I'm currently installing an
Icom IC455-UHF (CB) radio and
Zetifi combination UHF and 4G/5G cellular antenna.
I got the antenna installed today using an ARB bolt-on UHF bracket. I was inspired to use that bracket after seeing
@bigleonski's post
here. Thanks Leon.
The antenna has two coax connections (UHF and Cellular) and a power connection so there are three cables to run.
The ARB bracket is designed for a 47.6mm diameter bar so I had to adjust the drilling template for the 51.8mm diameter Ineos roobar. It bolts up nicely to the roobar and is a good alternative to a clamp bracket.
Installation requires a 24mm hole to be drilled in the front of the tube and a 10mm hole in the back. Once you make those holes there is no going back!
I wet-assembled the bracket onto the bar using silicon to stop water from entering the roobar tube.
ARB don't seem to have the bracket on their website. It's accessory for their Summit bullbar range. PN 35011170.
The IC-455 UHF will go under the glovebox (left side of my RHD vehicle). There is a good flat mounting surface there. I'll use INT1 for power. I did have my Wolfbox on INT1 but I have moved that over to a fuse tap setup so I get an ACC signal and parking mode will work properly.
The Cel-Fi will go under the front passenger (left side) seat. It's already in a portable case because I move it between my vehicle and my camper. The case has internal, external and power sockets built in so it's an easy plug and play setup to move it back and forth. I will need to add a single cig socket outlet under the seat to power the Cel-Fi.
