AUSTRALIA: Third Party Suppliers for the INEOS Grenadier and QM
Links updated:
AIRBAG SUSPENSION
  1. Airbag Man suspension for the Grenadier and QM, both come in standard and 2 inch lift kits. QM kits here and Grenadier Kits here; and
  2. GrenX Polyair Grenadier Ultimate Airbag Suspension Kit here; and
  3. Polyair Grenadier Kits here. Standard and Lift Kits. Also available from PSR here.
SUSPENSION FOR THE GRENADIER
  1. Heasmans (Sydenham Sydney) can can do Polyair airbags, Bilstein suspension and wheel alignments;
  2. Bilstein B60 shocks now released in Australia, look here;
  3. JMACX Alpha suspension (manual adjustment suspension kit here. Electronic model also available here) and GVM upgrades for IG and QM;
  4. Eibach 35mm Pro Lift Kit, look here (Standard, Heavy Duty and Extra Heavy Duty springs available);
  5. Eibach 35mm Pro lift kit/King Shocks package, look here;
  6. Eibach with external reserve oil reservoir here (IG and QM);
  7. Eibach anto roll bar kit here (IG and QM);
  8. King Shocks Set (4), look here;
  9. GrenX has a full suspension upgrade solution using Eibach springs, custom Bilstein shocks, Bilstein steering damper & rear air bags by Poly Air, look here;
  10. AIRBAG MAN suspension for the INEOS Grenadier here;
  11. Dobinson lift kit under development, look here (DMW uses Dobinson);
  12. SOLVE Offroad using Fox shocks and Eibach springs. Review here by @Braydo;
  13. LeTech Suspension system lift + 40mm (nearly AUD15,000);
  14. LeTech coil springs +40mm;
  15. Oleo-Pneumatic suspension for the INEOS Grenadier, shipped from France, also available at GrenX in AU;
  16. Tough Dog suspension, springs and dampers here;
  17. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITH winch;
  18. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITHOUT winch; AND
  19. Some US suspension options being discussed here.
SUSPENSION - GVM UPGRADE AU
  1. Expedition HQ GVM upgrade to 3800kg (Pre and Post Registration, but check), QLD registered cars only. EDIT: NSW GVM upgrade not possible at present;
  2. JRace Industries GVM upgrade to 4,000kg (Pre-registration) including rear axle capacity increase (Townsville Qld). Email: info@jraceindustries.com.au
  3. MORE4X4 GVM upgrade to 4,000kg (Pre-registration) here;
  4. DMW GVM upgrade to 3,900kg (Post registration) here; and
  5. Three GVM upgrade options for the Grenadier and QM from DMW here. More information on the kit here.
I needed to post my experience of the Australian manufacturer ISI carriers and the Grenadier specific Ebike rack.
Following my dealings wiith Broder at ISI Carriers, the Australian made bike racks.
I was put onto by someone on the site
They make cycle racks that are capable off road and a specific attachments for the Grenadier. Although I would never need for off road the way they are attached and extra ability gave me far more confidence than using the standard ones that clamp to a towball plus they give so much more ground clearance so not scraping on anything. Weight of 2 Ebikes just seems too much for just clamping to a towball on the current state of UK roads.
The cost including delivery and taxes to UK worked out slightly cheaper than what I perceived to be an inferior THULE item, so that was a plus. I have used once to take the bikes to the shop for their first free service and it was solid. I then knew how it worked and made notes of the torque levels on the bolt attached to the vehicle. so, couple of days ago I was just putting it on temporary but then decided to tighten up properly. Holding in the attachment that fits into the 50mm square of the tow bar is a long bolt. On the far side of the bolt is a support nut and safety pin which i hand tightened. I then decided to leave on and tightened the bolt up but did not remove the support nut. Obviously the thinner part of the bolt where support nut is attached tightened and went ping. I explained to Broder at ISI that I was an idiot and asked for an invoice for replacement part and shipping to UK. He replied with a bill of £29 for shipping only and said part was covered under their warranty. Every time I emailed i had a reply the following day on my computer back in the UK
I am posting this because I have had such good service from an Australian company that has supplied someone in the UK and it needs to be highlighted somewhere. I admitted it was my fault and asked to pay but was not charged.
It also needs to be highlighted how good a product this is.
I highly recommend and even though I'm in the UK the backup support is still there.
When purchased the delivery was also quick.
I hope that all makes sense, it did in my head.
Anyway, big thumbs up to http://www.isi-carriers.com/ and Broder Lackmann
