Nothing really to devise. Just order a set that fits the shock bolts and go.Has anyone devised a limiting strap installation to control articulation of the front axle?
What length would you suggest, or are they adjustable?Nothing really to devise. Just order a set that fits the shock bolts and go.
The T-case side is about 2.5° more IIRC. It's 100% more, I just can't recall exactly. And that difference changes slightly based on caster and lift.Do we know why only the transfer case side CV is failing? Seems like the angles on both sides are about the same.
I believe stock front shocks are about 23" eye to eye. So 21.5" strap would be fine. But likely you will end up with a 21" strap. Several companies will make custom straps, 2" wide is fine and they should sit inline with the shock.What length would you suggest, or are they adjustable?
So you mount the tabs for the limiting strap to the same bolts/nuts used to mount the shock absorber, effectively piggy backing on it? I think the mounting points for the shock absorber are offset by 90 degrees, ie the top mount is east/west and the bottom is north/south, any issues in this case?I believe stock front shocks are about 23" eye to eye. So 21.5" strap would be fine. But likely you will end up with a 21" strap. Several companies will make custom straps, 2" wide is fine and they should sit inline with the shock.
Yes, that is the simplest method to not cause warranty issues. You can attach to other locations if available but you will have to measure out the strap length at that point.So you mount the tabs for the limiting strap to the same bolts/nuts used to mount the shock absorber, effectively piggy backing on it? I think the mounting points for the shock absorber are offset by 90 degrees, ie the top mount is east/west and the bottom is north/south, any issues in this case?
Metalcloak has put on on their CTI rig..Has anyone ever measured the actual wheel travel at all four corners?
Is the CTI score for the Grenadier published somewhere with documentation. It does not appear to be listed anywhere on the Metalcloak website.Metalcloak has put on on their CTI rig..
Email from them states the following:
Stock with sway bar connected, our Grenadier did 532 on the CTI
Stock with sway bar disconnected it did 635
Metalcloak arms, track bars, coils and disconnected sway bars it did 645
A Stock 4 door Jeep JK is 540 for comparison..
For clarity, I meant actually dimensions, e.g. 8" front travel / 10" rear travel. This will show exact effect of limiting straps.Has anyone ever measured the actual wheel travel at all four corners?
They were provided to me via email by Metalcloak..Is the CTI score for the Grenadier published somewhere with documentation. It does not appear to be listed anywhere on the Metalcloak website.
Understood. But it is odd Metalcolak does not publish a list of the CTI scores for stock vehicles they have tested. If they want to legitimize CTI as a valid measurement they need to provide data and not just talk about how good it is as a metric.They were provided to me via email by Metalcloak..
RTI does not account for weight, tires size or ground clearance. RTI is based on height a tire can be lifted without others lifting and then adjusted for wheel base. You could literally start with your vehicles frame on the ground and no tires and still get a relevant RTI or CTI score.Ground clearance, tire size, weight and suspension travel (which when combined with wheel base determines the RTI/CTI score) are the primary factors that determine off road capability. Add center of gravity and front/rear balance and you have most of the picture assuming there is adequate power and low gearing. Shock valving and spring rate are also a factor. But it is misleading to say that suspension travel is unimportant. One of several factors yes, but still a key component of a well balanced rig.
