Ask INEOS - Does the Grenadier Have ETC?
Glen
8:38 PM
Golden, CO
Because the published documentation is lacking, I sent Ineos the following letter:
Ineos,
I purchased my 2025 Grenadier Trialmaster in October, 2025. In addition to the standard center locking differential, my vehicle is equipped with optional front and rear locking differentials.
I'm writing to ask for an operational description of an "Electronic Traction Control" system (ETC), if such a system is fitted to my vehicle or any other models. I suspect this system may exist and, when applied to an open differential, provide a result similar to a limited slip differential. Specifically, I'm interested in:
  • Does an ETC system exist in all Grenadiers / Quartermasters?
  • Is ETC a separate system or is it part of another system?
  • What mechanism does ETC employ to intervene?
  • What conditions prompt ETC intervention?
  • What circumstances will defeat the ETC system?
To rule out other topics, I have found appropriate documentation in my owner's manual for these other systems that may activate the brakes: ABS, ESC, AEB, Downhill Assist and Uphill Assist. But the documentation that I can find about an ETC system seems ambiguous. Please understand I'm not writing to quibble about grammar - I'm only seeking to learn more about the systems present in my vehicle.
Here are the resources I've located and what they say about the possibility of an ETC system:
Window Sticker
The window sticker for my vehicle lists "Automatic Traction Control" under safety equipment and is similar to the term ETC. The term "Automatic Traction Control" does not seem to appear in the owner's manual or in the online Grenadier technical manuals.
Owners Manual
The manual provided with my 2025 Trialmaster notes on page 11 that it ". . . addresses features that were available for ordering on a 2024 Grenadier for the United States market." This implies the features offered in 2024 are identical to those offered in 2025.
The only reference I can find in the owner's manual to something like ETC is found on page 138 under the heading Traction Control. The complete entry says "Traction control senses when a wheel is slipping during acceleration. It can reduce torque to a wheel to reduce the risk of such slipping." Note that this entry says traction control only operates during acceleration.
I believe this definition of Traction Control is incorrect. The Trialmaster cannot selectively reduce torque to an individual wheel. With an open differential, both axle shafts always receive equal torque. If the lower-traction wheel is braked, the resistance increases and the differential transmits more torque to both wheels. This may reduce or stop wheel spin.
Ineos Online Resources
I don't find any mention of an ETC system in the online Grenadier technical manuals.
I did find mention of an ETC system in an Ineos marketing page under the heading Grenadier vs the Desert (see https://ineosgrenadier.com/en/us/the-vehicle/testing-and-development). Here's the relevant text for that entry:
  • "Electronic Traction Control (ETC) monitors wheel slip. And selectively applies brakes to regain traction. But traditionally, ETC doesn’t cope well on sand. Overcompensating and cutting power to wheels it thinks are slipping. So we did as we always do in every testing location: drive, calibrate, repeat. Until the Grenadier’s ETC learned the constantly shifting characteristic of dunes – diff-locks engaged or not. Allowing sufficient wheel slip to maintain momentum keeping the Grenadier on top of the sand."
What's odd here is that the owner's manual specifically recommends turning ESC (not ETC) ". . . off to prevent traction control cutting power to the wheels on certain surfaces (e.g., in sand)" See the owner's manual, Driving On Road | Electronic Stability Control, page 139. So the interaction between ESC, "traction control" and a potential ETC system seems very muddied.
Information Provided By the Dealer
I contacted the service department of Red Noland Ineos in Colorado Springs, Colorado to ask about this issue. The service manager said he had driven a 2023 Grenadier without locking front or rear differentials and that automatic individual wheel braking was employed to simulate a limited slip differential in some low traction situations. He continued that it took some number of revolutions of a spinning wheel before the feature would activate. Finally, he suspected - but did not know for sure if - this feature was present on subsequent model years since it wasn't documented very well.
Any information you can provide regarding an ETC system would be very much appreciated by myself and others in the Ineos community.
They replied several weeks later with the following:
Thanks for contacting INEOS Automotive.
Thank you for your questions regarding the Electronic Traction Control (ETC) system on the Grenadier and Quartermaster models. Please find our detailed responses below.
1. Does an ETC system exist on all Grenadier and Quartermaster models?
Yes, an Electronic Traction Control system is fitted as standard on all Grenadier and Quartermaster models.
