Winters off? We’re awaiting snowfall over the next 30 hours measured in feet!
Awesome. I think we’re passed the worst of ours - watch this, I just persuaded the snow gods to dump a couple of feet on us in early March, it won’t be the first time!
I've got that one too. Didn't really fix the problem, still plenty of noise when off road.That's exactly the same as the one that fixed mine![]()
They all seem to have the same faults, mine is terrible off road tooI've got that one too. Didn't really fix the problem, still plenty of noise when off road.
Last update - this is the final form. Lacquer paint stick is definitely the way to go. IMO it looks factory good.Another update. Nailed it (well almost). The way to go is to use a lacquer paint stick. I messed around multiple times and finally came up with a good strategy. I used a tiny plastic “scraper” and used it to pack the recesses with some of the paint stick. It is not particularly liquidy, more like a paste, so I packed it full and wiped away the excess.
There was some residue left behind but I learned the hard way that the recesses are too shallow to simply wipe it off while still “wet”. I let it sit for days until the lacquer hardened up and then with a Qtip and a little dab of rubbing alcohol everything cleaned up.
You may notice that some of the black looks crappy but that is due to the over use alcohol needed to clean up the white out debacle. I’m going to reach out to @GrenadierUSA and see if they can make a version with deeper recesses and if so, this technique should look factory good.
not too shabby, KrabbySupra shifter, Grenadier USA transfer case knob and cup holder/center cover.
I guess this makes me a prepper
I have a trip coming up that takes me far enough away from home that I would prefer to have it and not need it than need it and not have it. A$160 shipped from Summit Racing. Much cheaper than anything I could get locally.
Also some spare M8 x1.25 x 50mm cap screws from Bolt and Nut Australia. My front driveshaft has been replaced previously so I'm not expecting issues with broken driveshaft screws but I have them anyway.
I will pre-grease the CV then vacuum seal it in a bag.
Excellent work. Having sheared off two bolts at the front diff during an away from home removal would highlight the need of moles/double nuts/heat source etc incase same happens. No doubt already in people's kit/camping hear but if not and two bolts next to each other shear then not ideal.Continuing my post above, one CV hotfix kit ready to go. Just add hand tools, rags and sweary words.
I've gone with class 12.9 industrial socket head cap screws because the factory torx screws have been known to break during removal which I think might be related to the red thread locker used at the factory. If they have used Loctite 263 or an equivalent it needs heat to release it.
- pre-greased CV
- cap gasket cemented in place
- two sets of class 12.9 cap screws (16)
- bolt tabs
- new boot clamp plus spares
- new shaft circlip plus spares
- tube of Loctite 243
- extra CV grease
- Purpose built two-bolt puller to remove the old CV (if needed)
I'll use medium grade Loctite 243 which is still suitable for M8 at ~45Nm finished torque but it only needs hand tools to undo it.
Again, this is just insurance for a worse-case self-recovery scenario. I'm running standard height suspension so a driveshaft or CV failure should be warrantable.
I'm happy to loan this kit to Australian forum members on a replace-what-you-use basis. Provisos are that I don't need it at the same time and you collect and return it promptly or pay postage both ways.
DM me with dates if you're interested. It will be available from 3rd April (Good Friday).
