add warm water geyser, works well, limited on 50degree C.
Don't tell them there are other warm spots in our great nation...Looks good. It was 80 when we were in our pool this afternoon. I guess you have to pay the gas price if you feel you can’t beat the weather!
As a born and raised Texan that lived through 30 years of August heat, trust me when I say, I’m not looking for warm. If you know of any places that are 65-75 and sunny most of the year with sub $4 gas, I’ll move tomorrow. Also no mosquitos.Don't tell them there are other warm spots in our great nation...![]()
Nothing provided.Are there any cutouts or tie downs on the deck to secure a fridge?
Hi Peter,add warm water geyser, works well, limited on 50degree C.View attachment 7925775View attachment 7925776
Hello Franz,Hi Peter,
What brand of geyser is that? I have a similar one in the van but they don't make them anymore and have been replaced with these:
Regards,
Franz
I really like that set up. Would definitely go for that but unfort my dog crate is 29" in height so cannot have the three combo of top shelf/bottom shelf and crate.Installed the Dometic/Frontrunner Grenadier Storage system and four Wolfpack Pro boxes. This is a lightweight alternative to a drawer system. It's removable by four bolts and attaches to the utility rail mounting holes (new bolts and spacers are supplied).
I have Drifta drawers with built-in fridge slide and camp table in my Isuzu DMax. They're great but a lot of dead weight and not straightforward to remove so they stay fitted and fill up withshistuff.
With boxes I can keep them loaded with the stuff I only carry on trips and take them out when I don't need them.
The frame deck is about 560mm (~22 inches) below the cargo shelf so I can still fit my 30 litre weekender fridge on top although the lid will be restricted.
The frame is straightforward-ish to assemble. There are a couple of errors in the instructions but if you read ahead so you know what's coming you can figure it out. It was helpful that @bigleonski let me check out his setup so I had an idea what to expect. Thanks for the tips Leon
A LOT of short M6 nuts and bolts so if you have sausage fingers you might need a dexterous assistant. It's the lovechild of IKEA and Meccano. I put blue Loctite on all fasteners because some will be a PITA to get to again if they come loose.
A lower crate isn't an option? What if you changed the dog's name to Kneel?I really like that set up. Would definitely go for that but unfort my dog crate is 29" in height so cannot have the three combo of top shelf/bottom shelf and crate.
Did you have a Meccano set as a kid?
Probably at their limit and the cages are not cheap!A lower crate isn't an option? What if you changed the dog's name to Kneel?
Good looking dogs. I miss my Labrador.Probably at their limit and the cages are not cheap!
The brown one looks so defeated. Poor doggo.Probably at their limit and the cages are not cheap!
Seriously considering this setup. Not sure if I'll do both modules or just the fridge slide. The right side module looks nice but I wonder how much value it brings if I'm not running a roof conversion. A few questions for you:Thanks to Daniel at Tiny Rig Co for my GP Factor half back! Will post more pics once I add my iceco back…. Love this setup!
View attachment 7925828View attachment 7925829View attachment 7925830View attachment 7925831View attachment 7925832View attachment 7925833View attachment 7925834View attachment 7925835
Since getting the Grenadier a little over a month ago I have been hard at work adding a bunch of accessories. This weekend I completed the biggest one in doing the GP Factor winch. It was quite a process but overall went well. Probably a 12 hour total job. I then set to work on adding a 314ah Wattcycle lithium battery, a Redarc Alpha 50 and still working on adding a 130 watt solar panel on the leitner roof rack. That should get me some good power to run a fridge and starlink mini and some scene lights for camping etc. Its a fun process but I have had a few setbacks, but overall happy with the mods.
Other mods done are :
Baja Designs Agile light Kit
Owl bull Bar
Metalcloak Diff protectors
Midland MCXT575 GRMS
CA Tuned ARB onboard air compressor
GOP Factor rear table and cutting board
Ready for my first major trip to MOab end of month for the Grenadier Gathering. Can't wait.![]()
yep, he knew we were leaving and going home!The brown one looks so defeated. Poor doggo.
I am still finalizing this build and will update you. One of the other forum members tried the Wattcycle 314ah mini bluetooth battery and it barely fits. I ordered 2 expandable battery hold-downs and I think it will work when I combine some parts. Arrived tomorrow. It barely fits under the seat but it does. I will have to trim some of the plastic on the front cover piece, TBD. I need to add a custom wood block or bracket to prevent sliding side to side as the battery is not the full width of the compartment. Probably 4" approx.314ah?! Can we get a build thread on this please? Here I am wondering if my 165ah battery is going to fit. Do you have a wiring diagram or anything you can share on the setup? Particularly interested in ground points for the solar and the battery, access to the roof for the solar cable, and any breakers or shutoffs used, if any.