2. Is ETC a standalone system, or is it integrated as part of another system?
The traction control function is not a standalone system. It operates as part of the vehicle’s Electronic Stability Control (ESC) system. In other words, ETC is a functional element within the broader ESC architecture, working in coordination with other stability and safety features.
3. What mechanism does ETC use to intervene when wheel slip occurs?
When wheel slip is detected, the system intervenes using a combination of brake torque control and powertrain control.
Brake torque control applies braking force to the slipping wheel to restore traction. Powertrain control adjusts engine output to reduce excessive wheel spin and help stabilize the vehicle. These interventions work together to maintain traction and improve vehicle stability across varying driving conditions.
4. Under what conditions does ETC activate?
ETC activates when excessive wheel slip is detected by the wheel speed sensors. The system continuously monitors the rotational speed of each wheel, and when it identifies a significant difference indicating loss of traction, it automatically intervenes to correct it.
5. Are there circumstances in which the ETC system can be overridden or disabled?
Yes, there are specific conditions under which the ETC system can be overridden or disabled, depending on the selected driving mode or driver input. This is typically intended for particular off-road or low-traction scenarios where a different traction strategy may be preferred.
Should you require any further technical clarification, please let us know and we will be happy to assist.
Best regards,
INEOS Automotive Customer Care Team
So they answered most of the questions. Item 5 could probably use some further clarification. A sixth obvious question would be why not harmonize the terms used on the windows sticker, promotional materials and the owner's manual. And a seventh might be why not put this information in the owner's manual?
I could have answered this, as well.
ESC is mandatory in the EU since 2014. ETC is a necessary subsystem so that ESC can do its job. So ESC always includes ETC.
AWo
AWo
We could have a separate thread : "Ask AWo" 🫠
Sort of a happy "Agony Aunt" to help us with our Grenadier relationship issues 😀
AWo
It's not that I'd discount your information, it's that Ineos should be documenting this system in a clear, unambiguous manner and - at the very least - in the owner's manual. At least until their response to my inquiry, that doesn't seem to be the case.
We've had several discussions on this forum where various members debate the existence of ETC. A video series on Robert Pepper's YouTube channel has often been cited as evidence of the existence of a Grenadier ETC system, but all I found was Robert saying something along the lines of "...oh look, the ESC isn't engaging..." when he expected it to. So that's not very convincing evidence.
To be fair, the Ineos team does usually go the mile when asked such questions. By and large the support team seems to be well incentivised to actually do something.
All fine....I just wanted to make clear, that ESC and ETC go hand in hand. It is an absolutely legitimate question to ask how and when ETC jumps in while offroading....
AWo
I sent Ineos a follow-up letter:
Ineos,
Thank you for your detailed response. It is very helpful in understanding how the ETC system works in my Grenadier. There is one aspect of your reply for which I request additional clarification.
You said . . .
You've answered yes to this question, but I'm still lacking the details I'd need to understand how ETC affects operation of the vehicle. Can you provide more information? For example:
5.a How does locking the center, rear or front differentials affect operation of the ETC system?
5.b. How does enabling "Offroad Mode" affect the ETC system?
5.c. For vehicles without rear and front locking differentials (or the differentials are unlocked), how can the driver best use the ETC system to overcome a spinning wheel that has little or no traction? To put it another way, how can the driver intentionally invoke the ETC system to simulate a limited-slip or locked differential? Should the center differential be locked or unlocked in these cases?
5.d. The owner's manual states that engaging "Offroad Mode" will result in "delayed ESC intervention." Is the response simply delayed, or is it delayed and of a different character? If it's of a different character, please describe the difference compared to "Offroad Mode" not enabled.
I very much appreciate your time and effort devoted to a reply.
@AWo - here's your chance to beat them to the punch and explain how this all works :)
In the case of intentionally trying to invoke the ETC system as a substitute for a locked differential, I'll be especially interested to hear their reply. All the videos I've seen where the author is trying to invoke ETC with an unlocked diff seem to result in little to no intervention and are inevitably followed by the comment ". . . a locked differential works a lot better . . . " I'd expect a locked diff works better, but for owners who didn't get the locking diff option, the answer to this question should be illuminating.
I received a reply from INEOS regarding my request for additional clarification. Here are their answers:
Q - 5.a How does locking the center, rear or front differentials affect operation of the ETC system?
A - "I have been advised to direct you to the table in the attachment for clarification on this point."
