Winning?2098 here.
Winning?2098 here.
how a bout a chicken karma with pilau rice?A bit rough mate. I don't believe in " karma" any more than a dog does.
Keep ya hair on, as my dad said![]()
As long as there’s lots of naan I’m in.how a bout a chicken karma with pilau rice?
Leave her out of thisAs long as there’s lots of naan I’m in.
Do you like an older woman?As long as there’s lots of naan I’m in.
The word comes from the Persian word for bread = NANHahaha.
Note: n - a - a - n (not nana).
Not at all…
There are ZERO reasons to not allow us to reset other than a money grab. So now, it will cost THEM money.
That is KARMA.
Bit Value Power of 2 Decimal Contribution
0 1 1 1
1 1 2 2
2 1 4 4
3 0 8 0
4 1 16 16
5 0 32 0
6 1 64 64
7 1 128 128
8 1 256 256
9 1 512 512
10 1 1024 1024
SUM 2007
Mine had also set the date to 1/1/2032, resulting in an overdue service reminder of 1989 days or so. Changing the date to 1/1/26 did not get rid of the service reminder however. Annoying.Check and reset your date, it may have been automatically set to 2032. You can disable Automatic date, set the correct date, then enable Automatic date back (also don’t forget to enable DST setting, if applicable)
That’s gone straight over my head after 1/2 bottle of red.So this gets a little deep into math, so hang in there.
1) Suppose my 2025 Grenny was built on February 11, 2025. This seems reasonable since it's a 2025 model.
2) A service interval due date might be calculated as February 11, 2025 + 365 days = February 11, 2026.
3) On January 1, 2026, I am 41 days from needing a 365-day service due message.
4) Another way to calculate a service interval, shown here in pseudocode:
daysSinceServiceDue = todaysDate - (lastReset + 365)
if daysSinceServiceDue > 0 then show the number of days
For my vehicle, this calculation would be
-41 = January 1, 2026 - (February 11, 2025 + 365)
So it's 41 days before I need service.
Here's the hard stuff:
5) Binary numbers can be stores as signed or unsigned. An unsigned binary can only store POSITIVE numbers. A signed binary can store POSITIVE or NEGATIVE numbers. There's nothing special about a bunch of 0's and 1's strung together to represent a binary . . . you need to know if you're dealing with a signed or unsigned binary.
6) The decimal number -41 as a signed binary is 11111010111. But if you make a mistake and treat 11111010111 as an unsigned binary, the decimal equivalent is 2007.
7) Here's the conversions for the signed binary equivalent of
-41 = 11 11101 0111:
SIGNED BINARY
The input has 11 digits. Proceeding from right to left:
0 1 2^0 = 1 1
1 1 2^1 = 2 2
2 1 2^2 = 4 4
3 0 2^3 = 8 0
4 1 2^4 = 16 16
5 0 2^5 = 32 0
6 1 2^6 = 64 64
7 1 2^7 = 128 128
8 1 2^8 = 256 256
9 1 2^9 = 512 512
10 1 2^10 = 1024 1024
The sum of these numbers is 2007 and that is the decimal value of the UNSIGNED binary. To yield the SIGNED binary, we subtract 2^11 (= 2048) from the result (where 11 is the number of digits in the binary number). So 2007 - 2048 = -41.
So in my case, it might be the INEOS programming treated the binary number of days before service due as an unsigned binary when it should have treated the binary number of days before service due as a SIGNED binary.
Cheers!
And, very importantly, why are the Aussie reminders in the format xxxxDay, whereas others are expressed as xxxxd ??@Glen are you sure about you're calcs?
Have you accounted for those of us that drive RHD and are on the bottom half of the globe?
A fine observation and one that requires detailed analysis, and a refund.And, very importantly, why are the Aussie reminders in the format xxxxDay, whereas others are expressed as xxxxd ??
Your certificate of conformity has your build date on itHow do you folks see what your build date is?
