Jeff 2063 days
Keato 2069 days
Lollo050968 2074 days
bemax 2078 days
255/85 2080 days
HessenHUnter 2081 days
Citori21 2081 days
bakepl 2082 days
MurphyMurph 2085 days
McPharmerII 2088 days
Barney 2091 days
LeeroyJ 2093
Wile E Coyote 2095 days
DrewB 2096 days
Dschubba 2097 days
Stu Barnes 2097 days
Manuel4x4 2106 days
Mazeman 2107 days
Jork 2113 days
Zenadier 2114 days
KlasN 2123 days
Wueste 2123 days
Brock63 2124 days
Tazzieman 2137 days
skinny tom 2139 days
Tenac loaner 2139 days
Phobiac 2141 days
ChrisRay 2141
archerwolf 2146 days
pipo 2149 days
Skymark 2156 days
ADVAW8S 2159 days
Ever Pragmatic 2141 days
Grenni-Tom 2153 days
VTTrialmaster 2161 days
Bayford 2162 days
StKesseler 2171
slukell 2175 days
Island Falconer 2178 days
wolftimj 2183 days
Emil 2190 days
emax 2233 days
bigleonski 2250 days
Ron50 2253 days
Torc Steel 2277 days
Bobineos 2188 days
Mulekick406 2297 days
Clark Kent 2367 days
tnkatoy 2362 days
C-Mack 2458 days
Jorda 2503 days
DeepCJ7 2651 days
mirwantandyo 2668 days
rwhitinger 6410 days
SUMMARY
191 members and an additional 3 members with no alert (4 if you include some chap in Townsville). Tally stops at 200, only 9 spaces left.
No change to first or last place. A photo is needed if you are claiming a new low or new high.
DO NOTHING FOR THE MOMENT
facebook-jpeg-png.7918675
* Wednesday's unpaid expendable gofer.
View: https://youtu.be/F9CdkjLrEt8
My understanding of the altimeter is it is pressure based system and not a GPS location. That is why as you get into the mountains the more accurate it is. I say this currently at -3ft on top of a hill.
A pressure-based altimter in the Grenny seems unlikely. Pressure altimeters need constant updates with the local station pressure to show accurate data. A change of 1" of mercury is equal to 1,000 feet of elevation, so it would only take a few tenths for the altimeter to be off quite a bit. If you were going to install a pressure altimeter with no way to adjust the station pressure (like in the Kollsman window of an aviation altimeter), it would most likely be set to the standard value of 29.92".
My station pressure (right here, where I sit, right now) is 30.40". If the Grenadier altimeter was set to a standard of 29.92", the altimeter should show the actual elevation of 8,175 - ((30.40 - 29.92)*1000 = 7,695'. But the altimeter actually shows 8120' . . . the exact same elevation another GPS-derived altimeter shows. I know my exact elevation because I commisioned a 1' increment topographical survey prior to siting my garage and house. GPS elevation is usually derived from lookup tables and may not be as precise as some other methods (like a topo map).
In my two other vehicles not equipped with a GPS altimeter, I carry a pressure altimeter with me while I'm travelling in the mountains. I routinely adjust it to the current station elevation when I have that data to maintain a modicum of accuracy.
I found this -
Reset/reboot the headunit (aka Console screen).
Hold the Mute button (located at the centre bottom on the vertical panel) in until half the Console screen goes blank (do not release the button). Continue to hold the Mute button in until the whole screen goes blank. Only then release the Mute button. That will reset/reboot the headunit.
by TheDocAUS from https://www.theineosforum.com/threads/grenny-infotainment-craps-the-bed.12416190/
Thank YOU!
OK, the reboot did not work. Tried it 5 times. Thanks guys. I appreciate it. I will schedule an appointment with the local dealer to see what we have.
@CWatson
You can try
Settings > General > Reset General Settings, and/or
Settings > General > Reset All
Not exactly sure of the extent or distinction between these two. You might have to scroll down to the bottom of the General screen. My car lost its Bluetooth id and this fixed it.
which errors do you actually have?
think i can win this one - 88 years?
Although this problem, which took a year to resolve, happened after my first service, and is probably unrelated to everyone’s current one. But i was so excited to have it return, im on a smaller number now. Wish I knew you could clear the faults with the trip button twice earlier, would have really helped!
1927 for me
A good friend yesterday rang me to tell me their Tesla had a special NY light and sounds function just delivered to their vehicle.
I rang them this morning to say that Ineos also has delivered a NY light and sound function, but it goes Bong and you can’t turn it off.
2064. Might have been funnier at 2067
Thank you to the moron software developer at whatever software company that Ineos uses for my new annoying feature after a new year has rolled over /s
service overdue 1899 days
I get it serviced every 5,000km.
I got the same. Just bought the Truck in November! Almost lost my mind!
Let us know all the lights that are presenting themselves and maybe we can help 🤷🏼‍♂️
I’ve had quite the selection along with many others and advice given here certainly assisted me to give a “directed” approach to the dealer! 😉
Meant for @ChrisRay
Thanks...the most annoying is the airbag light...I can't even read the code. I've tried 4 different readers, including the autophix one I specialed ordered from Australia. I would at least like to be told which one so I can check the wiring harness and connectors. I've found most of our grennys have loose fuses and connections that resolve d the engine lights we were having
I think I recall a bad ground wire issue where there was paint between the cable connector and the chasis where the paint needed to be removed.From memory this was in the back footwell area. That maybe worth a look along with doing a full battery disconnect following the documented procedure in the Rock_Dr manual.
NOT THE NEW LEADER
Sorry I will not be accepting that number for the Tally. It is a different format to other cars from Australia. The other AU cars are consistent with each other, that one is not.
So it is a different bug or a fake or something really strange is going on in your car. Based on your post 1 or 3.
not a fake, just as I said in my post likely a different cause. I also have the current issue, with a typical number.
But I did have this issue which was caused during a service (likely due to update? My guess…), came with many other alerts, took many visits to isolate, and was ultimately found to be a hardware fault.
I really only posted to see if anyone else chimed in with the same, and because nearly 90 years did cause a bit of laughter with passengers; even series 1 LR were still not even a sparkle on a welsh beach😜
