I had the pleasure of swapping out a buddy’s CV joint last Thursday night at MERUS in Palo Duro Canyon. I always carry a spare joint on my rig. This was my third time replacing a CV on a Grenadier — two times with
@Dokatd on my own rig (with a lift), and this time it was a trail repair using a jack and on my back!!!
Note: I have 35” KO3s with a 2.5” Eibach lift.
On the last three repairs, each time the transfer case side was stuck in the cup and required a mallet and punch. Another method is to leave four bolts in on the differential side of the CV joint and remove all bolts from the transfer case side. After battling to break the shaft loose, I had to call
@Dokatd a few times to ask him what the trick was. Finally, at his direction, with one wheel jacked up from the front left axle (we had to use the OEM stock bottle jack), we wrapped a ratchet strap around the rear CV joint (where the shaft narrows into the CV joint) and attached the other end of the strap to the front tow hook.
Note: The ratchet strap needs to be as parallel as possible to the attachment point to get the best angle and to keep the strap from slipping off.
Next, we took the transfer case out of neutral and put it into gear, then spun the left front wheel — and the CV joint broke loose. We then removed the four bolts that were left in on the differential side, and the shaft popped out. After that fun, we could not get the CV joint off the propshaft splines. (Yes, we removed the back cover of the CV joint with a flathead and a hammer and removed the C-clip that holds the joint on the splines.) After about an hour of hammering the joint with two hammers on each side to apply even force, we stopped for the night. Luckily, there was a hardware/machine shop in town that had a puller, and that did the trick. Our buddy’s CV joint boot had been ripped for a while. There was barely any grease left in the joint, and we surmised that the grease had thinned out and hardened in the splines, making it difficult to pull off. Using a hose pick, as suggested above, would never work — it would bend like an aluminum spoon.
Fun times........