Q - 5.b. How does enabling "Offroad Mode" affect the ETC system?
A - No direct answer, although the attached table should help with an answer.
Q - 5.c. For vehicles without rear and front locking differentials (or the differentials are unlocked), how can the driver best use the ETC system to overcome a spinning wheel that has little or no traction? To put it another way, how can the driver intentionally invoke the ETC system to simulate a limited-slip or locked differential? Should the center differential be locked or unlocked in these cases?
A - "This system uses inputs to determine when it is required and will activate as necessary. It operates autonomously and requires no driver intervention."
Q- 5.d. The owner's manual states that engaging "Offroad Mode" will result in "delayed ESC intervention." Is the response simply delayed, or is it delayed and of a different character? If it's of a different character, please describe the difference compared to "Offroad Mode" not enabled.
A - "This point delves into the characteristics and behavior of the system at a software level, which is considered proprietary information (IP). Therefore, I would recommend referring to the user manual and accompanying information for further details."
INEOS attached a table in the form of a .png graphic of very low resolution - so low that it is difficult to read. Some text is obscured by red highlighting directing my attention to entries for TCS. I have transcribed the table into a PDF document that should be more readable. I kept the format the same and provide two versions - one with the abbreviations in the left-most column and another with the definition of those abbreviations in the left-most column. I have attached all three documents to this post. If you can see any errors in the transcription or more likely candidates where I had to guess (see the notes in the Abbreviation / Definitions table), then let me know.
  • INEOS ESC options ABBR.pdf
  • INEOS ESC options VERBOSE.pdf
The most significant thing that strikes me after looking at the ESC Function Matrix is that saying a vehicle has Electronic Stability Control or Electronic Traction Control is a bit like saying "I've got some wood products in the shed." Those wood products could be lumber, bark mulch, toilet paper, maple syrup, drum sticks, a bolt of rayon fabric . . . a universe of things that "wood products" alone doesn't describe with any utility.
If you're trying to understand how the Grenadier operates, the function matrix opens up a whole new can of worms. While many of the terms are somewhat descriptive, like "Brake Temperature Model", other terms like "Vehicle Dynamics Control" give no hints as to when and how they might affect driver inputs. Sure, I can guess just like you, but that's not information, it's speculation.
The other thing that seems important is that the matrix lists about 20 different subsytems that can modify driver input. If you were into building and setting up your own computers prior to about 2005, you probably remember the concept of an IRQ. Hardware devices were assigned a number in the BIOS from 0 - 15, with lower numbers getting higher priority. So if a keyboard (IRQ 1) and a mouse (IRQ 12) tried to provide input at the same time, the keyboard input would be accepted and the mouse input would be ignored (during that clock cycle of the system timer). If I were designing an ESC suite with 20 subystems like we have in the Grenadier, I'd probaly do something similar to an IRQ so that one system wouldn't negate the input of another. For example, rollover protection might get a higher priority than understeer correction. The alternative to an IRQ-like strategy would be to model (and adjust) the mixing of 20 different system inputs, whether it be one, two, three or all 20 of the systems trying to modify the vehicle behavior. The number of combinations there would be 2^20 - 1 = 1,048,575, so that doesn't seem reasonable. Even if I'm wrong and there are really only 10 subystems, that's still 1,023 combinations for which you'd need to evaluate mixing. However it's done, the ESC system as a whole seems like it represents a level of complexity that transcends a regular human's ability to really comprehend what's going on at any particular moment. That might explain some of the vague or even slightly evasive answers from INEOS . . . they're not able to explain exactly what's going on because all the possible interactions haven't been explicitly mapped out.
Finally, do you want to defeat the largest portion of ESC? Select Low range, lock the center and rear axle diff and you've turned off everything that can be turned off.
Reading this makes me long for the volvo 240DL wagon I learned to drive on. You can do whatever you want, but you better understand physics, because it always wins. No Nannie’s. I learned a lot in that car in icy parking lots. The car was nice and slow.
I think I liked simplicity too - time will tell as I get more experience with the Grenny. I drove my '72 VW Bug (no electronic nannies) and my '93 Toyota 4Runner (rear axle ABS only) through some pretty crazy winter conditions, and driver technique made a lot of difference. With the Grenny, I have to wonder if my inputs will make it to the road or if they will be countermanded by the many and opaque ESC systems.
