Diff breathers
I bought a
Tube Colour: Blue
  1. Diff Breather Kit 4 point for INEOS Grenadier.(Front and Rear Diff, Transfer case, Gearbox)
  2. Diff Breather Kit 4 point for INEOS Grenadier.(Front and Rear Diff, Transfer case, Gearbox) - Image 2
Diff Breather Kit 4 point for INEOS Grenadier. I am after pic or suggestions where to mount it in the engine bay of my diesel Trialmaster. Thanks​
I bought a
Tube Colour: Blue
My bracket is mounted between the airbox and the fender, but @DenisM makes some good points here:
I used the same spot in the engine compartment for my breather kit. The related parts are from compressed air technology. The bracket is made of 50x50x3 mm aluminum and uses the existing fender screws. The 4-way air distributor can be easily removed, and each individual line can be blown out with compressed air.
The ZF transmission is currently not connected because I cannot access the connections on the transmission. To get there, you have to remove the front driveshaft.
If you place the breathers for the differentials on one side and the breathers for the gearboxes on the other side, this location is even better than my solution , provided you use plastic tubing.
Did you ever get around to connecting the transmission?
Im planning on doing the diffs but after a quick look into the tunnel the tranny breathrr wasnt very obvious so any pointers/ photos would be of great help.
Removing the front driveshaft doesnt sound as easy as tge front and rear diffs.
G.
G.
if you wait long enough it removes itself!
So far, I've only connected the differentials and the transfer case. I'm waiting to connect it to the ZF transmission until my front driveshaft fails and needs to be removed.😞 Accessing the breather is difficult without removing the front driveshaft. The transmission pictures show where the breathers are located. Both the standard transmission breathers and the diesel tank breather are identical. The transmission breathers are located at the rear of the engine. They can only be accessed by removing the body panel below the windshield wipers.
So are the transmission breathers already piped to somewhere under the bonnet/ hood? And what are they currebtly terminated with?
G.
G.
You'll need to take a cut lunch and a compass to find the transmission and transfer case breathers between the engine cylinder head and the firewall. That'll make you @Grumpy!
Or use a boroscope (y)
I think @Greasemonkey's breather4 image is a boroscope pic from that location. I have rotated and deskewed it using AI so take it as a reasonable representation.
This view would be looking "through" the firewall on the right side towards the back of the engine. The cast exhaust manifold is visible on the right. The shiny alloy is the back of the head.
The rocker cover and top of the head is bent like a banana due to deskewing. It should be straight across. Don't buy your knock-off car parts from AI Autos.
A plastic breather and round cap is in the foreground.
Original pic credit to @Greasemonkey
Petrol. HP51 transmission.
Diesel. HP76 transmission.
I can't say for sure whether the photo was taken with a borescope or a mobile phone. I did manage to pull the transfer case breather up a bit with a wire once. The photo probably dates from that attempt. Even with a borescope, I couldn't get a clear view of the breather's mounting from either above or below. However, the workshop manual now shows exactly how the breathers are arranged.
I only connected the transfer case breather because the mechanics forgot to reattach the hose when they replaced the transmission.
The original mounting point for the transmission breather is already quite high. I suspect my connection only added a maximum of 10 cm. So, as long as you maintain the recommended wading depth, everything should be fine.
In the past, I've probably had more luck than sense when crossing rivers and fords. I wouldn't do that again today, especially considering how expensive a new engine is these days.
Furthermore, I found the YouTube videos by Ben Greggers, Tom Sunderland, and also the Cape York videos very informative, because they show how quickly an engine can be ruined.
