What are the negative effects of the removal of the rear muffler
Rover and Dreamer
10:12 AM
South Africa
From what I can gather the rear muffler needs to be removed in order to fit a long range fuel tank on my Diesel Trialmaster. Firstly are there negative consequences on the engine and its long term performance and secondly what does this do to the warranty as issued by Ineos?
None at all the CAT is still in place which is connected via sensor to the engine. The long range tank still adds a muffler back its just different than stock. Warranty don't know the laws in South Africa but here in the states they would need to prove that removing the muffler caused the damage to what ever you are warranting out.
I’ve posed this question to an Ineos rep and as @Tenac says it doesn’t affect your warranty as the exhaust is cut after the CAT so not affecting any emissions equipment. I have a petrol Grenadier and will shortly be installing a Long Range Automotive fuel tank from Australia.
like others said engine will be unaffected and warranty is also safe. I’d definitely plan on doing some sound insulation work on the floor and rear door though. I mean, the rear floor is already a bit like a drum on an unmodified car I can’t imagine that situation will improve when removing the muffler
A few weeks ago, I had the Brown Davis 68 litre reserve diesel fuel tank fitted. Prior to that, I’d already installed a set of King shocks from Expedition HQ. When the shop installed the tank, they said it was a nightmare to fit—but they got it in eventually.
The other day, while checking the tyre pressures, I noticed the exhaust pipe was pressed hard up against the shock absorber. I’m no expert, but even I knew that wasn’t right. I booked in with a local exhaust shop and dropped in this morning. They put it up on the lift so we could get a proper look.
Turns out, it wasn’t just touching the shock—it was also hard up against part of the suspension linkage and something else I can’t remember the name of. While the contact with the shock was the only thing obvious when the vehicle was on the ground, lifting it by the chassis and letting the suspension hang (which, according to the exhaust guy, is how you should check exhaust clearance on a 4x4) revealed multiple contact points.
The fix? Slide the Brown Davis exhaust extender further over the existing pipe. To do that, he had to remove the extender and extend the expanded section to allow it to slip on further. Not a huge deal if you have the right tools, but it took him a couple of hours and cost me $350.
In my opinion, the original 4x4 shop didn’t cut the exhaust in quite the right spot—leaving it a little too long. They probably realised this after the tank was installed, and instead of removing the tank to correct it, they just left it. The proper fix would’ve meant taking the tank back out, trimming the pipe, and reassembling everything.
I also noticed that the fuel filler tube is jammed up against the right rear shock. The exhaust guy didn’t want to take that on, so it’s still like that for now. My overall conclusion? The Brown Davis fuel tank needs special consideration if installing it with King shocks. Get a shop that is meticulous with detail and one that has exhaust fitting equipment to do the job properly
On a related note, the Brown Davis exhaust extension is just a hollow pipe—not a muffler. That said, I haven’t noticed much change in noise. My partner reckons there’s no difference at all. Personally, I think it sounds slightly more like a tractor—which I love! It does make me wonder why the stock muffler is even necessary when removing it makes so little difference. If anyone needs a spare muffler, let me know. I’ve also got four OEM shock absorbers and the factory front steering dampener lying around. I'm in Sydney, AUS. Oh, and swapping out that front steering dampener has been the best mod I’ve done so far.
As for filling the tank—when I put diesel in, it seemed to fill both tanks together. I’m not sure if one fills before the other, but I did have to ease off the pump to avoid it backing up and cutting out. Transferring fuel from the Brown Davis tank to the main one took around 30 minutes. A bit slower than I expected, but honestly, not a big deal.
Consider the weights if you do any towing. I recently purchased a hybrid camping trailer and it had me in nearly panic mode when I hooked it up at the dealer to tow it away. Lowering it onto the towbar squatted the back end of the Grenadier right down. The steering was really light and a tad scary. The manufacturer's specified ball weight is 280kg but I'm guessing it was way over. The Brown Davis fuel tank is quite heavy, maybe 50kg (my best guess trying to pick up the box). Filling the tank adds another 56kg, with the weight right at the very back, behind the rear axle. I fixed the sagging back end by adding air bags to the rear suspension but it's still pretty heavy back there. I don't know if the Grenadier 350kg max towbar weight is impacted by adding weight with the reserve fuel tank. It's just worth considering the weights of the reserve fuel tank if you do any towing.
Would appreciate a few pictures of this tank...!
Sorry to hear about your less than ideal experience with the shop that installed your auxiliary fuel tank.
