Interior Water Leak
You mean in the front of the windshield?
I've heard reports of the windshield seal needing to be redone on a few vehicles, they leak at the top of the windshield. I think you can search the forum for a quick temporary fix while waiting for your dealer to sort it out.
Do you have safari windows also?
Yes , I have safari windows but it doesn’t look like that’s where it’s leaking . Top of the windshield or coming through the antenna
When it drips out of that area it is usually from the safaris, the other (much less common) location would be the top of the windshield, but almost always it is from the safari windows and just runs along the headliner
Thanks , waiting to have it checked out
Did you ever get this sorted out at the dealer? I seem to have the same issue occasionally. Only happens after I drive the vehicle after it rains - almost as if water is pooling somewhere and when I put it in gear, it all leaks into the box behind the rearview. Doesn’t happen at all when actually driving in the rain.
If you open the safari glass you will see a drain hole at the front. Driving normally or parked downhill the water drains away.
Parked uphill the water will pool at the high end of the aperture.
It then only takes some dirt on seals or they are not sealing properly to get a leak inside.
2025 recent owner and just had this happen. For me looks like two areas, could be the safari window seal in the driver side and/or the windshield. As just this morning I found water inside on the hood/bonnet release lever and the foot rest. Will take it in to diagnose and repair.
I’ve noticed the same problem twice after it rains. Been parked facing uphill on the driveway & when I get to the end of the street at the stop sign, it drips in. Its about to dump rain on us for the next day or two, so I’m gonna turn my truck around to face downhill then get the safari windows checked after Christmas
It’s the safari, I have a loaner and the water comes in around the rear view and ADAS camera. It’s not the antenna or the windscreen. It’s the safari windows, it’s always the safari windows
Just had mine with the same leak behind the rear view mirror. I do NOT have safari windows. Anyone hear of a fix or more importantly a cause?
Windscreen seal or central panel roof seal? 🤔
External roof antenna? I'm reasonably sure I read that some have experienced water ingress from here.
It was a fairly common issue with earlier builds (lots of posts on this site) but not common on newer builds. The MY25 had a change to the windscreen trim/seal. How old is yours?
Either way, the dealer will almost certainly have come across it before and know what needs to be done to resolve it.
Yeah looking from the outside the external antenna was my guess. It got super frosty up here so I'm wondering if ice found its way in there. Just disheartening to see leaks on a new vehicle!
It's a 2024.
I am finally taking mine in tomorrow to get it fixed. Dealer said that this leak is mostly common on vehicles with safari windows. I'll ask tomorrow about other causes.
