Dometic Coolmatic CD30 fridge wiring question
If you need a 12V output that is not switched via the overhead panel and always has power, you can use the one under the rear right seat. It just needs to be fitted with a plug. I have an Anderson plug on it for the portable compressor, for example. But it runs off the main battery.
There were no terminal covers on my auxiliary battery, let alone seals. However, you @Logsplitter are probably right that Ineos does not want any consumers connected directly to this battery.
But I don't care, I don't want the switch on the overhead panel to always have to be turned on when the refrigerator is running and connected to the socket in the boot. And I don't want the power to come from the starter battery either.
I have equipped both batteries with a monitor, so I can check the voltage via an app. In addition, I have a live voltage display with remote monitoring via the Webasto auxiliary heating system and its app. That should be enough; if the auxiliary battery runs out, it's not a big deal to me.
I don't really understand the point of the Ineos solution with Smartpass anyway. I would have found a real starter/consumer battery configuration more sensible for a car like this. That's why I'm going to connect the refrigerator directly to the auxiliary battery soon, including a 30A safety switch.
I understand where you’re coming from. When I ordered the dual battery setup I had in mind a traditional setup. As in starter and house battery with either a voltage sensitive relay or DC to DC charger. For now I’ll live with Ineos setup but when either of the batteries failes I’ll probably change to a more traditional house/consumer battery linked with a DC to DC charger to the starter battery.
