Americas Front Driveshaft CV redesign
Commodore
1:21 PM
Pasadena, CA, USA
Ineos crew, there is an issue with the front driveshaft CV at the transfer case side. The acute driveline angle generates heat causing the rubber on the CV to rip and spill grease. This leads to failure of the CV joint and ultimately immediate loss of forward propulsion. The failures have been well documented. Do you have plans to redesign this part or should owners start looking for their own permanent solutions?
This is a serious safety concern that needs to be resolved.
Solution
Lynn didn't have the answer to hand but we discussed the CV joint boots failing by the nature of them operating at their extremes in terms of deflection. She took it back to her engineering team and they replied today.
Propshaft angle a hot topic from...
Have a failure? Please visit this thread and post a reply.
Thank you. I have posted in that thread.
I suggest you consider another field to capture the type of failure, particulary the occurences of c-clip separations and boot splits.
I just feel like the steering feels different, and it’s hard for me to accept this is purely because of the longer wheel base. It feels like there HAS to be something different up front, but the dealer assured me that’s not the case.
when i test drove one, it felt different also, but when i got my truck back after all the extensive alignment work that includes remounting control arms, mine now steers like similar to the quartermaster.
as far as the wheel base affect, back up with an m416, and do the same with an extra 18' on the draw bar. the shorter wheel base really does amplify any wonkyness in the system, so i can see some extra wheelbase having a noticeable affect on something that tracks as bad as a grenadier.
Leave me with my foil hat and black helicopters
Hello all,
I was chatting with Justin Hocevar on Thursday night and I brought this issue up. He mentioned that DMW engineering in Toowoomba Queensland is close to have a process to rotate the diff centre in the front axle six degrees, allowing more castor and reducing the angle on the CVs on the front prop shaft.
Regards
Craig Murray
Hello all,
Regards
Craig Murray
Wizard Reuben waves his wand?
Hello all,
Regards
Craig Murray
This could be a game changer. I hope this is the case and gotta take ya hat off to the aftermarket and engineering industries
Hello all,
Regards
Craig Murray
Good to hear, odd OEM need aftermarket to fix a major flaw, but no different than the rear track on a 70 I suppose…
Hello all,
Regards
Craig Murray
Who is Justin Hocevar?
