Front Drive Shaft Update
What a blast from the past...
Justin Dermody... he definitely left his mark on Discoweb. One of the guys talking a big game, to vanish off the face of the Earth.
Lots of the old group have moved on. I largely lost touch when I moved into Unimogs. I still wheel with Bill Ritchie and Ed Mcgoffin and a few others. Saw Steiner not to long ago and didn't even realize it. I miss those days for sure.
A pretty substantial fraction of the "old group" (who still go off pavement) moved to Grenadiers.
That article about sums up Justin's track record. Can never seem to make it to big dance... Good old memories and fun times all around.
Did somebody say RTI? 😁 I found an RTI event this weekend near me.
"Fully Cloaked" - on full Metacloak suspension, 35x12.5s, extended brake lines, TCC front and rear bumpers, and front sway bar disconnected. I can happily report that there is NO rubbing, all tires clear.
Well that thing certainly look 'fully kitted', afraid to ask what it weighs. But more to the point, you found an RTI event, what was your 'number' and what degree ramp was it?
7340 lb to be exact. That's with both fuel tanks full, basic recovery gear, tools, plus me and the dog in the Grenadier. Not a light weight, but not too bad after I did some weight loss by deleting the rear seat and removing my drawers. I'm turning this thing into a trail weapon. Albeit a hefty one.
As for the RTI event, it was a 20deg ramp and I was the 2nd person on after my friend in his dialed-in GX470 on long travel and 35's. We were both there to see if our tires cleared and didn't take exact measurements as there is a Metalcloak CTI event coming up here soon that we will both be at. That's the one I want to capture. This RTI was just more for the fun of it.
Best use of an RTI ramp. They are great at finding about 95% of all clearance issues.
After seeing that awesome Grenadier Porn, I have a somewhat more mundane question regarding the Front Drive Shaft issue. Given the venue I suspect I know the answer, but I would appreciate your opinion nevertheless, particularly to satisfy my skeptical spouse. As a prospective Grenadier owner, is this issue a potential deterrent to purchasing one or is it thought of as a relatively minor annoyance? Thanks.
Not in a slightest bit. Spend extra $1K for a spare factory driveshaft.
So the Grenadier will not drive as rear wheel drive with the front driveshaft removed?
If for some reason your front drive shaft cv fails and you are able to remove it I guess technically you can lock the transfer case and drive rear wheel drive for a period of time. I'm not sure if that is a recommended strategy for the long haul
If for some reason your front drive shaft cv fails and you are able to remove it I guess technically you can lock the differential and drive rear wheel drive for a period of time. I'm not sure if that is a recommended strategy for the long haul
Thanks. My rear driveshaft (u joints) grenaded on my Land Cruiser so I removed it, put it in 4 wheel drive and we were able to get around town in front wheel drive to get it fixed. Not desirable, but better than getting towed.
Still seems like the frequency of this problem is not well documented. I see the survey on this forum but don't see anything more comprehensive. Perhaps Ineos has more data but doesn't really want to share.
There are a lot of small things about the front driveshaft failures that you’ve likely come across in your readings already, like low caster angles to relieve some pinion angle, people removing lifts, carrying an extra shaft or joint, etc.
Bottom line it has happened to plenty of folks, non-lifted and lifted, including myself. I’m not worried now I’ve already changed it out on my own. Secondly, we are in the infant stages of this vehicle being on the market. This will likely be solved sooner or later either by Ineos or the aftermarket. My money is on the latter.
I and many others here are trying to pioneer ideas for the fix. In the meantime, it’s a “be prepared” situation and that takes the edge off; for me at least.
It’s such a great vehicle I now have two. Go for it!
With a 1.7 in lift, I am going through one every 8,000 miles. I drive 1000 each week so yeah, it's getting costly and annoying. I've had the Agile HD shaft in for two weeks and it's not a great option other than a little more piece of mind. I'm not complaining about the HD shaft, I knew what I was buying and they make sure you know that. I checked with a well-known off-road shaft builder, and they said they've pretty much thrown in the towel after having no success in their R&D.
I won't buy another until they fix the issue or have an aftermarket solution that doesn't have harmonics issues. Someone around the Seattle area is rumored to have custom made portal axles for their '24 but I haven't confirmed it.
My grenadier was a total loss when it happened on freeway. 3.5 days of driving from Seattle to Dallas to see family for christmas; all road driving. Fire caused by the shaft failure on the last day was a total loss as it happened at 70 Mph and I had to fight other cars to get off the road as slag punctured the fuel lines.
But I am not the typical case. There's been what, two documented fires from the propshaft? The other fires to my knowlege were either diesel model defect with the engine cover or related to the high load electrical panel recall.
If I were you, I'd just be prepared and carry a spare boot / shaft, and definitely fire extinguisher. I wasn't able to save the vehicle with the extinguisher, fire spread too fast and the entire value of these vehicles is basically the undercarraige. But I was able to save all the Christmas gifts and woodworking tools I had in the cab with a little clean agent bottle.
Despite what happened not being the typical case, I personally am still holding off as I am extremely unhappy with how both IA and my dealer who sold the vehicle handled the matter. I know some IA engineer wanted to talk to me because I got a formal request to waive my WA state rights to privacy for my dealer to share my direct contact info with them, but for whatever reason they ended up ghosting.
bet a crisp dollar that lawyers put a pin on that. A bit of a shame because i would love for them to know more so they can design around problems.
