Where are the INT1 wires in the LH foot well?
10:27 AM
Georgia
For the life of me, I can't locate the INT1 wires in the LH foot well. I removed the plastic cover and am unable to see them. Apparently they are taped to a wire loom but I'm afraid to cut the wire loom I see. Any advice?
The main wiring loom is covered in fabric tape, the INT1 wires are normally taped onto the main loom with black plastic tape. So look for a gloss or semi gloss black plastic tape around the loom.
The wire ends maybe on the underside of the loom out of sight.
Find the gloss plastic tape often means you find the wire ends.
Do not cut the fabric tape.
This video is a RHD car.
View: https://youtu.be/A3qY4CrDonw
Look up higher, above the pedals. They are often tucked up tight against the main body harness, not down low with the other wires. You shouldn't need to cut any loom, just peel back the black tape wrapping the main harness bundle. The INT1 wires are thin and have a single black connector.
Thanks. I watched the Canny video but he's doesn't show the LH side. I got frustrated and put everything back together. I'll check again and go deeper down next week
There were no connectors on my wires only taped up with clear piece of shrink tube on each core
Here’s mine with wago connectors on for attaching extra usb and power sockets.
If you look closely behind the wago connectors you can see the remains of the clear shrink tube.
