Dometic Coolmatic CD30 fridge wiring question
If you need a 12V output that is not switched via the overhead panel and always has power, you can use the one under the rear right seat. It just needs to be fitted with a plug. I have an Anderson plug on it for the portable compressor, for example. But it runs off the main battery.
There were no terminal covers on my auxiliary battery, let alone seals. However, you @Logsplitter are probably right that Ineos does not want any consumers connected directly to this battery.
But I don't care, I don't want the switch on the overhead panel to always have to be turned on when the refrigerator is running and connected to the socket in the boot. And I don't want the power to come from the starter battery either.
I have equipped both batteries with a monitor, so I can check the voltage via an app. In addition, I have a live voltage display with remote monitoring via the Webasto auxiliary heating system and its app. That should be enough; if the auxiliary battery runs out, it's not a big deal to me.
I don't really understand the point of the Ineos solution with Smartpass anyway. I would have found a real starter/consumer battery configuration more sensible for a car like this. That's why I'm going to connect the refrigerator directly to the auxiliary battery soon, including a 30A safety switch.
I understand where you’re coming from. When I ordered the dual battery setup I had in mind a traditional setup. As in starter and house battery with either a voltage sensitive relay or DC to DC charger. For now I’ll live with Ineos setup but when either of the batteries failes I’ll probably change to a more traditional house/consumer battery linked with a DC to DC charger to the starter battery.
I suspect this discussion is going beyond what the OP had in mind 🤪
If INEOS has blocked off the service battery load port on the Smartpass, then I’d guess the second battery + Smartpass was intended to address a very specific problem. BMW’s implementation of their Intelligent Battery System (IBS) has been criticized in the past for maintaining the starter battery at less than 100%.
As I understand it, IBS is trying to maintain an SOC around 70% so the battery can always accept charging upon deceleration or no load on the engine. Imagine a scenario where you’re climbing a mountain pass for two days with lots of stop/starts (not the automated kind, but where you turn the engine off, scout the route, then come back and start the engine again). Then throw in 3 or 4 sessions of using the winch to extricate the vehicle. I can imagine that the charge system could fall behind and you’d end up in a position where the battery would become so depleted it could no longer start the engine . . . before you got to the top of the mountain.
Eventually, you’d descend that mountain, and IBS would be charging your battery for nearly the entire descent. I suspect the second battery was intended to add extra capacity so you could always get over the top of mountain under “typical” or “expected” conditions (as defined by INEOS) without draining the single battery to a no-start condition. According to the CTEK documentation, the Smartpass dumps service battery current into the start battery for the first ten seconds of an engine start - that’s how the vehicle accesses the extra capacity of a second battery to protect against a too-depleted start battery.
One of the best laziest ways to figure something out is to post it on the internet and wait for the inevitable corrections to roll in. So I’m going to keep speculating. I’d further guess the 2-battery solution was a speculative fix that was either eventually determined to be unnecessary, uneconomical for INEOS, or it was obviated by a slight modification to the IBS software.
So @Barrett1 , if all my speculation is true, then INEOS never intended any loads to be connected to the service battery (or else they wouldn't have blocked off the low-priority service battery load port on the Smartpass).
</specuation>
I don’t really see any downside to contradicting INEOS’s intentions of only connecting loads to the start battery, and this seems to be borne out by the experience reported by @AaronS . Or you could connect your load to the starter battery via the cigarette lighter, the fuse panel or via direct connection. Both batteries are connected during engine-on ops, and both batteries eventually get charged.
Some final thoughts . . .
- If I had the dual battery system and wanted to use the second battery as a house battery, I’d get rid of the Smartpass and install a DC-DC charger with a power distribution relay to disconnect the charger when the engine was off. But I don’t and won’t since I tow a small overland type trailer with its own house battery and DC-DC charger / solar controller.
- I live on top of a mountain, so anytime I go somewhere, I immediately descend 2,000 feet with engine braking the whole way. I was watching the SOC on a descent the other day. At the bottom of my descent, SOC was 96% (observed similar on several runs). This is what makes me think INEOS may have tweaked the IBS function, since that is far above the 70% SOC target all the IBS docs seem to reference.
I have an occasional use Engel MT45, so it’s in/out of the Gren all the time. I really like the convenience of the 12v DC plug, and the convenience of the overhead switch to power the fridge with engine off. I may eventually wire a direct feed from the starter battery, but with the Engel’s low draw it’s not really necessary.
The IBS:SoC is a joke. I put 200W of solar on my roof to support my Engel MT45. If I park in the garage I’m still at the mercy of the IBS, but out in the sun and I’m in the 90+% SoC all the time.
