Diff breathers
  • Thread starter Thread starter RTG
  • Start date Start date
  • Featured
I bought a
Tube Colour: Blue
  1. Diff Breather Kit 4 point for INEOS Grenadier.(Front and Rear Diff, Transfer case, Gearbox)
  2. Diff Breather Kit 4 point for INEOS Grenadier.(Front and Rear Diff, Transfer case, Gearbox) - Image 2
Diff Breather Kit 4 point for INEOS Grenadier. I am after pic or suggestions where to mount it in the engine bay of my diesel Trialmaster. Thanks​
I bought a
Tube Colour: Blue
My bracket is mounted between the airbox and the fender, but @DenisM makes some good points here:
a picture worth a thousand words 😉
Only 2 positions have been used. The third I'd intended for either the transmission or the transfer case... at least being there I won't forget the "safe place" where other bits and pieces are sitting (somewhere🤔)
I used the same spot in the engine compartment for my breather kit. The related parts are from compressed air technology. The bracket is made of 50x50x3 mm aluminum and uses the existing fender screws. The 4-way air distributor can be easily removed, and each individual line can be blown out with compressed air.
The ZF transmission is currently not connected because I cannot access the connections on the transmission. To get there, you have to remove the front driveshaft.
If you place the breathers for the differentials on one side and the breathers for the gearboxes on the other side, this location is even better than my solution , provided you use plastic tubing.
Did you ever get around to connecting the transmission?
Im planning on doing the diffs but after a quick look into the tunnel the tranny breathrr wasnt very obvious so any pointers/ photos would be of great help.
Removing the front driveshaft doesnt sound as easy as tge front and rear diffs.
G.
G.
if you wait long enough it removes itself!
So far, I've only connected the differentials and the transfer case. I'm waiting to connect it to the ZF transmission until my front driveshaft fails and needs to be removed.😞 Accessing the breather is difficult without removing the front driveshaft. The transmission pictures show where the breathers are located. Both the standard transmission breathers and the diesel tank breather are identical. The transmission breathers are located at the rear of the engine. They can only be accessed by removing the body panel below the windshield wipers.
ps: a curiosity regarding the drive shaft: did you lift the grenadier?
So are the transmission breathers already piped to somewhere under the bonnet/ hood? And what are they currebtly terminated with?
G.
G.
You'll need to take a cut lunch and a compass to find the transmission and transfer case breathers between the engine cylinder head and the firewall. That'll make you @Grumpy!
Or use a boroscope (y)
I think @Greasemonkey's breather4 image is a boroscope pic from that location. I have rotated and deskewed it using AI so take it as a reasonable representation.
This view would be looking "through" the firewall on the right side towards the back of the engine. The cast exhaust manifold is visible on the right. The shiny alloy is the back of the head.
The rocker cover and top of the head is bent like a banana due to deskewing. It should be straight across. Don't buy your knock-off car parts from AI Autos.
A plastic breather and round cap is in the foreground.
Original pic credit to @Greasemonkey
Petrol. HP51 transmission.
Diesel. HP76 transmission.
I can't say for sure whether the photo was taken with a borescope or a mobile phone. I did manage to pull the transfer case breather up a bit with a wire once. The photo probably dates from that attempt. Even with a borescope, I couldn't get a clear view of the breather's mounting from either above or below. However, the workshop manual now shows exactly how the breathers are arranged.
I only connected the transfer case breather because the mechanics forgot to reattach the hose when they replaced the transmission.
The original mounting point for the transmission breather is already quite high. I suspect my connection only added a maximum of 10 cm. So, as long as you maintain the recommended wading depth, everything should be fine.
In the past, I've probably had more luck than sense when crossing rivers and fords. I wouldn't do that again today, especially considering how expensive a new engine is these days.
Furthermore, I found the YouTube videos by Ben Greggers, Tom Sunderland, and also the Cape York videos very informative, because they show how quickly an engine can be ruined.
We're always worried about how much dust can get into the engine through the RAI or a snorkel.
But it's also interesting to see how much water the engine sucks in during heavy rain.
The picture shows my INEOS idling. The paper towel I held in front of the RAI was immediately sucked in tightly. I don't even want to imagine how much dust or water gets sucked in there while driving.
In this Motor Oil Geek YouTube a Donaldson Filters technician talks about 20,000 litres of air passing through the airbox per one litre of diesel fuel. And, surface filters get better after some use so don't clean or replace them too often.
Finally got started on installing my Air Parts Australia diff breather kit today.
I mounted the supplied bracket on a Z bracket I folded from 20mm X 3mm aluminium flat bar. The bracket sits over the studs that secure the fuse box on the left side. There was a redundant mounting stud in the way that I took care of with a Dremel and a dab of black paint (it's hidden by the bracket). It looks like it was added to attach a clamp but it's not used.
I mounted my breathers upside down so if they get wet the water can drip out. I clean my engine bay and undersides regularly.
I'll install the axle fittings and plumbing tomorrow.
This is a 4-way kit but I'm not bothering with the transfer case or transmission. Both of the factory breathers are installed up high behind the engine. See my post earlier in this thread.
To mount breathers to the transmission and transfer case, it's major. Removing the tailshaft to then remove the transfer case. My transfer case front seal requires replacing a slow leak (under warranty), actually in a fortnight. Yes I have a July 2023 build. Must drive 900 kms to get it done as it's the closest accredited dealer mechanic.
I am told to get to the gearbox, you disassemble the shifter, remove all those covers maybe one seat to get to it. Yes it's major.
