Anand great writeups, just catching up here. Lots of good stuff!
Cheers!
Steve
Cheers!
Steve
Quality product, what would the cost have been if purchased and what Springs did you match them with? Not in the marker at the moment - but you never know. Ignore my question on Springs - just reread your post.Had a long overdue visit to see my good friend's at Apex Overland today...
First up was a fresh set of Falken Wildpeak A/T4W's; still 255/80/17s. I found a cut in the sidewall of one of my rear tires, and since they have 22k miles on them I didn't want to permanently mix one fresh tire and one (almost) half life tire. Secondly, since the A/T3Ws are no longer produced, I also didn't want a mis-match between fronts and rears. The only logical () solution was to replace 1 bad and 3 perfectly good tires with new ones.
Next were a set of heavier OEM springs to regain some of the height that was lost from adding weight (winch mount, winch, sliders, storage system, roof rack, weight on the roof, etc), especially since more weight is coming in soon (LRA rear tank and perhaps some Agile skids). My truck came with green circle/green triangle springs (chart available here), and I went with purple circles up front (3 steps heavier) and blue triangles in the back (2 steps heavier). I wanted the black triangle rear springs, but at the time of ordering them last month, they weren't available. If I were doing it over again, at my current weight I would have gone with blue circles up front (2 steps heavier than my stock) as the front is just a bit higher than I'd like (we'll see if it settles, they only have about 35 miles and 6 hours on them now). Cost on the OEM springs is not insignificant. For the four springs it was ~$1450, but all of them were (very surprisingly) in stock in the US!
With the install of the springs I also installed a set of Koni's Raid adjustable shocks. These things are massive and beefy. It has been 15+ years since I ran Konis, but I had more than a few sets on my autocross and track prepped cars back in the day. I didn't know Koni had shocks available for the Grenadier until a few months ago when I got a phone call saying a set had arrived with my name on them. Full disclosure because I feel like transparency in this industry is lacking, I did not pay for these shocks. They were provided to the shop that installed them as a promotion, when I got a phone call asking if I wanted a set of shocks, I said absolutely. With that being said, everything else from this visit was regularly priced, including the install.
Initial thoughts after 35ish miles of driving. Wow. I was afraid I had oversprung the front and thus expected some jarring over expansion joints (more so than the typical, as this is one of the Grenadier's weak points IMO); but a mix of highway, residential, and city/suburban surface streets has proven that to be a non-issue. We set the shocks to the middle of their range of adjustment (they can only be adjusted off the vehicle, and while this doesn't take that long, I figured the middle was a safe place to start) and they are both supple and composed. Quick harsh hits like expansion joints, potholes, and manhole covers are much more smoothly absorbed without transferring the jolt into the cabin. Sweeping highway off ramps at speed are also not overly soft or squishy, nor are they filled with body roll.
If you're just doing shocks the install is quite fast (even with the springs it was only around half a day, but they've done lots of Grenadier suspensions at this point) and no alignment is necessary.
I wish I had taken more pics of the suspension while installing, but this is the only one I took:
I'm positive the Apex Overland socials will have the comparison pictures of the stock Sachs dampers and the Koni Raid dampers, I'll steal those as soon as they are posted and add them here. For instance, the Koni's use slightly offset mounts on the bottom of the rear shocks because otherwise the diameter of the shock would prevent it from fitting
The Koni dampers sell for $345/ea; for springs I did the OEM springs, just heavier than what my vehicle came with initially. Front part number was GRA-4C00-004580 and rear was GRA-4D00-031270; the set of 4 springs was $1543.26 from my local dealerQuality product, what would the cost have been if purchased and what Springs did you match them with? Not in the marker at the moment - but you never know.
How much past the sides of the vehicle roof does the Kammok extend? Did you mount the alternate brackets that seat it lower yet? I'm wondering if simple L-shaped brackets reversed so they "point" down would do the trick of lowering it to being closer to the same plane as the top of the roof rack.Something that has been on my list since I got the truck.... a giant wind brake! Errr... I mean an awning!
I've been eyeing up the Kammok awnings for months now, and seeing one up close at Overland Expo sealed the deal on ordering one... Originally was going to order from my usual source, but Kammok had an open box on their website for a ridiculous deal, so I clicked "check out". The only thing I've found is a knick in the top of the housing, luckily that's over 7ft in the air.
I'm not overly thrilled with how high it is, but it works for now unless I decide to get creative with extrusion to build my own brackets for it.
The awning is their 5' wide model, which actually has an outer measurement of around 63", or about 4" wider than my roof rack; and it pulls outward nearly 7' without the use of any uprights or poles
In the "furthest in" setting, which is just over 3', it covers the door openings almost perfectly
I haven't driven the vehicle yet, so no idea on how this may have altered wind noise, I'm sure it'll add a good bit, but now I can cook, grab a beer, or just hang out behind the truck without getting blasted by sun or weather
The roof rack is around 56" wide, the awning is around 60" wide, so it is about 2" on either side of the rack; from memory (it's in the hotel parking garage at the moment) it is narrower than the rain gutter.How much past the sides of the vehicle roof does the Kammok extend? Did you mount the alternate brackets that seat it lower yet? I'm wondering if simple L-shaped brackets reversed so they "point" down would do the trick of lowering it to being closer to the same plane as the top of the roof rack.
