How wet is your differential case?
The procedure doesn't call for a lubricant around the outside face of the seal. The inner face must be lubricated with Kluberplus S06-100 gel. I assume this is the surface that the pinion flange runs on.
It also says to use an applicable seal driver. No mention of a special tool.
Kluberplus S06-100 gel is a water based lubricant to assist in assembly. The seal appears to be a cassette type to the outside and inner diameters will be fixed to there respective component surfaces.
There is a correct tool for installing the seal. The Carraro pinion seals in the Iveco Daily would leak if the seal wasn't installed and set in the correct position using the correct tool.
Yep, that's my point. The procedure doesn't specify a special tool to install the seal. That could be part of the problem with repeated leaking if workshops that are unfamiliar with the task use some other driver or method.
There are actually two procedures. One if the ring nut is being reused, the other for a new ring nut. The seal installation steps are the same.
The only listed special tool is a brake pedal depressor. The procedure calls for an applicable seal driver, and an applicable drive flange locking tool. Now it might just be that details of the correct seal installation tool were not available when these procedures were being written and 'use an applicable seal driver' is to be interpreted as 'use the correct Carraro tool'. Anyone relying solely on the manual without other information or related experience is not being told about a special tool.
Does anyone have the precise specs of the rear diff pinion seal? Or the Iveco or John Deere part no.?
Iveco seals from the info I have are not cassette types just normal lip seals but likely cross reference across from an appropriate seal catalogue. Iveco Carraro axles suffered from the same issues with vents as the Ineos has.
Iveco spec Carraro Generic pinion seal 60.0 x 90.0 x 10mm Viton lip seal
John Deere AL159591
Iveco 42558469 (5x the cost ot the others)
Corteco 12017026B
Iveco pinion seal tool 99374459.
John Deere AL159591
Corteco 12017026B
Thanks mate. Great info. I’ll get on it
My front and rear pinion seals have been replaced under warranty. Neither was a significant leak, but enough for me to double-check the diff oil levels.
The front pinion seal was replaced twice - after the second time, the dealer replaced the axle breather.
Well this inspired me to crawl under the truck, and I shouldn't have. Because ignorance is bliss. Front seal is leaking, installing a breather and then getting the seal addressed.
No oil on the ground, but dang this thing is behaving more and more like my old defenders.
Which is brilliant!!!!! Next mod? I'm gonna lift it, so I can start replacing the CV every 7K . . .
That should take care of it! I hope.
I just finished a 1200 mile road trip, coming up on 20k miles and no leaks....
The trip had hours of highway, and a solid amount of Offroad...
Rear one replaced and remains dry.
Front one has been “weeping” for a while now but will get replaced next visit. No dripping like the rear one did so not as much of a leak but still there.
I’ve been considering diff breathers but am concerned about the variable results of this! 🙄
Latest posts
