what is the best compatible brake pads and disc to use for Grenadier
Has anyone figured out what parts correlate to FCP Euro? Brake pads and rotors?
I am not sure but some digging yielded FMSI numbers for Grenadier's pads.
Front pads - 9168-D1944 (it can also be labelled D1944-9168). Looks like the fronts were used in Acura NSX (2016-2022), Mercedes MacLaren, and Maserati Grand Turismo. Brembo lists the first as P50078. Autozone lists the part but tells you it won't fit a 2024 INEOS Grenadier.
Rear pads - 9123-D1895 (also D1895-9123). A Google search for those brings up 2017-2020 Audi A6, Q7, Q8, and e-tron Quattro A8.
FindItParts.com has both front and rear pad kits in stock.
Now... the part numbers for the pads were found on RockAuto website. I don't know if they fit - ordered a set, will report the fitment results.
OK, these are DEFINITELY WRONG part numbers.
Cross-listing from INEOS parts manual:
Front:
GRA-6A70-021170 (INEOS p#), FMSI D1984 9212, Brembo p# P68062 (EAN 8020584110072), Delphi p# LP2190, EBC p# DPX2083, Ferodo p# FVR4347.
A lot of cross-listed part numbers here: https://www.trodo.com/brake-pad-set-disc-brake-brembo-p-68-062?currency=USD
Rear:
GRA-6A80-020670 (INEOS p#), Brembo p# P68063 (EAN 8020584110089), EBC p# DPX2084, Delphi p# LP2191
Lot of cross-listed parts here: https://www.trodo.com/brake-pad-set-disc-brake-mapco-6945
Please set me right if I am wrong again.
I'll probably do the first pads change at the dealership with the mechanic.
I'm used to change land's fixed brake calipers and not these floating ones
My stealership wants $600 for the pads and another $400 to do the work (per axle). I honestly thought the parts guy was kidding. It’s a 30 minute job and the pads are <$30 per axle 🤯.
Back in June 2023 I paid £239 + vat for front pads and £141 + vat for rear pads no fitting. Just to have as spares. OEM brake pads are bloody expensive
30 mins? That’s a fast guy. The service manual for billing will not be 30 minutes. I agree $1k is a lot, but that doesn’t seem obscenely abnormal for a small niche brand. Not at all. Even larger luxury brands will be at least that much I’d think. It’s not a Toyota or a Hyundai.
The brake pads were originally specified for a Nissan. It’s a 30 minute job. Call it an hour if you are less accustomed and parts are $30 per axle.
Just bought these too. We’ll see if the dealer is willing to install them when the time comes. The grenadier is so unique I feel more comfortable with a mechanic that works on them regularly, even if it’s a little more expensive.
I guess I’ve been lucky. I’ve been changing brakes since I was 13 years old. These are about the least complicated units you’re going to find.
Yeah, OEM pads can be pricey, but at least you’ve got genuine quality and perfect fitment.
Keeping spares like that was smart prices have only gone up since 2023.
but you made a smart move. (link removed - mod.)
Does anyone know the correct name or part number for the brake discs for the front and rear? Or an alternative?
Let's not. become a forum of pad slappers.
Check discs and bbed them in as its such a heavy vehicle.
Pads are easy to change. I'm going to do it myself and treat myself to a good single malt with my savings... :)
Enjoy , because usage of peat in whisky making is being phased out. Climate change , etc.