The Brown Davis tank is about 30 kg if I remember, the muffler I removed is about 11 kg, so the weight gain is not that bad.
I put an early version of the Brown Davis tank in myself up my driveway, it really is not that difficult, I think the shop that fitted the tank for you should of rectified the clearance problems they caused, they are clearly incompetent and should be named and shamed so that no one else on this forum has the same dreadful experience you received.
You should get the shop you used to install the tank to fix the filler tube rubbing the shock absorber issue, and the slow filling of the aux tank is probably caused by the fast filler fuel hose having a kink in it, but none of this should be at your expense, and I would also present them with the $350.00 bill from the exhaust shop.
My filler tube is about 400mm from my shock absorber, and about 50mm to 70mm from my right rear coil spring from full compression to full extension.
The auxiliary tank is a game changer when traveling remote, I just made good use of it on a trip to Arkaroola, and the spectacular flooded Lake Eyre. Lake Eyre really is an inland sea at the moment, and with all the visiting bird life made it even more special, I have seen Lake Eyre flooded a few times, but never to this extent, and water is still flowing in.
Might be worth asking Ineos.
If there is an incident , these factors will be investigated.
My guess is the weight of the tank is just part the overall GVM, GCM and rear axle loading, and if it all fits within those allowed parameter's it should be fine, it should be no different than having a suitcase of the same weight in the rear of the vehicle.
So a tow bar load of 350kg should be fine if the GVM or rear axle loading are not exceeded.
I'm inclined to agree with you!
I would disagree, tongue weight is subtracted from GVWR when applied.
3500kg GVWR
350kg Tow bar load allowed
250kg Fuel tank and fuel (probably over estimating by 50-75kg)
2700kg curb weight with accessories
leaves only 200kg for passengers and other cargo. Tow bar weight is not "on top" of GVWR, it is subtracted... nothing in life is free.
Hi,
I have just had the Brown Davis tank installed and am happy with it.
There have been some teething issues which have been rectified.
It was a bit slow to fill. The issue was that if one keeps the Grenadier OEM fuel filler, there is one breather which affects the filling. The Brown Davis filler has 2 breathers but my dealer felt the OEM fitted better with the angles of the tubing. They fixed the problem with putting the second breather into the OEM line.
The second issue was that if one fills the tank on the run (like when the main tank goes down to reserve), the car does not seem to register this and the km left to empty does not increase, even though the fuel level does.
A working solution provided to me by another Grenadier driver was to intermittently fill the main tank as it drops to not let it go down to empty or reserve volumes.
I brought mine to the dealer today to have a look, and magically the km left fixed it self. This was about after about 5 cycles of the engine turning off an on with my general driving since the fill on the run. They suggested also doing a hard reset of the computer which can be done by just pushing the mute button on the volume know for about 10 seconds and wait for the screen to turn off (the ignition is on). The computer reset and the km left figure then came back to a more accurate representation of the volume in the main tank ( >500km - the main tank was almost full).
I hope this is all helpful.
Chris
3500kg GVWR
Thinking about this, the added weight is behind the rear axle, thus could overload the max capacity of that axle and reduce mass over the front axle. Thanks to the principle of moments.
Steering and handling could be compromised, especially with a heavy trailer.
As with an old 911.
I crawled around under to have a look. I was mistaken with the filler tube up against the shock. It is not up against the shock or spring. It looks okay but just a little, I dunno, strained. I can see the bulge in the plastic wheel arch that I'm guessing is the filler tube hard up against it. The filler cap doesn't come out in the same place as the original, leaving a gap in the rubber. It all seems to work so I'll probably just leave it. I've got two weeks left before movers clear out our flat and we head out on this big lap of Australia.
They have used the Brown Davis filler with yours. The guys who installed mine said they use the Ineos one because the Brown Davis was a bit bulky and the angles of the tubing didn’t quite fit. The downside was the tank being slow to fill but that was rectified with a second breather.
That's the kind of installation I was hoping for. You know, someone who actually thought about what they were doing and didn't just slap it together. I wouldn't take my Grenadier back to the place that did the work and wouldn't recommend them. On the one hand I can kind of forgive the exhaust hard up against the shock. They weren't an exhaust shop and didn't have the equipment to do a simple expansion operation on the tube. They would have had to take the entire tank out again just to cut the pipe shorter to make it fit right and no doubt that would have cut the profit on the job. If it was me, I would have taken the tank back out or taken the exhaust tube to an exhaust shop. The filler tube just annoys me now every time I look at it. I'll take it apart and do the job right when we're back in the UK.
