Americas Front Driveshaft CV redesign
Commodore
2:46 AM
Pasadena, CA, USA
Ineos crew, there is an issue with the front driveshaft CV at the transfer case side. The acute driveline angle generates heat causing the rubber on the CV to rip and spill grease. This leads to failure of the CV joint and ultimately immediate loss of forward propulsion. The failures have been well documented. Do you have plans to redesign this part or should owners start looking for their own permanent solutions?
This is a serious safety concern that needs to be resolved.
Solution
Lynn didn't have the answer to hand but we discussed the CV joint boots failing by the nature of them operating at their extremes in terms of deflection. She took it back to her engineering team and they replied today.
Propshaft angle a hot topic from...
They added this later.
I had the springs on order as soon as they were available for sale and my truck had not yet been delivered.
There was no warning at that time.
I had my lift installed myself, but many trucks were sold modified, or offered to be dealer modified at purchase.
In the US when a dealer offers modifications or has a modified new vehicle for sale, there is an implied warranty.
Ineos may not have liability due to the lift, but we all know that no dealer sold it with any driveshaft disclaimer.
For the US, this is barely considered lifted. The minimum that typical pickup drivers do is a leveling kit.
It sucks that this small spring change equates to Ineos dismissing the problem.
I still love this thing.
Then the dealer should provide the warranty
Is the drivetrain setup exactly the same on the QM (just a longer rear drive shaft to account for the extra foot of wheelbase?)
Most certainly IA is paying particular attention to such a prominent YouTuber putting the QM through its paces so if something did happen involving the front driveshaft how thrilled would IA be to see that? The worst would be if IA offered some sort of special support or assistance just because of the social media exposure at play.
Would the rest of us mere mortals be able to expect the same kind of treatment should it occur? IA is going to be biting their nails and walking a fine line on this issue so it’ll be interesting to see what if anything happens should a failure occur and how it gets resolved.
I keep reading here that stock, unmodified ones are failing but I’ve not yet read one that has, at least that I remember. Granted, I’ve been reading here consistently only about two months…Will he who experienced his unmodified CV joint fail please stand up and share?
I'm one of those who had a CV boot rip on a Grenadier with an unmodified suspension.
I just feel like the steering feels different, and it’s hard for me to accept this is purely because of the longer wheel base. It feels like there HAS to be something different up front, but the dealer assured me that’s not the case.
12" difference in wheelbase is significant. Tahoe/Yukon/Escalade to Suburban/YukonXL/EscaladeESV is a 13.2" difference. Having driven many many examples of both wheelbases over the years, they handle completely different from one another.
There have been a small number of failures reported on stock vehicles on these pages, I would suggest it’s less than ten, possibly even less than five. But it has happened.
Yep. This document is included with Eibach Pro Lift kits and the same info is on their website.
This info was not included when I purchased my lift. I spoke to them multiple times about reported failures before I decided to take the risk. I talked to OWL before install to make sure they didn't let the drive shaft droop during installation. So far I have been lucky. Installed at 9000 miles and I am just shy of 24,000 now.
@terdrocket said the same thing a few posts back. I have no doubt Eibach reacted quickly when they learned of the CV issue.
My point was that Eibach (now) include a caution about the driveshaft so it's on dealers and installers including DIY to understand and accept that a lift is not going to make the CV situation any better. You're testing the edges of the warranty if there is a failure that can be attributed to the lift.
Get informed.
Assess the risk.
Proceed if you are comfortable.
There seems to be some confusion about Eibach Pro Lift kits. Despite being the same brand they're 100% an aftermarket modification. They're not listed in the Ineos options or accessories catalogue and have no official recognition by Ineos.
My point (2) above is for Ineos to clarify their warranty position re standard and lifted vehicles. We might not like the answer but we need to know their position. Too many owners have had repairs delayed while dealers and Ineos debate warranty matters.
Get informed.
Assess the risk.
My local dealer covered my CV replacement under warranty and made if very clear that it was ONLY done under warranty because it was a stock suspension. She told me that Inoes was denying warranty replacement on lifted trucks. She also said that they are replacing a lot of front driveshafts and they even keep them in stock at the dealership.
I'm quite sure that will be the answer if we do get a response. But there is now an awkward inconvenience between:
lift + fail = no warranty, and
no lift + fail = warranty.
Consider:
1. The boot fails on a lifted vehicle. The CV is otherwise intact. The boot was found pinched and this is attributed to excessive operating angle. There is minimal lubricant present and it appears overheated.
It's defendable for Ineos to say the lift was the root cause of the failure.
No warranty.
2. The c-clip fails on a standard suspension vehicle and the CV joint separates. The boot is torn. The CV contains residual lubricant and there are no signs of overheating.
The c-clip failure likely preceded the boot failure. The c-clip is the root cause.
Warranty applies.
3. As per #2 but now on a lifted vehicle. The CV separates. The boot has crease marks. The CV contains residual lubricant and there are no signs of overheating.
There is a history of c-clip failures in standard suspension vehicles. Lift may be a factor but it cannot be considered the root cause.
Warranty should apply, either in full or partial.
Opinion only. Pass me the 🍿
edits: updated after I thought about it some more.
