For the life of me, I can't locate the INT1 wires in the LH foot well. I removed the plastic cover and am unable to see them. Apparently they are taped to a wire loom but I'm afraid to cut the wire loom I see. Any advice?
The main wiring loom is covered in fabric tape, the INT1 wires are normally taped onto the main loom with black plastic tape. So look for a gloss or semi gloss black plastic tape around the loom.For the life of me, I can't locate the INT1 wires in the LH foot well. I removed the plastic cover and am unable to see them. Apparently they are taped to a wire loom but I'm afraid to cut the wire loom I see. Any advice?
The wire ends maybe on the underside of the loom out of sight.
Find the gloss plastic tape often means you find the wire ends.
Do not cut the fabric tape.
This video is a RHD car.
View: https://youtu.be/A3qY4CrDonw
Did you look on the underside of the loom where the plastic tape is, marked with the 3 white arrows? This is where the wire ends are normally attached - and often hidden under the loom.Well I disassembled the entire left hand foot well and did not see the INT1 wires.![]()
Post a picture to help others that may have the same issue. Is there shrink tube on the ends of the cores.Motherf..... Found them were you said they might be. Thanks a million![]()
Do not worry, you are not the first. I even have trouble finding them and I knew where they were suppose to be.Motherf..... Found them were you said they might be. Thanks a million![]()
IA should have labelled these G1 and G2 knowing full well that men would struggle.Do not worry, you are not the first. I even have trouble finding them and I knew where they were suppose to be.
Just using a tape of a different colour would make it easy. Look for the green tape ... Or even a white marker on the relevant black plastic tape.IA should have labelled these G1 and G2 knowing full well that men would struggle.
I already put everything back together but mine were at the top arrow and were sealed at the ends.Post a picture to help others that may have the same issue. Is there shrink tube on the ends of the cores.
That is a long way up, higher than where I thought you would find them. I was thinking the two lower arrows. One thing is clear, the exact position is varying a bit.I already put everything back together but mine were at the top arrow and were sealed at the ends.
