Ideas for added 12v plug in dash area
4:56 PM
Jacksonville, NC
Have a new to me '24 Trialmaster.
Looking to add some needed 12v ports in the dash area.
Has anyone done and can you share pics for ideas?
Looking at either trans tunnel or lower sides of center console-close to int- prewires.
Also, can the side panels of the console come off-
Pls post pics for ideas.
There is thread on this recently. I am trying to find the link.
EDIT
STEDI option
M4x4-ineosgrenadierquartermasterswitchmountdashboardshorttoyswitchuhfmountpassthrough-3_1800x1800.jpg
Lightforce panel (RHD car)
full
Euro Flo option
Threads:
I found a much neater solution that did require a bit more work. Worst part was trying to establish if there was sufficient free & clear space behind without ruining anything….. there is.
I did take install pics but can’t find them at the moment so will update later.
There is also also space on passenger side grab handle. Out of the way and not very obvious.
This location I was eyeing, can you provide guidance on panel removal to get to this space. I don't have access to the drawings at this time.
The console side panels do come off — they're held on with push clips. Tip: use a trim removal tool and start from the bottom edge, they pop off without too much drama. Just make sure whatever you tap into is on the accessory circuit (switched with ignition) and not constant 12V, unless you want your ports live when the truck is parked.
