35's with the Eibach 2.5" lift...
The Kahn wheels are 20 inch.
I think that still applies, as the outside diameter and width will be roughly the same just with a few inches less sidewall. The issue on stock suspension starts with tire width once diameter gets to around 34 real inches. Narrow tires (like 9.5-10") can fit at 34.5" diameter, but the wide boys will rub at full lock and under any kind of compression
I can't seem to get a straight answer either through searches online or through Eibach. I just wanna know if I can get 35 x 12.5 tires to fit with the Eibach 2.5 inch lift springs with no trimming or rubbing. Just a Yes or No please...
I pick up my rig tomorrow... so excited!!
New to hear. Just put the 2.5 eibach spring lift with fox series 2.0 shocks on my Quartermaster and it fits a 35x12.50R18 perfectly with no rubbing backwards or forwards and have been articulating off-road so you should be golden. I kept mine on the stock rims and put 33mm spacer on rear and waiting for 25mm spacer for the fronts.
