Wolfbox 900 Pro 3 Camera install - Fast and Easy
hightechcoonass
9:46 PM
Here I installed a new Wolfbox 900 pro... I did the installation in a less conventional way. Ran it under the truck...
I figured if I needed to go under the truck with the front camera, I would do the rear camera the same.
Notes- I used alien tape to secure the cameras-
I mounted the 3rd camera on the front grill (camera 1 in the mirror, camera 2 inside the top of the rear window)
I did not use the red power trigger that pops up the reverse camera with the hatch lines.
The unit has voice recognition. "Show rear camera." crazy cool
A few people on YouTube mentioned the first upgrades one needs. I agree on this one!
It has a WIFI high-speed app where one can connect and record to their phone, another super cool feature.
Ok lets start.....
I saw a guy on an Owl Overland video run power to his electric running boards via the hole in the floorboard under the pad. That port exits right under it TO A SECOND PLUG near the driver's body mount. So I drilled holes through the two rubber plugs for my wiring.
I use a 1/4 plastic tubing as a fish tape...
See here, I pushed the tubing through the floor plugs and used it as a fish tape.
Here is the plug on the other side....
Here the wire is ran through the plug ... While I was running wires, I added a red and black for future lights.
First pull the jam plate up (no screws) and the foot rest plate (no screws just pull up)
I then pulled the kick plate on the left, removed two screws (black wood screw for the hood lever, grey wood screw holds the panel on), one 10 mm nut on the fire wall, and one 10 mm bolt on bottom near the jam plate.
I ran the wire under the factory harness (not shown), and then next to the hood latch, then up the crack.
(I removed the door seal rubber and installed the wire through the crack)
I tied the power into the Aux switch 1 wires that were taped to the main harness using lever nuts.
(I used the USBC power module instead of the lighter scocket plug)
Here you can see the power module tucked behind the plate (white dot QC sticker on it)
Once I got to the back it the truck, I went through the same rubber plug that I wired my boat trailer module through....
Once in the truck, I ran a wire through the hole behind the light and then to the bottom rear door rubber hose interconnect.
You can see the hole I made... I ran the cable on the outside. Is it possible to run it existing rubber hose, but it is really , really tight so I went aroung the outside.
I used a little soap to reinstall the grommets (super easy)
I later realized there was no need to power the red. I did not want the reverse trigger to show the back reference marker on the screen.
Just for now, I jumped over the lower to upper door grommet and ran the wire on the outside. I will fix this this week when I have a little more time.
Jumping back to the front, I removed cap, then the screw here to run the 3 wires behind the A piller trim piece. (front camera, rear camera via USB-C, and USB-C power module feed cable)
Thanks ... I will do it eventually. I am a retired Controls Systems Project Engineer Wiring was one of our weekly task ,and was running low on patience.
BTW- The unit I have is the G900 TriPro - It should be on sale for Amazon Prime Days in July!
Here is a picture of the camera mounted on my front grill. ( I ran the wire on the inside of the frame, attaching it to the tranny cooler lines and mounting clips).
Link to the tape I used to secure the cameras
Of course, I loss sleep knowing that I ran the wire outside the back door, so I had to fix it this morning.
If you notice here this grommet includes the water line for the rear washer. I did not want to compress it in anyway, so I put a split in it to run the camera wire.
I then re-wrapped it with the cloth tape I removed.
Because the hose runs through the rubber hose, I left this cable as is. I did not want to disturb the washer hose...
This pic of the door panel may help folks to understand where the clips are and how and where to apply pressure when removing. It clips on the tiny studs in the window frame. Here you can see I re-wrapped the grommet with the cloth tape. I need to buy some, it's perfect to stop things from rattling when adding connectors, or anything in a closed door..
the finished door... I can rest now...
Nice work. Would be interested to see what the view looks like from that rear and front camera, on your mirror.. any pics?
I’ve just installed mine today (pics attached). The rear view is darker (it’s through tinted glass after all) but bright and clear enough for its purpose.
Install issues:
I passed the wire through the ducting at the bottom of the back door. The wiring loom on the door end of the ducting had been sealed in with a generous quantity of latex which ‘cured’ as it was exposed to air. I had to cut around this to allow the rear camera wire to pass whilst protecting the integrity of the grommet.
The OEM mount won’t fit on the metal plate glued to the Grenadier’s windscreen. Wolfbox are sending a replacement metal plate but I have no clue how (or if I want) to remove the original mount.
When the Wolfbox is strapped to the rear view mirror the USB connections impinge on the airbag warning binnacle so they’re slightly under tension. I’m concerned that this will weaken the connections over time.
Overall, a fantastic bit of kit that seems to be well made. I’ve still got the front bumper camera to install but that’s for another day.
FWIW: The rear camera wire will pass through the rubber boot with the help of a wire snake and some silicone spray w/o damaging anything. Just have to detatch the boot from both ends, cut the tape on the door-side of the boot to expose the boot opening (I re-wrapped with TESA tape affterwards), and tape the camera wire to the wiresnake. Silicone spray, or something similar will allow you to slowly work it through w/o tearing the boot.
