e-call failure
Geez, you guys have this in the UK/EU and we have ADAS clicks in the US…INEOS got us both😂😂😭
I wouldn't even know/remember to use it so complete waste of time.
I got the ‘eCall error’ (amber) warning today. I haven’t used the vehicle for around 10 days although battery indicator was up around 78% (usually sits high 80s/early 90s with reasonably regular use.
It doesn’t sound like a big problem but is annoying. Is this likely to disappear by itself or is a trip to the dealer on the cards? I am told I had the software update at service towards the end of last year.
Any advice is much appreciated!
Mine finally turned off after about 2000 miles.
You can get a dealer to clear it and most likely charge the battery up to avoid it happen again.
I also raised the hypothetical situation that my warranty runs out, the car battery drops below 50% and I'm stuck with an eCall error and need to get the error cleared. The answer was that it'll cost me to clear that error. Not really happy about it, but it's good to know the error does eventually clear by itself.
Mine cleared itself too after a few days of normal use.
Simpler to do than to say... Disconnect the fuse indicated below for 20", than riconnect it. It works.
Don't worry it. won't work in Wales as neither the radio or satnav do.
It came on in a Mere I was driving last week for no apparent reason had a loverly debate with a foreigner about weather I had crashed or not he said yes I said no.
Hi, I've tried this a few times and it didn't work, first time 20seconds then for about 40seconds with same effect. I had the engine switched off, should I be doing anything else apart from pulling the fuse? Its a shame the software boffins don't allow this facility to be turned off. Thank you for your help.
The eCall facility in the UK and EU is a mandatory safety feature and as such the option of being able to turn it off by the owner is not permitted. And I also presume that a failure warning light ( along with most other failure warning lights ) is now classed as an MOT failure.
I did it the way "alvan" suggested and it worked and still works.
Ignition on or off? Engine running or not? Other conditions to be taken care of? I think that's what @bemax was interested in.
From the picture I would say "off" since the key is not present...
Ignition off. And don't forget that 'sometimes' a warning light/message can be caused by a real malfunctioning... Not always a warning system malfunctioning...
The vehicle was locked. After unlocking, only the red LED on the e-call lit up. First, I pulled the fuse without the ignition switched off. The red LED stayed on. Then I removed the fuse with the ignition switched on. The red LED stayed on. I then turned off the ignition, locked the vehicle, and waited for it to go into standby mode. Then I unlocked it again. The red LED lit up briefly for a self-test, after which the green LED lit up continuously. It has remained this way ever since. The red LED lights up briefly after unlocking, after which the green LED lights up. No additional warning message on the display.
Do I get this right: When ignition was "on", you removed the fuse, and after a couple of seconds you reinstalled it while ignition was still on?
Sorry for pestering...
Hi, the advice was undertaken with the intention of resetting the warning light, opposed to disabling the e-call system. Unfortunately with a battery/electrical system that likes emptying itself, (altho I have never been left stranded), the low voltage and e-call lights are a permanent glow on the dashboard. Which is a shame and annoying as I love the vehicle. As you say, it would mean any vehicle with the e-call warning light on, is an MOT failure, but having just checked the VOSA guidelines, that system isn't safety or environmentally critical, so should not be the cause of an MOT failure. 🤞
There are a couple of obvious issues though, a) there may actually be an eCall fault and b) the eCall internal battery 🔋 does take a long time to recharge. It may be worth a visit to a dealer to see if the internal battery needs replacing.
Thanks Alvan. I had the red warning light and amber triangle in the dash display a while ago. This was fixed by my dealer (who are no longer a dealer) with a software update and re-boot. Now I just have the red ecall light with no amber triangle and no local dealer. Is the advice the same
(1) Turn off the ignition
(2) Remove the fuse
(3) Lock the car and let it turn everything off
(4) Unlock
(5) Replace fuse
and everything will be nirvana?
Thanks Guys
(2) Remove the fuse
(4) Unlock
(5) Replace fuse
Thanks Guys
I have the same warning just now, Its the 3rd time I have had it, each time caused by leaving the PWR switch on and draining the battery. I have not managed to find a way to fix it. Annoyingly when the car was at the dealers for the turbo hose repair they didn't clear the code! I only noticed after I had left. They also refused to reset the service interval as they hadn't done the service! The fault code reader can't come soon enough.
The last time I had this warning it cleared itself, I have no idea how. I had left the car parked at work for 5 days as I was working away from home. when I got back the code had gone!
