Installed the Agile Offroad Diff Breather kit. There were a couple of differences between the list of parts in the instructions and what’s in the box, but everything shown in the photos in the instructions is present.
Instructions say a 13mm deep socket can be used to fit the new breathers, but that wasn’t the case - the fitting for the hose is sufficiently wider in diameter to prevent the socket from fitting. Used a ratcheting wrench instead.
The 8mm hose retains its coiled / spring shape, making threading it through/around things a test of one’s patience. This is definitely a job to do BEFORE you fit skid plates if at all possible.
EDIT: as John says in the YouTube video, both differentials hissed as the factory breathers were removed, indicating both were holding pressure.
Wild Camping in Rosevelt national forrest close to home with my daughter overlooking Boulder Colorado. Fun times.
Any advice for someone who has a full set of skid plates on the car?
Outsource it?
I've just replumbed my camper with new 12mm John Guest poly tubing that was also tightly coiled. The best thing I did was uncoil the tubing and hung it over my shed beams with a couple of weights attached. After a week the tubing was straight and much easier to work with. You could do the same by tying it along a fence under tension, or peg it out on the ground in the sun, etc.
I used a length of strong cord as a leader to run in the pipe. Same idea as pulling ethernet cable. Route the cord where you want the pipe to go then pull the pipe through. I drilled a small hole through the end of the pipe and looped the cord through the hole and tied it off. Discard that bit of pipe when you're finished pulling.
Agile’s proposed routing is good - I wasn’t objecting to that, just the difficulty of controlling the tubing. @Clark Kent ’s method of getting some of the “coil” out of the line would be worth a try if you have time.
