Asnes
5:50 AM
Windermere, FL, USA
Got my badges and forum paraphernalia attached. A little crooked in the back I think but perhaps for good measure :)
A big thank-you to Stu and Krabby for creating a wonderful community for owners. Having been an admin on the airstream forum I can appreciate how much work it takes to put a great forum together and manage things.
Shaky
5:50 AM
At this rate the “Grenadier spotted” thread will become the “forum medallion spotted”.
Could it become like train spotting with members keeping records of member numbers and where they spotted them 😂
parb
2:50 AM
Silicon Valley, CA, USA
I'm curious. Do you guys put a clear coat on the medallion before you put them on the vehicle? I figure sun (and especially on an outside mount) carwashes would wreak havoc with them?
rovie
5:50 AM
No, I'm not going to do anything. For me, it's absolutely fine if the badge gets patina.
bakepl
7:50 PM
Brisbane, Australia
Hi Jonathon & Hannah, Thanks for the info on the Clevershade Ultra Light 270 and your install. I am also installing a 3/4 Leitner Design Rack in the next week of so.
Once you get your Leitner Rack installed let me know what brackets you use to install the Clevershade. I am hoping I can find a way to install it so I can easily take it on and off as I am not sure the Clevershade will clear my garage door opening. Any photos would be helpful. You travels are so inspirational and you travel tips are beautifully detailled. John Eash aka DaBull
Following.. already had a Clevershade 270 ultralight, great awning about 16kg thereabouts, have been waiting for a rack and the Leitner looks yo be the one... just need to sort getting one to Aus unless someone here already has them available. 😀
globalgregors
7:50 PM
Sydney, Australia
Not yet but I’m aware that a couple of parties are interested. I’ll discuss with Leitner when we’re there in June if noone has got to them first.
globalgregors
7:50 PM
Sydney, Australia
Thanks, John. I believe the Leitner features tracks that will accept the same hardware as Rhino/Yakima/Frontrunner, in which case the Rhino Rack mounting kit should work fine. We’ll hit California in June and will confirm if another forum member hasn’t done so before then.
Regardless the Clevershade is easily and quickly removed, and at 16kg or so it’s a job for one person (a bit of height helps).
You’ll see in the earlier photo that the awning attaches to a piece of aluminium billet about 30cm in length - this slots into the track you see attached to the roof bar/rack, and is retained with a screw/clamp fitting. Loosen the clamp and wiggle the billet free to remove the awning.
TheDocAUS
7:50 PM
Eromanga
I am back home after the shake down trip. Things went well, engine running nicely, spare rim is all good and most of the electrical work is now done. I need to adjust the CLEVERSHADE 270 awning to make it work properly and I will revise my drawers and water tank after seeing the deeper drawers at XHQ. They go in after Easter.
A couple of minor issues with the car, the passenger footwell circuit is not working, the driver’s door latch is catching or the door has dropped and the Start/Stop feature does not work properly.
No alerts post the electrical work, the solar panel is working and the only remaining electrical goodies to be installed are the ARB Twin compressor and a USB charge point on the Lightforce Fascia Panel near the driver.
I am now over 4,000 kilometers, the CLEVERSHADE awning and rooftop solar panel has not resulted in much increase in fuel use or noise. There was some minor whistling, caused by the solar panel, which seems to have gone away. The motor settling in and the extra drag almost cancelled each other out. I am getting around 11.7 to 11.8 litres per 100 km traveling at 100 to 110 kph.
DaBull
2:50 AM
California
Hi Jonathan and Hannah, Thanks again for the info. Looking forward to getting my Leitner Rack installed in the next week. I am first having my Grenadier Roof wrapped in Xpel Stealth Mat/Satin PPF Film to protect it since it will be a bit harder to clean under the rack once I put it on. I am having Wrap Labs in Westlake California do the job. The film is twice the thickness of most wraps and is guaranteed from Xpel for 10 years.
It comes in clear or mat/satin. I am also getting the front driver and passenger windows tinted a bit darker and a light tint added to the safari windows too. I am picking it up from Wrap Labs on Monday. Say Hi to Bernard at Leitner for me. John Eash aka DaBull
7:50 PM
@TheDocAUS my driver door wasn't 100% , and ill fitting doors really get on my goat!
But it's easy and satisfying to fix.
rovie
5:50 AM
Yesterday we were back at Böblingen MotorWorld. Between the Pagani, McLaren, Lamborghini and Maserati showrooms is the German headquarters of INEOS Automotive. Unfortunately, I was too late this time and didn't meet anyone. Unfortunately, everything in the INEOS showroom was dark except for a lamp at the desk. The only Grenadier in black on display was barely noticeable. Outside there were 2 prototype vehicles (PT01, PT03), one of which was a right-hand drive. One vehicle had a badge beneath the windscreen which I have at least not yet seen live (I`ve got my Trialmaster badge).
If you are ever in the neighbourhood and are interested in cars, you should take a look at MotorWorld. We have had events here in the past, including Land Rover. Maybe in the future with INEOS Grenadier. Who knows? I've suggested it several times in conversations.
And if 1 day isn't enough, you can spend the night in the V8 Hotel.
IGL
11:50 AM
Frankfurt Metropolitan Area, Germany
Today I mounted my bike securely. The brackets on offer were clearly too expensive for me.
Heute habe ich mein Fahrrad stabil befestigt. Die angebotenen Halter waren mir einfach zu teuer.
Hi Pauli, were did you purchase the snug fitting floor mat?
Hallo Pauli, wo hast du die passgenaue Bodenmatte gekauft?
Jeremy996
5:50 AM
Today Maria and I went to the National Outdoor Expo at the NEC, with free tickets from Ineos Automotive. Still an expensive place to go as we bought a posh waterproof coat for Maria and some collapsible stools.
I'm not sure that Ineos marketing has really worked out what to do with Grenadier owners, the invitation talked about having a test drive and a good look around the Station wagon and the Quartermaster. Anyway, some pictures:
View attachment gren Outdoor Show - 4.jpegView attachment gren Outdoor Show - 5.jpeg
Latitude, the roof tent people had a stand with a Grenadier fitted with a MaxTraxx kitchen insert; lovely but pricey.
View attachment gren Outdoor Show - 8.jpegView attachment gren Outdoor Show - 9.jpeg
Karearea
9:50 PM
New Zealand
View attachment 7849485View attachment 7849486
View attachment 7849490View attachment 7849491
Nice gear! And lovely wheels on that Gren too!
