- Local time
- 7:12 AM
- Joined
- Aug 24, 2022
- Messages
- 2,459
- Reaction score
- 6,068
Yep same on mine, you can spool all the way in
I asked Red Winches this question and this was their reply.the rope supplied is 15m, the drum is narrower than most due to the custom build and to make it fit between the front chassis rails. there is a possibility that if you can locate a stronger rope of a smaller diameter then it could be longer.
Practical AND cheerful! Less whipping by spinifex/baking sun south of the StraitFor now I'll just use some corrugated conduit - the black stuff. And a Christmas novelty sock for the eye.
Novelty stops the haters in their tracksPractical AND cheerful!
I think you are 100% in using a spool. Without it, you are bending the line more than "permitted" (for safety/breaking considerations). I will likely buy a spool and "stopper" (Factor 55 have an excellent - but - range here in the USIt just needs to be wound on carefully @Fidei Defensor. If one is not prepared to guide the last section of line it would be better to stop at the marked location.
I was concerned about the performance under load, a major reason to install the winch shackle (which ensures both the winch line eye and the soft shackle are kept at the desired diameter).
If you zoom in you might spot that I have a spool around the shank of the winch shackle, which has a similar effect as a fixed eye.
If you compare it to @grenadierboy ’s example (maybe is without a spool?) you can picture the effect just having a bare shank.
I don’t anticipate any issue with NOT using a spool, but our use case anticipates operating a long way from replacement components (and medical assistance), so our setup is designed to maximise the longevity of shackles/line and the safety of winching operations. Normal users can rather easily just pick up new soft shackles when the ones they use show wear/are damaged.
If one isn’t planning to use a shackle in this way it may be worth sleeving the exposed section of winch line, simply to protect it from the elements etc.
T Synthetic Dyneema Winch Rope Sleeve Sox By The Meter - 4x4 OFFROAD CLINIC
T Synthetic Dyneema Winch Rope Sleeve Sox By The Meter. A protective winch rope sleeve will protect your winch rope from abrasion and. . . .www.4x4offroadclinic.com.au
I don’t believe there is anything official from INEOS, however somewhere here there is a thread where people have reported the springs that have been supplied with their vehicles and there are clearly different springs for different specifications. INEOS people have verbally confirmed this with me and othersAs I was reading through the older posts, there's mention that part of the high cost of the factory winch is the addition of a heavier duty spring-set up front. Is there somewhere where I can read up on this from Ineos themselves?
Work backwards through thisI don’t believe there is anything official from INEOS, however somewhere here there is a thread where people have reported the springs that have been supplied with their vehicles and there are clearly different springs for different specifications. INEOS people have verbally confirmed this with me and others
The Factor55 spool was the only one I could find in stock that fit within the Saber shackle jaw.@globalgregors I just started reading this thread again after losing track of it for a while. Any recommendations on an eye spool? I see a Factor55 one on a quick Google search.
I've just ordered the Saber shackle from Qikazz (4x4andcamping.com) which was the only site that looked like they were vendors to the USA.
I'll be looking to get 2 of the Red Winches - 8T or 12T (?) - Snatch rings or something similar if I can't get the RW ones in the US.
Another idea: a 3 ton Wyeth-Scott More Power Puller with synthetic rope. I carry one in the back of my truck at all times. Have used it to pull down trees as well. Probably weighs about 25 pounds. Cast iron strong.I have now watched some youtube videos showing how to operate a Tirfor or a Hilift Jack. Oh my god.
In an emergency situation, lost in nowhere, this is really an option. But itakes time. As far as I have seen, you can usually forget about the afternoon and you really have to be fit. Ok, why not.
Another thing is weight. A good Tirfor (say 3200Kg) and a cable quickly sums up 50 or 65 Kg, depending on the brand and the length of the cable. The cable has to be made of steel due to the functioning principle of the Tirfor, so it is quite heavy. A short steel-cable would however work if you extend it with a plastic rope and only use the steel part for winching. This saves some kilograms.
Maybe it's better to transport 65 Kg for 10% of the time than 45 Kg for 100% of the time. But you have to secure this load whilst driving, it can become a dangerous missile.
There was another idea: The removable winch. Works front and aft. Does anybody know what it weighs?
Looks good! I can see it as not only a rear recovert kit but, as you said, for pullinmg trees upright after a hurricane! (I had to use my D90 winch and multiple snatch blocks to get at some inaccessible mango trees in our Florida garden last year!Another idea: a 3 ton Wyeth-Scott More Power Puller with synthetic rope. I carry one in the back of my truck at all times. Have used it to pull down trees as well. Probably weighs about 25 pounds. Cast iron strong.
I’m a fool. I still carry a Jackall and about 25lbs of chain attachments. I can do a lot with it, just slowly.Another idea: a 3 ton Wyeth-Scott More Power Puller with synthetic rope. I carry one in the back of my truck at all times. Have used it to pull down trees as well. Probably weighs about 25 pounds. Cast iron strong.
Oh awesome, great info!I don’t believe there is anything official from INEOS, however somewhere here there is a thread where people have reported the springs that have been supplied with their vehicles and there are clearly different springs for different specifications. INEOS people have verbally confirmed this with me and others
See my post , 429 , above with linkOh awesome, great info!
