Front Drive Shaft Update
Hi All, been reading watching for awhile.
Mine failed 24 Trailmaster, 17000k's Eibach lift (35mm) all done at Expedition HQ when the vehicle was new (i suspect pre-delivery, i bought it used)
managed to get a new one done under some deal worked out between ExpHQ, Ineos and the local dealer
this was approx 5000k's ago, no sign of failure as yet, i have done a few weekends mild to hard 4wding
I was advised when it was replaced that this wont happen again, i wont say by who but they hinted at a new rubber design.
Still makes me nervous though and i check regularly
I have a big trip coming up to the Vic High country at Christmas, im thinking about grabbing a jeep JL\JT Rzeppa joint as a spare
are these still the best option?
Seems so, with reservations re the fit on the splines. See post #519 in this thread
Everyone is conerntrating on the static driveline angle as the contributing factor to the CV failures and correctly so, but are there other issue that need to be considered and added into the equation like CV lubricant type, excessive heat transfer or operational powertrain movement under load or in certain driving scenarios also playing a part in the CV failure?
Placing a few temperature recording decals in critical areas may assist. This give a visual reference to service departments and owners a way of quickly checking for any impending issues.
Surely they selected high temp cv grease?
Yes, it will be a lithium soap based with mineral oil grease they use because it is the most cost effective CV grease to suit all CV applications on the production line.
The main factor for a CV is the extreme pressure (EP) additive required which is commonly molybdenum disulphide (moly) with the addition of graphite. Moly grease generally comes in 2 3 5% or more. Cv grease is around 3% any higher the balls in the cv will likely start skidding because molybdenum disulphide can act like a wheel chock if there is excessive amounts in roller elements of bearings.
I bought temp indicator paint just for this. But then I used my IR gun and found the temps are nowhere near what's needed to fail the boot.
We need to get the attention of Lynn Calder. Perhaps it’s time that the lot of us all comment on her LinkedIn posts. The last one only has 14 comments on it. We can certainly stand out and perhaps whoever manages her account for her will pass on that the owners are pissed off. Here is here account https://www.linkedin.com/in/lynn-calder-a6814b55?
Mark my words, someone is going to get hurt when one of these fail at 75 mph. My post in the ask Ineos section is marked as solved because someone asked her about this issue and she said that she would look into it. That isn’t solved. That is the answer a politician gives when they want to avoid the truth. No doubt the attorneys have told her not to comment.
I absolutely love this truck but Ineos needs to address this engineering flaw.
Definitely preferred it when it was attached rather than in the boot. Will pop by Chandlers in Horncastle for a chat before heading home. Will diagnose cause and report back.
Front and rear diffs also leaking AGAIN (photo from underneath inspection day before trip)
What’s it like to drive in CDL high with the front driveshaft removed?
Sub optimal when pulling away or reversing - bit of a delay. At normal road speed I didnt notice much difference. Got a 5hr drive later so will know more then. Just want to get the dogs home in one piece.
I been holding off on a new vehicle for about a year now hoping ineos would fix this drive shaft issue, along with other concerns. I had to pull the trigger as need all of next year to set up a tourer for our Oz trip. So just put a deposit down on a 2024 RAM 1500, sure its not a hard core 4x4 but itll get me where I need to go. It has some issues but after some research there are permanent fixes available if I ever experience them thanks to the awsome after-market guys ive spoken to. 4T GVM upgrade ordered with 2" lift and next year a Norweld tray and canopy to be fitted. Dealer offered a great deal so I took it as this will be the last of the HEMI V8's available here in Australia so taking a chance on this purchase. Perhaps one day I will trade the RAM in for an Ineos, time will tell if IA do there part.
I dropped mine off yesterday at Rusnak for a windshield and front pinion seal leak. While there I asked about the driveshaft situation. They both service advisors said that Ineos is aware of the situation and they are continuing to warranty replacements as long as the vehicle is on stock suspension.
I asked about if there was a fix coming and neither had any information.
And I left a comment on Lynn’s last LinkedIn post. Feel free to pile on.
It’s highly probable there won’t be a “fix” for this issue on existing vehicles but rather different aftermarket options to cope with the problem but it’s always going to be a weak point. The one true fix will be a redesign on the front axle from IA if they manage to get around to it.
If that actually does happen on future production models be prepared for current vehicles to take a big hit on resale value as the market flags it as less reliable to modify suspension wise. So we either lump it and try and enjoy the vehicle as-is or we prepare to sell our current vehicles at less than ideal values and move to an upgraded version should one appear in the future.
I'm just in the process of writing IA a letter around the point of 'this is now a known design fault of the truck and it has severe safety implications to life and limb - let alone pain in the arse (which a flailing driveshaft at 70mph could easily cause!) logistics, confidence etc etc'. What good it will do I do not know but considering I'm not alone with a low mileage/age non-lifted failure I have to make my concerns clear and recorded.
Yours p1ssed off of Sussex
This will be costing them millions if not billions in the long run with lost sales
I hope they are smart enough to release a new model soon with some much improved engineering with the front diff and steering geometry with some more castor adjustment
If not they will become a collector item from a failed venture by 2027 would be my guess
It’s also highly probable IA will not be addressing this issue in the near term because they can’t risk the optics of issuing a large recall while they are in the middle of restructuring their business, laying folks off and significant financial stress facing the automotive division meaning they might not even have the cash to deal with a retroactive redesign. They’ll take the path of least resistance and try and thread the needle until everything is on a more firm footing.
Seems to me ignoring the issue outright isn’t a winning strategy either as all that accomplishes hurting current owners and the brands overall reputation. Worse still would be a few failures resulting in vehicle accidents and/or injuries and a government forced recall so not an ideal situation all the way around.
