Wolfbox external camera mount
Silverjay
3:49 AM
Nevada
Just picked up the truck from getting the Wolfbox installed. The camera was mounted just above the license plate with a bracket using the top 2 lic naw mounting bolts. It. Vibrates easily and makes the image jump alot. Is this a common mounting location? Is there a better external spot?
Are you referring to the front? Or back? The rear is best inside rear large door window, close to center. For the front, the consensus seems to be the center of the middle horizontal grill slat. Lots of pics available of installs on the forum. Search wolfbox install
Unfortunately the back. I see where most of the install have gone in the inside. I didn’t specify and got what I think is a mess.
