New grenadier winch options
Awaiting LFD winch tray also
I received the lfd tray a week ago and installed it over the weekend. Several QC issues with the tray. Might be a one-off but I contacted lfd directly to make them aware.
1. On the passenger side the pre-threaded holes in the cradle for the cover are M8 whereas the ones on the driver side are M10s (what they should be since the OEM bolts are M10.
2. The holes in the winch cradle that attached to the frame are so large that the OEM flange nuts do not fully cover the openings therefore the cradle is not securely mounted to the frame. I had to find some large washers to ensure a proper fit.
Yea, there were a couple of issues with mine as well, interesting to see I'm not the only one. I wrapped up yesterday and ran into a couple misaligned threaded holes that needed to be cleaned up. Also, there were a couple of fitment issues, including the lower tabs on the plate cover that go underneath the bumper (only allowed one bolt without dremeling) and the cover bolt holes as you mentioned. All in all, not terrible, but seems like QC might be a little lacking. Why wouldn't you confirm all the threads are good before shipping?
Edit: Wanted to add that the winch plate is really solid. Its beefy and I have no doubts it will manage whatever the winch throws at it.
LFD in the garage and Zeon 12-s enroute from out west. Probably won’t get to until Christmas break TBH.
Installing the Zeon 12s on Monday. Hopefully no issues 🤞. I located the positive terminal connection behind the RH light. Not sure what to connect the negative to yet.
Please document your process and share if you can. It will be greatly appreciated around here!
I went to the bolt south of the positive terminal in the engine bay. Some of the Aussies ID'd it as a good ground in another thread and I always trust people that come from a land down under.
Installed the winch today. It took me a minute to figure out how to disconnect the batteries, but need to disconnect the negative terminal on the battery connector if you have a dual system, then disconnect the negative terminals on the main and aux batteries. I connected the positive from the winch on the open terminal behind the right headlight and the negative to a threaded hole in the same area, after grinding away the paint and using a bare bolt. I had a bad connection using the bolt to the front of the positive jumpstart terminal in the engine bay. Hopefully the pictures attached make it somewhat clear.
I needed access to the barrel after installation to rotate it when I was pretensioning the line, had to remove that center screen. I think I'm going to leave it off. Also, and this is just me, I mounted the side screens on the interior like it shows in the install photos, I think it looks a little better.
Edit to add pic
Yeah not sure if I keep the screens on the outside or not. One of the hardest parts was installing the winch rope. It was almost impossible to pull the loop through the barrel opening and had to use some thicker wire since the one that was supplied was not strong enough. I still need to pretension the rope at a later time and get to winch in right spot (probably move it back a half an inch or so) so I can fit the winch cover over it.
Kinda starting to wish i’d held off on the LFD tray after reading this last page.
The tray is solid, just make sure you get large washers to ensure a proper mount onto the chassis. LFD send me a bunch of large washers after I made them aware of the issue. But the winch sits fine with good visibility to the rope.
I’m all over the place on a winch, and I’ve exhausted my ‘toy’ money for the moment. The LFD tray seems to be sticking out more than I thought, but I think that may be a wide-angle lens phenomenon. I’ll just off road with ColoradoMike until I figure out a which winch…
It sticks out more because it is not a hidden tray. The reason I got this tray is so I can see the rope and winch which is better option IMO than a hidden winch where you really do not see how the rope is rolling on the drum and I have the full 100 ft of rope. Plus I can remove the winch without having to disassemble the bumper. A hidden winch bumper certainly looks cleaner but access to the winch is harder and normally the rope is shorter (not a deal breaker).
Also from looking around the width between the frame rails restricts the type of winch and specifically the length of the winch motor when a hidden mount is used...
For example the Superwinch Tigershark 9500 (an entry level winch) will fit with the solenoids mounted remotely but the 11500 probably not.
Here's a better shot. It doesn't stick out all that far.
To me its aesthetically fine. Not as slick as a hidden, but man I was sure glad to have that barrel access when I was pre-tensioning since I stupidly pulled out too much line while daydreaming 😆
Yeah I agree it doesn't look bad. I came from a Bronco Everglades which has the winch slapped on the front bumper from the factory and was sticking out as well. I just think it's nice to have access to the winch
I think I need to see it in person. I think when the pics are from close up and wide angle it exacerbates how much it sticks out.
I’m also looking at adding some light, mainly for fog. I was thinking about the two side holes on the mount. Or maybe on the side to keep the lights from being the very front…
Latest posts
