35's with the Eibach 2.5" lift...
The Kahn wheels are 20 inch.
I think that still applies, as the outside diameter and width will be roughly the same just with a few inches less sidewall. The issue on stock suspension starts with tire width once diameter gets to around 34 real inches. Narrow tires (like 9.5-10") can fit at 34.5" diameter, but the wide boys will rub at full lock and under any kind of compression
I can't seem to get a straight answer either through searches online or through Eibach. I just wanna know if I can get 35 x 12.5 tires to fit with the Eibach 2.5 inch lift springs with no trimming or rubbing. Just a Yes or No please...
I pick up my rig tomorrow... so excited!!
New to hear. Just put the 2.5 eibach spring lift with fox series 2.0 shocks on my Quartermaster and it fits a 35x12.50R18 perfectly with no rubbing backwards or forwards and have been articulating off-road so you should be golden. I kept mine on the stock rims and put 33mm spacer on rear and waiting for 25mm spacer for the fronts.
These are the latest pics of the Eibach 2.5 lift with the BFGoodrich mud 35’s. Took it for extensive test drive at speeds over 80 mph. It actually drives and handles better than before.
Off topic but winch is in your stock bumper and did you use a hidden winch kit?
I just lifted mine with the Eibach lift, New 17" Reika bronze wheels, and Toyo AT3's - 285 75 17. No rubbing. I also added a 5th tire to the spare tire carrier. The door still opens fine with only about 1/4" to spare. The backup camera is slightly blocked with the larger tire, but not too bad. These are 33.9" OD x 11.3" wide. View attachment 7852355
What lift do you do? Is it just the leveling kit at 1.2" or is it the 2.5 front 1.2 rear kit?
I spy with my little eye... NAS DEFENDER 90 :p
(Oh I wish I made more money, your toy budget is much better than mine)
These are the latest pics of the Eibach 2.5 lift with the BFGoodrich mud 35’s. Took it for extensive test drive at speeds over 80 mph. It actually drives and handles better than before what offset did you go with on your wheels? I just all my components delivered and trying to make sure I have everything right. Went with a +32mm offset and going with 35x12.5x18 Toyo open country A/T’s