Anand - would you mind sharing aFe part number? Not seeing 320/220i late model option on their website. Or did you mean 330/230i part number 32-10299?Couple updates of finally getting things installed before leaving for Moab in the morning...
I installed the Blue Ridge Overland Gear attic (I'll update this with a pic later today)... It's effectively a "net" that can be tensioned and sits against the headliner above the back seat. Super fast install as it just bolts into the locations for the factory dividers. I'm using it for the same purpose as in previous builds, to hold light items like jackets/pillows/blankets/etc, and while it does eat into the rear seat headroom slightly (especially since I have the seats in the utility position), having back seat passengers is a rarity, so it's worth it.
Also finally got around to installing an aFe cleanable dry air filter; the part for the current era 320i/220i fits perfectly... After the past 12k miles the OEM filter wasn't super dirty, but also not what I would consider to be clean.
A keen eye will also notice the giant muffler missing off of the back of the airbox. I used the Berger Motorsports airbox cap for this; super easy 5 minute install, but, sadly, no audible difference. I was really hoping it would perk up the turbo whistle/intake sounds a bit. I also have the Berger MS silicone intake pipe sitting in a box (from the MAF to the turbo inlet), but not sure when that will make it on the vehicle, definitely not in the next 2 weeks.
Looking forward to putting faces to names at the Grenadier Gathering in Moab next week
Ooooof that's my mistake, 330/230i... the B48 motorAnand - would you mind sharing aFe part number? Not seeing 320/220i late model option on their website. Or did you mean 330/230i?
Very nice. I was hesitant, but now I know I want it! Thanks for sharing the info, there wasn't much out there.Update time!
FINALLY the Long Range America fuel tank arrived! I had the folks over at Apex Overland install it yesterday, and for the first time ever, made the drive home without having to stop for fuel along the way
The simplified install is as follows: Drop the rear bash plate, cut the factory exhaust, remove the exhaust from the mid-resonator back and toss it in the metal pile, remove the OEM fuel filler neck, mount the transfer pump, and then just pop that auxiliary fuel tank into place and reinstall the bash plate. Oh, and run a harness into the vehicle to install the gauge/pump switch in the dash. Super simple, right?
The install took about 7 hours, including a brief wait for an upgraded Edelbrock fuel transfer pump. The pump included with the kit has been known to fail in a handful of vehicles, including on Apex's own 5th gen 4Runner, so we proactively replaced it with the slightly higher flowing Edelbrock unit.
As mentioned, you remove the OEM rear muffler and replace it with a small resonator and a single exit tip (on the LHD driver's side). There is definitely a bit more rumble from the exhaust, but certainly not loud. I would say the rumble is primarily on the outside of the truck. As the first vehicle I've had in >15 years with a modified exhaust, I can't believe I went through so many vehicles without itThere wasn't a single overpass on the 6ish hour drive home that didn't illicit a "window down, downshift"maneuver. The LRA tip sits substantially higher/more tucked in than the OEM tips also; something I appreciate as the last outing partially crushed the OEM passenger's side tip
Back to the fuel! While the muffler weighs a good bit (more than the tank), it still has 145lbs of fuel inside of it, which definitely adds weight to the rear end. My first fill up of the aux tank got 24.4 gallons before the pump clicked, so notably more than 1 full OEM tank is available for transfer. I ordered the Metalcloak 1" rear spring spacers, however, the spring compressors they had on hand were unable to sufficiently compress the uprated OEM rear springs enough to fit them; so they'll be in the classifieds section soon. Since I probably won't have fuel in the aux tank all the time, I may just handle this with airbags, or do nothing at all.
While transferring fuel from the auxiliary tank to the main tank, the rate is something along the order of 40 miles of indicated range per 4-5 minutes of transfer (while driving at highway speeds); so ~0.8-1 US gallons per minute by some horribly inaccurate math. The OEM fuel gauge/range is not quick to update as fuel is being transferred. After those 4-5 minutes of fuel transfer the new amount probably didn't register fully for another 3-4 minutes. I'm sure this would be quicker when stopped, just like while fueling up from a gas station, but at 70+MPH the algorithm slows down refresh rate due to sloshing/movement substantially. The LRA gauge/pump switch comes with the appropriate length wires/etc to tap off of the fusebox in the dash kick panel, and, despite the instructions saying to install it almost in the middle of this knee panel, I had them align it to the left side which is a bit easier to see and interact with. The fuel level LEDs are on anytime the ignition is on, and depressing the button turns on an orange light to let you know the transfer pump is on.
Filling the tanks is very similar to original, except when you take off the (new) fuel cap, you have the ability to select which tank you want to fill. The rearward hole is for the aux tank, the forward hole is for the OEM tank. I do wish the new fuel cap had a retention lanyard and/or fit into the OEM holder spot, but alas, it does rest inside the lip of the opening while fueling.
All in all, super happy with the upgrade as I've always felt the fuel quantity was a bit meh on the Grenadier... not specifically for off road trips, as for most off pavement routes in the US fuel is not an issue, but more so for road trips. I've been spoiled by having larger aftermarket tanks on the last few vehicles we've had, and now the Grenadier carries almost as much as the rest.
And for those wondering, I know there's no baseline, but here's a quick start up sound clip, this is after the cold start was completed, so regular idle
Soon-ish I hopeCan’t wait to get mine installed
