General Transmission Neutral Lever - Tool
samnt650
3:35 AM
More of FYI - lever help put the transmission out of Park. This is for emergency use. Can only hope someone figure out how to turn it into an assessory that we can install on the truck....
Mentioned before. Crazy price.
You can put the vehicle TC in neutral as long as you can start the vehicle enough to get the trans in N. Carwash mode etc.
If you drive into a large puddle/river/sea without a snorkel and grenade the engine, well the above tool might help you if not your engine.. If you have a winch or someone close by has.
Or.....hear me out, you can use some wire or even zip ties. There is a lever on the side of the transmission that you simply pull down and the trans goes into neutral.
Except in a fast flowimg river at night!
Well, that's when you use the T-case lever. You aren't using the aforementioned kit in a fast flowing river either. Well some people on here might try. 😂
Yes, the T case lever works , well once you've learnt the secret handshake, and can remember what to do in the heat of the moment if the shite hits the fan 🙃
