I haven't contacted MB but I found one FS the correct width but no mention of offset.Is it the offset that's different?
There must be a wheel guy on this forum who can access the info.
I run MB vans at work, I may just have a swap over one afternoonI haven't contacted MB but I found one FS the correct width but no mention of offset.
Most I've seen are 6.5" widthI run MB vans at work, I may just have a swap over one afternoon
In steel?Most I've seen are 6.5" width
Yes I've watched John's videos from, the start, and just hoping they get there act together here in the UK, I think they need to back off promotion videos etc ,and backup existing customers, and all,that john highlighted in the video. From Steve near Chester England where the Roman's once lived.K video from John Canny, voicing moans a number of us will identify with.
I
His previous videos are worth a watch, including a van rollover and some recovery with a non-functioning winch and lockers.
View: https://youtu.be/QsKHs2g-Xiw
Can you find one in the same size?Isn't the steel rim exactly the same as from the Mercedes Sprinter? About 50 to 60 Euros....
The stud pattern is, but the rim is too narrowIsn't the steel rim exactly the same as from the Mercedes Sprinter? About 50 to 60 Euros....
AWo
Those 'grommets' as you call them so callously were hand made - each formed on the perfectly tanned thigh of a Brazilian Super Model from the rarest natural rubber, then were hand packaged and flown to Sweden where they were sung ancient Norse songs by local maidens while the finished white patina you see was perfected to look like they were decades old. Later, after a 3 week stay in Germany where engineers did the final assembly in pure carbon fiber resins they were packaged and delivered gently by DHL on a separate plane - 1 pack per plane mind you - with no other packages lest they be damaged. $18 each sounds like a bargainI share his pain on the parts. I paid £18.65 + vat each for rubber grommets for the auxiliary rads
View attachment 7844789and about £500 for a BFG tyre on a steel rim. I hope I get the TPMs valve View attachment 7844788for that price but not sure as yet.
Sounds like a dream job being 'quality control manager' at the very beginning of that processThose 'gommets' as you call them so callously were hand made - each formed on the perfectly tanned thigh of a Brazilian Super Model from the rarest natural rubber, then were hand packaged and flown to Sweden where they were sung ancient Norse songs by local maidens while the finished white patina you see was perfect to look like they were decades old. Later, after a 3 week stay in Germany where engineers did the final assembly in pure carbon fiber resins they were packaged and delivered gently by DHL on a separate plane - 1 pack per plane mind you - with no other packages lest they be damaged. $18 each sounds like a bargain
Just to clarify...a.f.a.i.k. the UN-ECE regulations apply in Australia. That means you're right, a high beam lightbar must go off with the cars high beam.I am also aware of cars that have been fitted with Light Bars that do not turn off with high beam, again a clear breach of the Australian Design Rules. Do Ineos care? Do they know?
Yes I was slightly surprised that the cargo barrier didn't meet Australian standards as well, But in my experience many manufacturer supplied barriers don't and if they do they are Australian sourced. With regard to trying to mount the barrier in the front do you mean that top barrier mounts won't fit into the forward top body slots or the lack of lower mounts?Ineos are definitely damaging the brand. All Johns issues are real and there are many more. Broken promise after broken promise.
My big gripe is that the Ineos Supplied cargo barrier does not comply with the Australian Standard for Cargo Barriers. I live in Australia, drive in Australia and have what i believe a reasonable expectation that my cargo barrier should comply with the AS. Inoes disagree. As a minimum i think we should have been told at time of purchase that the barrier does not comply with the AS. Again Ineos disagree.
Further the cargo barrier cannot be relocated from behind the rear seats to behind the front seats on a Trialmaster. The mounts provided look like they will fit but don't. This is the first vehicle i have ever owned where the cargo barrier can't be relocated. Built on Purpose, not a touring purpose with the rear seat folded.
All of these issues make me wonder what surprises are in store for us after a couple of years.
As a side note wait until you have to replace the batteries on a Trialmaster. I don't think Battery World will honour the free fitting service.
As a side note wait until you have to replace the batteries on a Trialmaster. I don't think Battery World will honour the free fittingThere is a demonstration somewhere either on the forum or FB on how to remove the barrier.Yes I was slightly surprised that the cargo barrier didn't meet Australian standards as well, But in my experience many manufacturer supplied barriers don't and if they do they are Australian sourced. With regard to trying to mount the barrier in the front do you mean that top barrier mounts won't fit into the forward top body slots or the lack of lower mounts?
I'm still working how to remove the damm barrier without using 4 hands though. My car is at the dealers getting another round of warranty niggles looked at. I've asked them to demonstrate removing the barrier when I pick up the car. It will be interesting to see.
Cheers
Steve
I was under no impression that the barrier would comply with ADRs, as there was no literature to state that it would
Steve,Yes I was slightly surprised that the cargo barrier didn't meet Australian standards as well, But in my experience many manufacturer supplied barriers don't and if they do they are Australian sourced. With regard to trying to mount the barrier in the front do you mean that top barrier mounts won't fit into the forward top body slots or the lack of lower mounts?
Cheers
Steve
