Front Drive Shaft Update
How much heat play a role? If your driving at 85mph versus 60? Can this attribute to early breakdown of the boot?
Rubber generates heat as it flexes, but I would think the grease in contact with it and the rest of the metal parts would act as some sort of a heat sink. I don’t see heat in and of itself being the make or break factor.
Old mate who was helped out by IA with a replacement driveshaft at the ferry terminal in Melbourne recently made an interesting comment. He speculated to his partner that they had been driving on a lot of dirt and gravel roads and must have flicked a piece of gravel into the CV mouth and it got pinched between the boot and the CV lip at the bottom. Of course he's guessing but it's not improbable. He'd done a lot of miles under the same driving conditions and then got a failure. It could easily be another pattern fatigue failure of the boot from flex cycling, heat, etc. Or, he could be right. I'm just throwing that in because it hasn't been mentioned and it's another plausible reason why a hot soft boot could go from hero to zero very quickly.
That is a very interesting theory and certainly not improbable. Think about what it’s like on a muddy track. You can get mud stuck up on the transfer case cross member.
It seems to me like that would be difficult for a rock to lodge in there while it’s spinning, and it would clear.
I doubt it lodges itself there but if it hits at just about the right force i can see it making a tear.
I honestly cannot. This is fatigue from stress. Don’t waste your time with little cages. They need to utilize a different compound.
The design of the front axle is such that this is relatively hard compared to other trucks. It will require some other components to complete it as well.
It's doable, but a considerable task. Honestly it may be easier and cheaper to change the front axle out all together. Maybe a built Dana 44 or a 60 if you want over kill. But then you almost might as well swap the rear to a 60 as well.
If I can get a housing as a core I would be more than happy to start dissecting it to see what's truly possible. I have seen several detailed photos of the front axle torn down and understand the assembly, but I need it in hand.
An expensive proposition for sure. But then there's parting out the rest of the rig that may help offset the acquisition fee.
The transfer case side boot went on mine today, but I caught it before any other damage. Annoyingly, I just drove it an hour and a half back from the dealer. On the way down I noticed a new vibration and told them to check the driveshaft. Clearly they didn't.
I just had the same dealer (Arrowhead in Phoenix) install a 30mm front and 30mm rear lift about 1000-1500 miles ago.
Dealers at this point certainly know suspension lifts are a likely contributor to early demise of the transfer case front driveshaft boot. Curious if anyone with a dealer installed lift has encountered any sort of a required signed wavier or verbal warning you are on your own should a failure occur?
Not to say that some would or would not implement that, they don't technically have the need to.
The decision is still up to the customer to install aftermarket parts (or for that matter, buy a vehicle with aftermarket parts installed), and the warranty process is covered (paid) by the manufacturer. Whether the lift is installed by a dealer or not, the manufacturer still has no duty to cover a part that has failed from modifications.
The above reply isn't Ineos specific, as this is something done by dealers of nearly all brands at this point
At how many miles since new did this occur?
Call me know-it-all, but this exactly what I thought when I looked underneath a proto vehicle for the first time.
