Yes…. As suggested some time ago by someone else it works perfectly
U.K….. “tie wrap” 5mm stub.
U.S….. “zip tie” 1/4” stub.
Nice, I missed that. How much fo the strap do you cut off? Or better question, how much oif the strap remains/goes into the slot?
After attempting to wrap the shiny black centre console plate with some matt grey vinyl (and having failed miserably around the screw holes) I decided to hit it with some 600, 1000 and 1500 grit sand paper to dull it down (and prevent the annoying glare it created in direct sunlight).
Wrapping is easy,
Rupert as per previous post…..
Just enough to slide under the switch. Approximately as below & if you get it wrong you can always “invest” in another $0.01 🤓
UK… 5mm
US… 1/4”
A few lessons learned. The Pentel whiteout didn’t go as planned and using rubbing alcohol to clean thins up took the shine off the anodized finish. It’s still black but lost its luster. I bought some anodized aluminum cleaner which helped but still can tell it’s not the same.
I think the whiteout dried too quickly and then I struggled to remove excess not down in the grooves. Maybe paint is the next effort.
Another update. Nailed it (well almost). The way to go is to use a lacquer paint stick. I messed around multiple times and finally came up with a good strategy. I used a tiny plastic “scraper” and used it to pack the recesses with some of the paint stick. It is not particularly liquidy, more like a paste, so I packed it full and wiped away the excess.
There was some residue left behind but I learned the hard way that the recesses are too shallow to simply wipe it off while still “wet”. I let it sit for days until the lacquer hardened up and then with a Qtip and a little dab of rubbing alcohol everything cleaned up.
You may notice that some of the black looks crappy but that is due to the over use alcohol needed to clean up the white out debacle. I’m going to reach out to @GrenadierUSA and see if they can make a version with deeper recesses and if so, this technique should look factory good.
I guess this makes me a prepper 🤷‍♂️
I have a trip coming up that takes me far enough away from home that I would prefer to have it and not need it than need it and not have it. A$160 shipped from Summit Racing. Much cheaper than anything I could get locally.
Also some spare M8 x1.25 x 50mm cap screws from Bolt and Nut Australia. My front driveshaft has been replaced previously so I'm not expecting issues with broken driveshaft screws but I have them anyway.
I will pre-grease the CV then vacuum seal it in a bag.
Good idea. Do you have the part number for this please?
Hey @MattG. The Crown Automotive PN is 68272524FRK. It's the Summit Racing link in my post. The equivalent Teraflex PN is 1745000.
Tomatoe/tomato. Buy whichever you can get the best deal on. The Summit Racing service was great.
Today I had my whitewalls flipped around. Need to scrub the tires clean now(is that brake dust?). Any recommendation for a tire dressing afterward?
Reactions: CRH
Ordered up power steering cap seal in 2.62mm thickness to fix my greasy looking power steering filler cap area. Arrives next week at local supplier. - $2.90. Same thing if ordered from agile off-road was similar price but $79 to deliver to New Zealand. Thank goodness for local suppliers and this forum’s tech heads for providing the size detail. 40.95 x 2.62 mm in Viton. 🙏🏾
Today was exhaust day. With a little help from all around good guy Jared we installed the Kooks cat back 3" 304 stainless system. It deletes the resonator and sounds amazing without being annoying. All in from unboxing to first drive took about an hour and 45 minutes.
The factory exhaust is available free to a good home in Northern California between San Francisco and Sacramento. A special thanks to David from Design Build Go in Statesville North Carolina for bringing these to market. It costs a bit more but is worth it.
Looks great. Im glad you enjoy it as much as I do. Made here in North Carolina.
Picked up my Grenadier from Design Build Go this afternoon.
I had the Eibach 1.2” leveling springs and Fox 2.0 shocks installed.
Along with a few interior accessories.
David was Great to work with and I was very impressed with his expertise and engineering abilities. I’m already planning my next upgrades.
We were supposed to head north from Cochrane, Ontario to Moosonee yesterday morning on the Wetum Road. Except that it wasn't open. So we made the decision to head southeast to the mining town of Val-d'Or, QC since we didn't know the Wetum was opening at 6:00 p.m. that day and our time was limited (and we didn't want to drive at night). Meanwhile we've been turning some heads here in northern Canada with our unfamiliar truck (there was a really nice kid in Sudbury, Ontario who almost went out of his mind when we met him in the parking lot of a sporting goods store: he dragged a car book with a picture of a Grenadier out of his parents' car to show us how excited he was). The fellow at the PetroCanada station in Quebec where we filled up last thought our truck must run on diesel and seemed borderline incredulous when we told him it was made in France (he made us write down the name). Today was pretty much a down day but we did check out the mining museum in neighboring Malarctic before driving 60 or so kilometers up to Senneterre, the terminus point on the thrice weekly VIA rail service from Montreal to Senneterre. (I had been wanting to come here by train for many years, but unlike the route to Jonquiere which I took about ten years ago, I never got the chance to take this train.) While in Senneterre, I took this shot of my salt splattered beast:
Other than having one of the welds on the non-OEM jerry can holder fail (hence the roof mount), the truck has been running well, although the computer did some rather odd stuff in the sub-zero Fahrenheit temperatures in Cochrane and there is some evidence of a very slow leak in one of the tires which the onboard Arb compressor can fix when needed. We leave tomorrow morning on a six to seven hour drive to Montreal.
iCheck TPMS for car and van
I installed the iCheckTPMS sensors to test (car only). I am testing it before the remote trip. It allows me to also monitor the car's spare tyre and also the tyres on the van, including the van spare. It monitors tyre pressure and tyre temperatures.
It worked straight away. No hassles.
I may also add in the van hub temp sensors. You just need to buy the hub sensors.
I will be using the system when I go on The Kimberley. Anytime I change the tyres up and down, the benchmark pressure on the sensor resets and allows 25% PSI increase before the alarm sounds, or 15% down. I wish the IG TPMS system worked the same way!
I will ignore the IG tyre sensors when I need to often change presures on the trip across bitumen, gravel, sand and corrugations.
This video show you how easy it is to set up and use, plus its features. It is an all wireless setup. I bought an 8 sensor kit:
View: https://youtu.be/XigW3k0_36U
