EUROPE AND UK: Third Party Suppliers for the INEOS Grenadier and QM
thats great! look forward to seeing the registration stats land! I know the lifeboats order was floating around and then got can'd in the end. Would be great to see fleet's invest here.
RNLI has 20. Probably leased I guess
I’ve seen one in a marina in Poole all liveried up.
edit that. Going to have 20 ! Over the next five years
To come over time, Part 2 will be links sorted by subject.
  1. AUX fuel tanks
  2. Brackets for lights, air compressors, etc
  3. Canvas bags
  4. Cargo barrier
  5. Drawers
  6. Fender plates
  7. Fridge slide
  8. Gullwings
  9. Lights camping, grill and LED lightbars
  10. Molle Panels
  11. Picnic tables
  12. Side steps
  13. Rear roof shelf
  14. Rock sliders
  15. Roof racks and roof rails
  16. Storage
  17. Suspension, air bags, shocks and coils
  18. Under body Armour
  19. Winch stuff
New link
Explore Glazing (Netherlands) has gullwings and Molle Panels here;
I do like a sliding window, also the swivel quarter front side window on some old cars. I have no need for that rear sliding window, but I am going to have to work one out using 'man maths' and explain it to the wife.
Your lists of all the aftermarket suppliers is of serious damage to Grenadier owners pockets, I need to unwatch this thread 🤣
Keep up the good work 🫡
It is still only short. The AU Master list is 120 headings with over 500 links. ;)
  • Mind Blown
Reactions: CRH
I don't know if this is ok here, but I wanted to also give a shout out to Roy Duffy at https://4x4obsession.co.uk/
Known him for the best part of a decade, and had been my go-to person for all things electric and lights. He's also a great connection for sourcing US and Australia made kit. I don't think he has a G specific section, yet - but maybe we can help him fix that :)
I will figure out how to add it. A similar thing is already in place for the AU list.
They have rocker switch panels, like the one I use in my IG. Now I only have one switch vacant, as I have now used 3. The extra two are USB charging points.
full
With the other switch panels you can make up some interesting power sources for the rear of the car. Here is the one in my car which I made up.
full
THe USB outlet is wired into the Anderson socket, you can see above. At the end of that cable (out of picture) is an Anderson plug, which I plug into the cable from the aux battery. It is a plug and play set up which is now field proven. The wire from the USB outlet is fused, you can partly see the fuse holder to the left of my fingers.
full
It is installed on the side panels of my rear drawers, left side (just near the L track):
full
full
My panel is plugged into a 50 amp Anderson cable from the aux battery. It can be removed or repaired by simply unplugging the Anderson plug.
The 3 power outlet is wired to the rear OEM power outlet, so I had two power sources to the panel, not one. From memory that outlet is only live when the car is on, but I do need to check that.
Check out Mud U.K. for accessories that would fit Grenadier also. I used them a lot for my Defender.
New link
Nakatanenga 4x4 (Germany) has over 20 products for our IG or QM here, including lights, rims, sun visor organisers, window vents, etc.
