I wouldn't even know/remember to use it so complete waste of time.Geez, you guys have this in the UK/EU and we have ADAS clicks in the US…INEOS got us both![]()
That's the point, you don't have to, if killed in an accident it automatically notifies your next of kin, or something like that.I wouldn't even know/remember to use it so complete waste of time.
See, I had no idea what it was for. Anyway, I don't want the wife knowing I'm dead, she'll take all the moneyThat's the point, you don't have to, if killed in an accident it automatically notifies your next of kin, or something like that.
Mine finally turned off after about 2000 miles.I got the ‘eCall error’ (amber) warning today. I haven’t used the vehicle for around 10 days although battery indicator was up around 78% (usually sits high 80s/early 90s with reasonably regular use.
It doesn’t sound like a big problem but is annoying. Is this likely to disappear by itself or is a trip to the dealer on the cards? I am told I had the software update at service towards the end of last year.
Any advice is much appreciated!
Hi, I've tried this a few times and it didn't work, first time 20seconds then for about 40seconds with same effect. I had the engine switched off, should I be doing anything else apart from pulling the fuse? Its a shame the software boffins don't allow this facility to be turned off. Thank you for your help.Simpler to do than to say... Disconnect the fuse indicated below for 20", than riconnect it. It works.
The eCall facility in the UK and EU is a mandatory safety feature and as such the option of being able to turn it off by the owner is not permitted. And I also presume that a failure warning light ( along with most other failure warning lights ) is now classed as an MOT failure.Hi, I've tried this a few times and it didn't work, first time 20seconds then for about 40seconds with same effect. I had the engine switched off, should I be doing anything else apart from pulling the fuse? Its a shame the software boffins don't allow this facility to be turned off. Thank you for your help.
Ignition on or off? Engine running or not? Other conditions to be taken care of? I think that's what @bemax was interested in.I did it the way "alvan" suggested and it worked and still works.
The vehicle was locked. After unlocking, only the red LED on the e-call lit up. First, I pulled the fuse without the ignition switched off. The red LED stayed on. Then I removed the fuse with the ignition switched on. The red LED stayed on. I then turned off the ignition, locked the vehicle, and waited for it to go into standby mode. Then I unlocked it again. The red LED lit up briefly for a self-test, after which the green LED lit up continuously. It has remained this way ever since. The red LED lights up briefly after unlocking, after which the green LED lights up. No additional warning message on the display.Ignition on or off? Engine running or not? Other conditions to be taken care of? I think that's what @bemax was interested in.
From the picture I would say "off" since the key is not present...
Do I get this right: When ignition was "on", you removed the fuse, and after a couple of seconds you reinstalled it while ignition was still on?The vehicle was locked. After unlocking, only the red LED on the e-call lit up. First, I pulled the fuse without the ignition switched off. The red LED stayed on. Then I removed the fuse with the ignition switched on. The red LED stayed on. I then turned off the ignition, locked the vehicle, and waited for it to go into standby mode. Then I unlocked it again. The red LED lit up briefly for a self-test, after which the green LED lit up continuously. It has remained this way ever since. The red LED lights up briefly after unlocking, after which the green LED lights up. No additional warning message on the display.
Hi, the advice was undertaken with the intention of resetting the warning light, opposed to disabling the e-call system. Unfortunately with a battery/electrical system that likes emptying itself, (altho I have never been left stranded), the low voltage and e-call lights are a permanent glow on the dashboard. Which is a shame and annoying as I love the vehicle. As you say, it would mean any vehicle with the e-call warning light on, is an MOT failure, but having just checked the VOSA guidelines, that system isn't safety or environmentally critical, so should not be the cause of an MOT failure.The eCall facility in the UK and EU is a mandatory safety feature and as such the option of being able to turn it off by the owner is not permitted. And I also presume that a failure warning light ( along with most other failure warning lights ) is now classed as an MOT failure.
There are a couple of obvious issues though, a) there may actually be an eCall fault and b) the eCall internal batteryHi, the advice was undertaken with the intention of resetting the warning light, opposed to disabling the e-call system. Unfortunately with a battery/electrical system that likes emptying itself, (altho I have never been left stranded), the low voltage and e-call lights are a permanent glow on the dashboard. Which is a shame and annoying as I love the vehicle. As you say, it would mean any vehicle with the e-call warning light on, is an MOT failure, but having just checked the VOSA guidelines, that system isn't safety or environmentally critical, so should not be the cause of an MOT failure.![]()
Thanks Alvan. I had the red warning light and amber triangle in the dash display a while ago. This was fixed by my dealer (who are no longer a dealer) with a software update and re-boot. Now I just have the red ecall light with no amber triangle and no local dealer. Is the advice the sameSimpler to do than to say... Disconnect the fuse indicated below for 20", than riconnect it. It works.
I have the same warning just now, Its the 3rd time I have had it, each time caused by leaving the PWR switch on and draining the battery. I have not managed to find a way to fix it. Annoyingly when the car was at the dealers for the turbo hose repair they didn't clear the code! I only noticed after I had left. They also refused to reset the service interval as they hadn't done the service! The fault code reader can't come soon enough.Thanks Alvan. I had the red warning light and amber triangle in the dash display a while ago. This was fixed by my dealer (who are no longer a dealer) with a software update and re-boot. Now I just have the red ecall light with no amber triangle and no local dealer. Is the advice the same
(1) Turn off the ignition
(2) Remove the fuse
(3) Lock the car and let it turn everything off
(4) Unlock
(5) Replace fuse
and everything will be nirvana?
Thanks Guys
