Heating system is useless
Your service centre is not fixing the issues. The heating will blow hot and cold if sorted. In-between settings and large and quick temp changes upset it.
Firstly, check the 2 expansion tanks for any signs of water leaking, if they are they need changing under warranty to get the system to work with the In-between temps. Check they are both topped up with coolant. Try doing the bleeding procedure that is available on here. Do this a number of times, after long runs and engine has cooled down. Make sure the refrigerant is topped up by dealer. If all this is done your heating will work. You may need to turn the aircon off at time s to get the mid temps when in auto or manual, sometimes you won't.
If you really want to sell, and i believe your selling issue is due to location from a dealer, i would contact Chester as they tell me they can't get enough second hand ones. But please try fixing first, saves loosing a lot of money and you will start to love it
The heating system needs to be treated gently when working, just one temp click change at a time and wait. If it insists on blowing cold on mid temp after a long spell of full heat, try a blast of full aircon cold and then turn aircon off for mid heat and use in manual.
Ultimately, the heating system should work, your dealer is just not doing their job
I have tried everything , trust me , it’s been with Ineos for 5 weeks now and they admit it’s a major fault . It simply does not work , they have tried everything . Autotrader had 2025 field masters fully loaded less than Sub £56k . I am not saying you can’t sell them , these chaps including the guys in Chester will offer you £38k or around there for a car I’ve paid £78k for . They low ball you . Ineos have given me a brand new loan and even on this one warning lights come in random and heating system takes forever to heat up so the issue is still there .
Sorry about that, it's a long trek for you but Lloyds at Carlisle would be worth a visit. They are very good, alternatively, contact @IneosGrenadierTech I can't recommend him enough.
Just throwing this out there. My truck is at the dealer getting the windshield replaced so I'm driving everyone's favorite - my purple 2009 Honda Jazz/Fit with 162K miles. She doesn't get driven very much; I got her started the other day knowing I'd have to use her for a few days but I had to use my NOCO booster to do so. Unfortunately I had to this morning too, but she fires up thereafter and still runs quiet as a top.
Point being - once on the road on a morning of approx 29 deg f, the heat/defroster was warm and toasty in a few minutes down the road. No auto-mode, nothing fancy, just a good ole fashioned red-to-blue temp dial and a 1-4 fan knob and it just works. I've said this before (maybe even in this thread TBH), but how did IA get this so wrong?
lol you are describing the operation as of a heater in a car. It’s year - looking it up - 2025. Why are we concentrated on a heater?
Oh yeah because Lynn Calder said they have very little room to work with and that’s why they can’t get hvac working.
On the flip side they want to sell arcane works for $160k because it has a few silver bits.. but not because they reinvented the heater for that trim 😆😭
My heater seems to be working but temps are in upper 30s/lower 40s. I also have the heated seats and very rarely wear a jacket. Mostly a hoodie and a vest. Temp set on auto at 72 recirculation off. Kids in the back. No complaints. 2025 QM
you should pull the dash on a G463. talk about no room. it still blows how you want it to blow.
Mine now does this thing, where when put in dash/floor for heat, it also blows cold out of the defrost. WTF.
When I use dash only setting, the temp coming out of each of the four vents is different. How is that even possible? Seriously they effed that whole thing up miserably.
IA - just tell me where the fk to insert the screw driver, so I can pry open the stuck flap. Give us some of these life hack tips at least! 😆
yep. on manual my flir has 140 at the rear, 107 a the dash, 85 at the dash side vents and 70 out the defrost... on fan setting 3 max heat. It gets weirder tho. on fan 1, all dash output temps drop significantly, like 20-30 deg..... um. fan is volume not temp. how is this air being routed that a lower fan speed means a lower air temp??? on fan 4 it makes a squeal that makes me think the fan or something else is unhappy at that speed/pressure, so I dont use it.
I'll add recirc does raise the temps, but eventually that will cause human load moisture buildup. warming the cold outside air lowers the rh and keeps the interior dry. I'm not a big recirc fan except on initial warm up.
Try turning the aircon off, it does help.
Just reading the last few posts. I have had all of this for over 12 months. I had the bleeding procedure done numerous times and it improved then finally had both expansion tanks replaced and it sort of works. Don't do full heat then expect mid temperatures. You need to blow ice cold to cool the sensors down and possibly turn aircon off if you are getting cold out of some vents. Turn rear off if you can, it does help.
Don't change temperatures too much and you will need to wait for it to do anything, and keep waiting.
If it starts to blow cold turn the HVAC off for a while and then back on. If still playing silly buggers blow ice cold and then fingers crossed. Again, turn aircon off if all fails. It will still run auto without aircon.
Get bleeding the system and have the expansion tanks changed if you have evidence of leaks
step back. Look at the chapter you wrote on the various “work around”, for getting warm air into the cabin.
Perhaps not your intent, but reads like rationalizing this egregious issue
I just recently had my 24 at the dealership for issues with the HVAC system. When selected to dash vents full hot the air was significantly cooler than if you select dash + feet. The dealership performed the coolant bleed procedure and found that there was air in the cooling system. The RO from the dealership said they were instructed by INEOS to rework the footwell vents and center vents and check for possible obstructions.
