I received preproduction samples of the rear door window bags from the craftsmen at Overland Outfitters. I had designed and sewed a bag for the narrow door window as a proof-of-concept and six weeks ago I sent that bag and a design and patterns for a wide rear door window bag to them; they created samples for testing as a first step towards deciding if they should put these production.
The narrow door window bag is basically a duplicate of the proof-of-concept bag I sewed. It's pretty much ready for production, but probably should undergo a little testing first. The pocket panel on the lower half of the door is already in production.
The wide door bag has two pockets, a large pocket on the low side of the window and a smaller pocket on the high side.
The wide side also has a zipper closure in addition to the top flap.
I'm not completely satisfied with the fit of the wide door bag, so I'll make a few suggestions to the folks at OO and ask for another sample with the changes. Maybe I'll ask for a black sample to see how it looks in that color. Also the bags probably need some good testing before OO decides to put them in production.
The bags are not higher than the spare, so visibility out the back isn't any worse than it is without the bags. I designed the narrow door bag to be a little taller than the wide door bag, let me know if you think they should both be the same height, and if so, should the narrow door bag be lower or should the wide door bag be taller.
Both mount very securely without screws, double side tape or any other "destructive" attachment method; they don't damage the door and they're easily removable.
Here's a View of the bags along with some other Grenadier products from Overland Outfitters (https://www.overland-outfitters.com/ineos-grenadier.html#/):
My build thread: https://tinyurl.com/265dxjyc
New content every day: Land Rover Ideas for Grenadiers: https://tinyurl.com/3puyt6m3
Red still seems appropriate (and in keeping with the cover of the adjacent 12 volt post), considering the risk…
I was playing around with a two colour job.
Trying to continue the black/red theme.
Just need to now print in a filament material better suited to the temps under the bonnet. PLA is ok for prototyping but doesn’t like heat. 🤨
Will you sell
Some for folks who don’t have a 3D printer
Is possible, however postage cost can make a cheap part expensive. Having someone local print for you is much more cost effective.
The design will be shared free of charge.
Just needs to be printed in the right material due to heat exposure under bonnet. ASA should be ok, but PC or PP may by better options.
Not my Grenadier but stopped in for some whiskey and a pint at “the” Grenadier while here in London for a couple days…..
I didn’t realize Jim went and bought the place :)
I did the same but used the stedi mounting plates… just cut them short to fit. These are the best option on the market for camping lights if you ask me :) very versatile with white/yellow and individual dimmer for each color….
No need to cut off the Stedi brackets. Just give them an initial shove at a 45 degree upward angle and they will then lay flat to bolt into place. These Stedi Micro Touch Dual Color 13.9" lights were $104 each delivered to the US from Stedi UK. Two weeks from the time of ordering to my front door. They await connection as I finalize my rooftop electrical plan (trying to make sure I don't forget something and have to rewire it later).
It’s our pickup and it’s my son driving 😅
But, yeah, the Ineos is awesome.
Lots of snow
This is a couple of miles away (not my pic)
This is from my dashcam today
Last time I saw it like that we owned a Volvo 340 and had normal tyres on it. Drove from Aberdeen to Helmsdale. Were staying in a cottage up the hill from village and we scraped the road with shuttle and then wife pushed me up. She drove a lot from Aberdeen. Loads of cars in ditch and struggling to get up the dips. We arrived well after midnight on new years day.
Next day the road from cottage looked like your snow drift shots.
It was still like this when we had to go home so we dug our way down to the village. Lovely old couple at the last snow drift sent son out to dig the car through and gave us tea and toast to warm up. Harbour frozen when we were there, I think news said -24 in the valleys by us.
After that I always aimed to have a 4x4 and started using winter tyres when I could.
Brilliant, that was good going in an rwd car. Amazing still the number of people who live rurally and don't use winter tyres. Might be ok on a little light car with narrow tyres but no way on a 2 tonne rwd BMW with all the traction and stability aids that keep you in a straight line in the wet but halt all progress on ice.
-24C is proper cold, our record low was -23C and our well froze solid (1.5m below ground level). Funny it doenst feel that much colder than maybe -10 or so which is pretty regular but it can catch you out - and diesel starts to gel by then.
Reactions: CRH
This happens as the captive bolt catches the seal, I brought this to my dealers attention and they posted a new one to me (I live 250klms away) all service techs should know this
Just some follow-up to my air filter damage during installation by my agent. See my earlier post here.
The damage occurs due to the centre inside captive bolt snagging on the filter seal during installation of the airbox lid. This was noted by @MrMike above. It's super easy to do but easy to avoid if you're aware of it. It does take a bit of care to align the lid over the airbox. The captive bolts can be wound up into the lid which retracts them far enough to avoid catching on the filter. I recommend this for at least the centre inside bolt. See pic. Wind it up before bringing the lid over the filter. Get the lid on straight then start the corner bolts. When you know you have the lid on correctly wind down the centre bolt and tighten all bolts.
Serving suggestion only.
Edit. I forgot to give MrMike credit for the share about the centre captive bolt.
Today, ploughing in the snow. Got a call from my mom, about here appointment at the doctor today.
Mom: We aren't going to the appointment, I will cancel the appointment, to much snow, to difficult to drive, you can stay at home.
Me: NO WE DON'T! Be ready I am on my way!
Are they the BFG K02's?