I mention it only because the exposed wire may get damaged over time zip tied to the outside of the boot🤷🏻‍♂️
Install issues:
I can't see what your factory mirror arm looks like but I resolved the mount arm problem for MY23 in this thread. Yours might be the same.
Just installed my G900pro, tested it all worked first with the 12v socket adaptor, then installed with the hard wire kit.
Finished the install but unit will not power on, removed the trim to access fuse box again and cut all my cable ties.
Both fuse adaptors from the kit do not work!!! no continuity from adaptor to connector, thought they we just badly crimped but no.
The actual fuse adaptor heads have no continuity with the fuse holders in the adaptor lead.
Before you install make sure you check the fuse holders for continuity from pins to connector.
It will save you a lot of time! Oh how I laughed and laughed!!!!!!
Hi Clark, Thanks for this. I’ll try and get of something similar (currently not available on AliExpress).
Ok lets start.....
Thank you for sharing this, I recently installed the same way and used double sided tape to mount the rear camera on the rear door (looks just like yours). However, now I am having issues with the camera not holding in place, which I expect to become a bigger issue next summer when it is warmer. How did you attached the rear camera? Thank you, Doug
I just used Scotch Extreme Mount tape. I’m hoping this is it. 🤞Time will tell.
Ok lets start.....
I am also in the process of installing a Wolfbox G900 Tripro. I have successfully installed the rear camera on the outside underneath the third break light as I have tinted windows. I pulled the wire through the ceiling starting from the overhead switch panel. For the bumper camera, I started the same approach as you, and opened the plug in the floor on the driver side. I noticed that there is some water standing in that hollow space underneath. Did you notice that as well?
I have done a similar installation of a Wollfbow 900Tri Pro and installed the third camera underneath looking forward so I can watch the two front wheels and the clearance over rocks from underneath (very cool) and did the testing taking power from the cigarette lighter. So far so good.
To avoid the power cable hanging about, I ordered the Wolfbox hardware kit with the intention of connecting it up to the power point in the left hand foot well (switched via the ceiling console) as you have. I connected the yellow (constant power) to the live 12v and the black to the other cable of the Ineos prewired pair and blanked off the red (ACC ignition cable) thinking this would mean the Wolfbox would stay permanently on and only be switched off if I switched it off on the ceiling console or got switched off by the "Low Voltage Protection: The hardwire kit monitors the car battery voltage. If the voltage drops below 11.8V, the kit will automatically cut off power to the dashcam after 60 seconds to prevent battery drain".
Unfortunately this didn't work!
The Wolfbox boots itself up only to switch off a few minutes later. Oddly enough, without touching anything else, I have noticed that just playing with the fuse (FI29) can cause the dashcam to boot up only to switch itself off a few minutes later.
Any suggestions as to what is going on?
Did you connect both the red and the yellow to the 12v live of the prewired pair in the LH foot well?
Ideally, the as the Wolfbox instructions say:
"The red wire should be connected to the ACC (Accessory) fuse slot. This slot provides 12V when the ignition is on and drops to OV after the engine is turned off. " Doing so enables the dashcam to automatically enter parking monitoring mode when the vehicle is turned off, which can either be set to continuous timelapse recording or G- sensor trigger recording. Both nice to have features.
BUT who knows what would be the easiest way to get that red cable of the hardware kit from the left hand foot well all the way to an ACC (Accessory) fuse slot?
Where is the ACC accessory fuse slot? I've tried several in the driver's fuse panel but believe they all have trace voltage, thus preventing the Wolfbox from entering the parking mode. I connected similarly to the interior ACC switch so I can power on or off as needed but I would like it to go into the parking mode.
Hi can you post pictures and explain where and how you wired the third camera? Also a picture of the view would be incredibly helpful.
Thank you.
There is no single ACC fuse. There are circuits wired to the key on position which is equivalent to Accessories mode.
The INT1 AND INT2 circuits are fused under the seat.
On my MY23 the live and ACC fuses are in rows. The blacked out positions are not populated or wired on my vehicle but your vehicle might be different.
@Matthew Gray - can you please share a picture of the front camera installation? How did you attach it and where did you positioned it? Thanks
Thanks for the tip !!! (y)
I installed my Wolfbox yesterday following the same path.... sorry to busy to take pictures :-(
For the bumper cam, I ran through the same hole in the floor, and going immediately into the front wheel arch.
For this I removed the wheel arch liner, and losses the wheel arch cover.
Not removing it (did not want to remove the wheel) just enough that I could push the cable over the wheel arch.
(there is some sound insolation foam, so the cable is hold nicely in place)
The cable arrives in the left front bumper (missing the cooler there), without ever going through the engine bay.
And only a few centimetres under the car, nicely protected by the rock slider etc. You can hardly see the cable.
Decided to mount the camera below the front bumper, just in front of the skit plate.
Used some extra tape to water-prove the connector, although it's nicely hidden from direct water in the left front bumper.
For the plugs in the floor... I only used the thick part of the cable with the "bumps".
They actually seal nicely in the rubber plug, so I did not even need to add some silicon etc.
