Installed the Fox ATS Steering Damper. Easy install, less than an hour. Had to sue the vise to compress the tie rod end per the Agile Offroad video, but pretty simple stuff. Took 'er out for a test drive and voila! the steering is much improved at 12 clicks, I think a few more might be even better.
Took the new custom hat and the truck out to Alligator Creek.
I’m in central Germany and today I stopped at a supermarket for provisions. When I came out the Grenadier would not start. Engine turns over but does not fire. No active faults bar the overdue service and e call error and battery at 93%. A bit frustrated I walked away and got a coffee. Come back 10 minutes later and it started first time and strangely I no longer have an Ecall error with yellow warning triangle. I’ve had this Ecall error for many weeks and no active errors now apart from overdue service warning. I can’t understand this vehicle.
You deffo got a Friday arvo build.
I went karting this afternoon. My Ineos has the Toughdog damper adjusted similar to stock, fairly heavy compared to any modern car as many have stated.
But after karting I almost ran the "boat" off the road on the drive home. Several times.
God knows how loose some of you have set your steering.
Moral: get your wife to drive you home after karting!
Well now you've done it. If Tiger Woods' attorneys read this you may be called as an expert witness. 😂
