- Local time
- 4:56 AM
- Joined
- Nov 14, 2021
- Messages
- 1,176
Conversation moved from "Largest Functional Tire Without Mods"
This is a reply to @Tenac who wrote:
"My performance shop that works with a transmission shop. They built my ZF in my M8 before, they called their rep with ZF there isn't a factory upgrade clutch kit like many have. The one in the Ineos stems from the same one used on the V12 7 series of old 50series but its gen3. 8HP51 which base starts at around 380-400tq numbers. There are a few aftermarket companies that can build kits but I'm not hunting that down, since there seems to be no need. However this transmission rocks 4 gear sets and 2 brakes and 3 clutch packs. ZF states this gen three is considered their heavy duty model, hence when we tried to source a higher pressure clutch packs they don't offer any they are already their higher pressure packs. Sorry I thought this stuff was well known should have considered adding a bit more detail in the first post. But basically as I build my cars and now SUV
I always try to understand what potential week links there are, with automatic transmissions 100% of the time its the clutch packs which are somewhat easy swap for a good shop and you can take a limited say 500tq transmission to well over 1000tq for couple grand well add labor too."
As most folks know, the transmission mated to the B58 (gas engine) is the ZF 8HP51 (3rd Gen). Its a great transmission, but the max torque rating on this version of the ZF 8-speed is 500 nm or 369 lb-ft of torque (I read this in a technical manual on the 8HP51, but I cannot find that now, so here is a link to the Wikipedia page which says the same: https://en.wikipedia.org/wiki/ZF_8HP_transmission). While there are aftermarket upgrades to the ZF 8HP51 that increase its torque rating (e.g. Pure - ZF 8HP 51 Stage 1 Transmission Rebuild), I have not seen any information that indicates that the stock transmission in the Grenadier has been equipped with any upgrades. I'd love to be wrong about that, but could you provide a source to your info that says that the ZF 8HP51 in the Grenadier has a higher torque rating than 500 nm (369 lb-ft). Thanks!
