I have some water coming in through the back of the rearview mirror . Anyone have this issue ?
When it drips out of that area it is usually from the safaris, the other (much less common) location would be the top of the windshield, but almost always it is from the safari windows and just runs along the headlinerYes , I have safari windows but it doesn’t look like that’s where it’s leaking . Top of the windshield or coming through the antenna
Did you ever get this sorted out at the dealer? I seem to have the same issue occasionally. Only happens after I drive the vehicle after it rains - almost as if water is pooling somewhere and when I put it in gear, it all leaks into the box behind the rearview. Doesn’t happen at all when actually driving in the rain.Thanks , waiting to have it checked out
If you open the safari glass you will see a drain hole at the front. Driving normally or parked downhill the water drains away.Did you ever get this sorted out at the dealer? I seem to have the same issue occasionally. Only happens after I drive the vehicle after it rains - almost as if water is pooling somewhere and when I put it in gear, it all leaks into the box behind the rearview. Doesn’t happen at all when actually driving in the rain.
It’s the safari, I have a loaner and the water comes in around the rear view and ADAS camera. It’s not the antenna or the windscreen. It’s the safari windows, it’s always the safari windowsYes , I have safari windows but it doesn’t look like that’s where it’s leaking . Top of the windshield or coming through the antenna
Windscreen seal or central panel roof seal?Just had mine with the same leak behind the rear view mirror. I do NOT have safari windows. Anyone hear of a fix or more importantly a cause?
It was a fairly common issue with earlier builds (lots of posts on this site) but not common on newer builds. The MY25 had a change to the windscreen trim/seal. How old is yours?Just had mine with the same leak behind the rear view mirror. I do NOT have safari windows. Anyone hear of a fix or more importantly a cause?
I thought it was a standard feature on a safari roof......... Dealer said that this leak is mostly common on vehicles with safari windows.....
Perhaps...I thought it was a standard feature on a safari roof![]()
