AUSTRALIA: Third Party Suppliers for the INEOS Grenadier and QM
Links updated:
AIRBAG SUSPENSION
  1. Airbag Man suspension for the Grenadier and QM, both come in standard and 2 inch lift kits. QM kits here and Grenadier Kits here; and
  2. GrenX Polyair Grenadier Ultimate Airbag Suspension Kit here; and
  3. Polyair Grenadier Kits here. Standard and Lift Kits. Also available from PSR here.
SUSPENSION FOR THE GRENADIER
  1. Heasmans (Sydenham Sydney) can can do Polyair airbags, Bilstein suspension and wheel alignments;
  2. Bilstein B60 shocks now released in Australia, look here;
  3. JMACX Alpha suspension (manual adjustment suspension kit here. Electronic model also available here) and GVM upgrades for IG and QM;
  4. Eibach 35mm Pro Lift Kit, look here (Standard, Heavy Duty and Extra Heavy Duty springs available);
  5. Eibach 35mm Pro lift kit/King Shocks package, look here;
  6. Eibach with external reserve oil reservoir here (IG and QM);
  7. Eibach anto roll bar kit here (IG and QM);
  8. King Shocks Set (4), look here;
  9. GrenX has a full suspension upgrade solution using Eibach springs, custom Bilstein shocks, Bilstein steering damper & rear air bags by Poly Air, look here;
  10. AIRBAG MAN suspension for the INEOS Grenadier here;
  11. Dobinson lift kit under development, look here (DMW uses Dobinson);
  12. SOLVE Offroad using Fox shocks and Eibach springs. Review here by @Braydo;
  13. LeTech Suspension system lift + 40mm (nearly AUD15,000);
  14. LeTech coil springs +40mm;
  15. Oleo-Pneumatic suspension for the INEOS Grenadier, shipped from France, also available at GrenX in AU;
  16. Tough Dog suspension, springs and dampers here;
  17. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITH winch;
  18. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITHOUT winch; AND
  19. Some US suspension options being discussed here.
SUSPENSION - GVM UPGRADE AU
  1. Expedition HQ GVM upgrade to 3800kg (Pre and Post Registration, but check), QLD registered cars only. EDIT: NSW GVM upgrade not possible at present;
  2. JRace Industries GVM upgrade to 4,000kg (Pre-registration) including rear axle capacity increase (Townsville Qld). Email: info@jraceindustries.com.au
  3. MORE4X4 GVM upgrade to 4,000kg (Pre-registration) here;
  4. DMW GVM upgrade to 3,900kg (Post registration) here; and
  5. Three GVM upgrade options for the Grenadier and QM from DMW here. More information on the kit here.
I needed to post my experience of the Australian manufacturer ISI carriers and the Grenadier specific Ebike rack.
Following my dealings wiith Broder at ISI Carriers, the Australian made bike racks.
I was put onto by someone on the site
They make cycle racks that are capable off road and a specific attachments for the Grenadier. Although I would never need for off road the way they are attached and extra ability gave me far more confidence than using the standard ones that clamp to a towball plus they give so much more ground clearance so not scraping on anything. Weight of 2 Ebikes just seems too much for just clamping to a towball on the current state of UK roads.
The cost including delivery and taxes to UK worked out slightly cheaper than what I perceived to be an inferior THULE item, so that was a plus. I have used once to take the bikes to the shop for their first free service and it was solid. I then knew how it worked and made notes of the torque levels on the bolt attached to the vehicle. so, couple of days ago I was just putting it on temporary but then decided to tighten up properly. Holding in the attachment that fits into the 50mm square of the tow bar is a long bolt. On the far side of the bolt is a support nut and safety pin which i hand tightened. I then decided to leave on and tightened the bolt up but did not remove the support nut. Obviously the thinner part of the bolt where support nut is attached tightened and went ping. I explained to Broder at ISI that I was an idiot and asked for an invoice for replacement part and shipping to UK. He replied with a bill of £29 for shipping only and said part was covered under their warranty. Every time I emailed i had a reply the following day on my computer back in the UK
I am posting this because I have had such good service from an Australian company that has supplied someone in the UK and it needs to be highlighted somewhere. I admitted it was my fault and asked to pay but was not charged.
It also needs to be highlighted how good a product this is.
I highly recommend and even though I'm in the UK the backup support is still there.
When purchased the delivery was also quick.
I hope that all makes sense, it did in my head.
Anyway, big thumbs up to http://www.isi-carriers.com/ and Broder Lackmann
Reactions: CRH
NEW QM TRAY (AU)
XSPEC tray for the QM, it looks nice on the Expedition HQ Black OPs Special Edition:
Specifications​
  • Powdercoated Dulux Pro Texture Black
  • 1 piece folded headboard
  • 4mm flush tray decking
  • 3 x Unistrut built into tray for tie down mounts (sides / middle)
  • Rear underbody aluminium toolboxes
  • Custom rear bumper bar with factory sensors
  • 1200mm rear under drawer with 225kg runners
  • Lockable fuel filler
  • Chassis mounts
  • 316 Stainless Steel bolts
  • XSPEC Mudflaps
  • LED Tail lights
  • 60L Stainless food grade water tank
  • 12v pressure water pump
  • John Guest Hose & Connectors
  • Flush mount water outlet each side
  • Flush mount anderson plug in headboard
  • Price includes fitting, plumbing and wiring.
Optional:
  • Sideboards & Hardware, Powdercoated
  • Custom canopy available on request
Here is the Expedition HQ Black OPs Edition, as shown immediately above:
Key Features​
  • XSPEC Black Ops Quartermaster build
  • XSPEC heavy duty aluminum tray system
  • Integrated tray storage and toolbox configuration
  • Under tray storage solutions
  • Integrated water tank system with pump
  • Dual water outlets for practical use
  • SSM 4.2T GVM Upgrade for Australia wide delivery
  • Suspension lift, King Remote Res Shocks, rear Airbags
  • Improved load carrying and off-road performance
  • Optional Nappa Leather Interior
  • Heavy duty touring and work-ready setup
  • Designed for Australian conditions
The Expedition HQ Black OPs Special Edition specs seem a bit vague. However, the tray's specs are specific in the link given above.
TANKS – WATER AND FUEL
  2. Leitner Designs Jerry Can Holder here (if you put 2 holders on one side, the combined weight exceeds INEOS specs);
  3. DUNN & WATSON water tanks here;
  4. The generic Jerry can used for fuel and water is commonly available. They can be carried inside the car (water), on the roof rack or molle panels on the car;
  5. PAK Offroad has a water tank for the footwells in the rear, or a new roof rack mount with recovery tracks called the RACKTANK (unknown if the TUBTANK or Wheel arch tank can fit into the QM tub); (thanks to @globalgregors and @Rok_Dr). Warning QM owners: this tank may not fit into the rear foot well of a QM. Please confirm before buying;
  6. VAAST has range of water tanks that can be mounted on a roof rack, inside the car or on Molle Panels;
  7. ONTAP Portable Shower, Original here , Black Limited Edition here;
  8. BOAB Offroad has fuel and water tanks, look here; and
  9. ORS can fit stainless steel water tanks (including for the Grenadier, I have one installed), look here;
  10. Headspace Campers are working on 90 litre water tanks (January 2026) under the car on both sides, giving 180 litres in total. See video here.
Recent Lightforce ad.
Number plates on the Suzuki is South African. I cannot read the words on the IG's number plate frame. It looks simialr to an Offroad Animal Predator bumper, but a little bit different, with no hoop.
