That is an area we are most definitely wanting to visit when we start our Europe travels.
The contrast with Bosnia is marked. I guess it’s a cultural thing being different religious majorities. Montenegro feels like the Norway of the Balkans, clean (compared to Bosnia) well developed and stunning scenery.
3 of xxx, Montenegro 2024 with Barney, Burki and survivor
In North America, Hell's Canyon is recognized as the deepest canyon at 7,993 ft (2,436 m), while the Grand Canyon at 6,093 ft (1,857 m) ranks about 4th or 5th deepest, depending on how each is measured. Other canyons in Tibet, Nepal, Pakistan, and Peru are more than 10,000 ft (3,000 m) deep.
I guess it’s how you measure it and what you class as a canyon.
Yesterday we went on Montenegro’s longest zip line. Then today we were offered a ride on Montenegro’s longest zip line. They are not the same lol.
If you fit the Almont skid plate, check if it touches the steering rod, because in my case I had to cut about 3 cm
Yes and the rear sway bar . When fully loaded in Morocco I kept hearing a squeak going over bumps and the rear differential guard was rubbing on the bar so had to cut some of that to.
Rear guard before cutting
Front guard after cutting
Not in my grenny, but I flew down to Sydney for the 3 day weekend to watch the last tour match of the British and Irish Lions v Wallabies.
If any of you guys from the British Isles or Ireland were here in Sydney and bumped into me down at the Rocks after the game until the wee hours of the morning, it was great to meet you, I apologize if my enthusiasm for your visit was somewhat energetic, and I’m sorry if my singing voice is still grating at your eardrums this morning. I met a hundred of you last night and you were all gentle men and women to a fault. Even you Jimmy from Thurso Scotland who sprayed single malt scotch all over my face and clothes in a swallow gone wrong.
Great party.
Safe trip home!
Great party.
Safe trip home!
Thanks for bringing this up.
I too have had to customize Altmont’s skid plates…do they not have sway bars in Spain?
They also only use cheap bolts (mine snapped on first impact) in the swing arm skid, and single side weld the swing arm skid plate ( see damage). You may want to consider installing higher grade bolts and having your welder weld the back side too if you have the swing arm skid plate.
All straight and fixed (welded inside and out) and new bolts (thanks Custom Machine)
My morning was installing Agile’s adjustable sway bar mounts by Apex. Lots of skid plate cutting for clearance with the Eibach adjustable sway bar. Will evaluate soon. We’re not a go fast/die hard like John (at Agile), but Moab and Colorado will give em’ a work out.
I was considering the same combination. When I spoke with John about it he advised against it as the end links would be easily overpowered by the stiffer bar. I’m interested in your experience and if it’s possible to generate enough pressure to realize the full stiffness of the bar on the street.
Disclaimer- not an engineer, just a dummy with lots of time tuning race cars-and an active imagination.
That said,
We should get a city speed idea in the morning and a highway this weekend.
Notable facts:
Truck is usually about 6500lbs, camping weight is 7000lbs at about 40f/60r weight distribution. Koni raids, 500lb rear springs and Eibach rear sway bar. Metal Cloak front disconnects, Full skids, sliders, etc bring the CG down - pizza cutters and a bit less than 300 dynamic lbs on/near the roof bring the CG way back up. The rear bar’s stiffest position is a rate of 272lbs (per Eibach), but don’t know at what amount of flex/displacement. This is apparently double the factory rate.
The Apex’s will go up to 300psi, which, not having a spring gauge or knowing the air volume, or if the stroke end is less than than the total chamber volume, makes it anyone’s guess at what point they will start compressing (stiction+initial rate) and when/if lock out/end stroke happens. The big question for me is how fast will the tiny air spring’s rate ramp-up with a little shock’s small amount of air volume, because, at some point it should become effectively rigid - either no more room, or shock spring rate greater than sway bar spring rate - and push the sway bar normally. I think (hope) it will function, on road, fully loaded as variable rate sway bar, the whole system stiffening at a non linear rate as the lean angle grows. I suspect it won’t be as good (softer) in sharp slalom maneuvers than the current setup, but equal the stock links in long highway curves. Current setup is way better than stock, great on road, but the rear bar is best disconnected off road or removed for serious stuff like Moab.
Having watched John’s YT video, the sway bar usually remains at about the same angle, meaning the whole system is only using the air springs/end links and the bar is effectively rigid (think 962), only on big hits does the air spring seem to ramp-up and then force the sway bar to flex. The shaft’s dirt line seems to indicate where that change is usually happening.
However, My real reason for getting these is exclusively for Off-road. The goal is an easy rear sway bar disconnect (mostly) but with that air spring ramp-up effect engaging the sway bar if things get way crossways out back and to flex the front axle. So if they rock off-road, I’ll keep em even if on road slides back towards stock. If not, you’ll see them in the classifieds.
View attachment 7903953View attachment 7903954
Thanks @Brandnm. I’ve got new bolts ready for when I get my vehicle back from the dealers. At the moment all guards are off as I I took them off to facilitate warranty works and exhaust mods to fit LRA fuel tank. I found the bolts very soft and struggled with some and one rounded out completely so had to be drilled out to be extracted. I’ve bought two kinds and deciding which to use. I have high tensile and stainless steel replacements. Plus I’ve also cut a small piece off of the transmission guard to make it easier to get my hand and arm in to hold the spanner and nut whilst tightening the bolt with the other hand. I’ve cut a piece off the back left corner of the guard.
Filled up my adblue from a service station pump for the first time today. (French supermarket) Quite a bit cheaper and certainly less messy.
Our local service station has just installed an adblue pump. Just waiting for it to commissioned and the price determined.
