MrMike
Hi @das mo, yes it should be (depending on if the socket in the rear is wired to the second battery) a matter of plug n play. Make sure you have ventilation for the drawer fridge otherwise it will draw more power. The only problem with the drawer fridges is that items like milk can't be stored upright unless it's in a container no higher than a 375ml beer can. If possible change the socket and the fridge plug to the Anderson style plugs, these are far more secure and generally save you from having either warm beer or off milk! or both!Running a fridge.
As I never ran a powered fridge in a car:
Is this simply plug and play when having the prewiring and second battery ordered?
What is the exact location of the power plugs in the boot?
Initial info was there are different Amp sockets in and outside the car.
I am currently looking to install the Engel SB30 into my setup as we usually only need to cool some cheese, milk, fish or meat.
The info is probably out there, so sorry if this has been asked before.
Cheers!
